Question about Jaybird JF3MB Freedom Bluetooth Headphones JF3
Jaybird JF3MB doesn't turn on
Connect USB to charge. Red light comes on for about 2 minutes, then off. Earbuds do not turn on when button on right bud is pushed
My tzumi wireless Bluetooth earbuds didn't come with instructions
You could ask direct. Link at the bottom. Normally, you just switch them on and then set your phone to search and then when found you click on it and then PAIR. If it asks for a code the default is 0000 (4 x zeros)
BLUETOOTH CONNECTIVITY: Pair effortlessly to iPhone, Android, Smartphones, tablets and all Bluetooth enabled devices. Move freely with wireless listening
  • POWERFUL AUDIOPHILE TUNED AUDIO: Drivers professionally tuned by our sonic engineers driver crisp wide range natural sound quality with powerful bass.
  • HIGH DEFINITION MICROPHONE WITH REMOTE MUSIC CONTROL: Answer incoming phone calls with the push of a button. Clear natural sound on both ends of a call. Control your players Power, Play, Pause, Stop, Volume Up and Down, Previous and Next Track. Features are compatible with today's popular phones
  • WORKOUT AND SPORTS READY: Secure In-Ear Fit make these Pro EarBuds Perfect for the gym. The headphones come with three sizes of earbuds Small, Medium and Large.
  • QUICK RECHARGEABLE BATTERY WITH 7 HOURS OF PLAY TIME: Connect the micro USB plug to micro USB port and connect USB Plug with power supply, average charge time 1 hour. Micro USB. USB cable included.
  • V
    Video instructions
  • TZUMI Wireless Bluetooth Earbuds Unboxing - YouTube www.youtube.com/watch?v=Ekzbkw33SF8
    • BY JEREMYTALKS TECH
    • 2 MIN
    • 21K VIEWS
    2015-08-03 · Today I bought TZUMI Wireless Stereo Earbuds Sports Series since we are moving in the age of technology where wired earbuds are ...
  • Tzumi wireless stereo Earbuds review - YouTube www.youtube.com/watch?v=dvljuqYXEp0
    • BY JET2595
    • 8 MIN
    • 15K VIEWS
    2015-09-13 · Tzumi wireless stereo Earbuds unboxing - Duration: 10:49. ... Tzumi Bluetooth Wireless Stereo ProBuds Sports Earbuds Review - Duration: ...
  • Support Tzumi
    May 02, 2016 | Radio Communications
    I was on the phone with my BB Torch, then the battery ran out, i got back the next morning, tried to put it on charge, nothing happen, no red light, no indicator , nothing, tried the charge for few ghours...
    Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. If the red light doesn't come on, connect the charger and put the battery inside. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
    Sep 09, 2011 | RIM BlackBerry Torch Cell Phone
    Sro 8120 transonic mp3 keeps cutting out like its going flat when its charging a red light comes on sometimes flashes and the device will only play for a few minutes
    Taken from the Quickstart User Manual
    LED Light 1 (L1) - is by the earphone socket
    LED Light 2 (L2) - is by the USB connector
    Charging: Please switch on the player before charging. (Push the on/off switch to 'on' )
    When charging the battery for the first time it is recommended that the player is charged about 8 hours. Connect the player to an active USB port using the supplied cable. The computer must remain on during the charging process.
    Recharging: Recharge the player will take about 3 to 4 hours. When it's charging, L2 will turn on in red, when it's fully charged, L2 will turn to green light.
    When playing music, L1 will shine.
    Sep 01, 2011 | Audio Players & Recorders
    Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
    Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
    Aug 18, 2011 | Samsung SL102 Digital Camera
    It is stuck on low battery screen and charging light won't come on.
    Hi imrydn!
    You can try these steps:
    1. Connect the reader to the AC Adapter (If available). If not, then connect the Reader via USB to the computer
    2. Hit the reset button for 3 seconds at the bottom
    3. The red steady light should come on, if not, try the reset again while the unit is connected
    4. Allow the reader to charge for 40 Minutes (on PC make sure the computer does not go into sleep mode.
    5. Disconnect the reader and see if operational.
    GoodLuck!
    eBookBoy
    http://digialreader.freeforums.org
    Aug 01, 2011 | Sony Reader Touch PRS-600
    When i turn on my prs 300, the screen flickers and the light on top is yellow. when its done trying to turn on the light flashes a few times and thats it.. i've tryed several computers and they cant...
    Hi jmjohnson198!
    2. Hit the reset button for 3 seconds.
    GoodLuck!
    eBookBoy
    Jul 16, 2011 | Sony Reader Pocket PRS-300
    My Sony ereader touch isn't charging. Pluging it in to either the computer or the wall charger, and the light doesn't go on. The screen is frozen on the last page it turned to.
    Hi suebagnall,
    If the redlight does not come on, try the following:
    1. Connect the reader to the wall charger (make sure you use the Sony Charger ACS5220)
    2. Hit the Reset button at the bottom of the reader
    3. Check if the redlight comes on
    4. If so, leave the reader charging for 15 minutes to see if it takes the charge
    5. If this does not resolve the problem, probably you will need to contact Sony to get it repaired
    eBookBoy
    www.digitalreader.freeforums.org
    Jun 27, 2011 | Sony Reader Touch PRS-600
    My wireless Logitech mouse stopped performing. I changed batteries. the red light comes on even before I changed the battery. I have had it about 3 months. Wal Mart told me to look on the back of mouse. ...
    So much for Wal-Mart tech support.
    If your mouse is not working, first check the batteries to be sure they are good.
    You wireless mouse has a USB "antenna" or sending unit. It may have a button on it that says "connect." If so, push it.
    The mouse itself has a little button on the bottom that says "connect."
    Push that one next. It should now work.
    If it doesn't, switch USB ports and try again.
    And no, we don't charge for this answer.
    May 13, 2011 | Logitech Cordless Mouse
    When you plug the reader in to recharge is a red light supposed to come on until charged? How do you know when it is fully charged?
    Yes, the red light should be turned ON after connecting the Reader to te Computer. That means the Reader is taking charge. After getting it fully charged, the red light will be turned ON. If those things will not happen to your reader, perform the below mentioned stepos::
    1. Connect the Reader to a different USB port of the Computer. 2. Connect the Reader directly to the USB port of the Computer; dont use any USB hub or adaptor to connect the Readr to the Comp. 3. Disconnect the Reader and then press the RESET button. 4. Try connecting the Reader to a different Computer to check whether the USB port of the Computer is working properly. 5. If the issue still persists, service may be required. Follow the below link to initiate the repair: http://eservice.sony.com/
    Feb 02, 2010 | Sony E-reader Portable E-book MP3 Player
    My jabra BT160 won't charge
    i had the same problem with mine. the problem is with the completely empty battery.
    solution is to disassemble it and force charge the battery inside.
    you have to cut any usb cable leaving the side which connects to pc and remove the insolation from red and black wires. connect them for few seconds to battery soldering points on jabra board (red to red, black to black, sometimes you have to scratch the solder a bit if it oxidized a bit). once you see the light you can start charging it normally.
    Sep 23, 2009 | Jabra BT160 Wireless Headset
    Jaybird JF3MB Freedom Bluetooth Headphones JF3 Logo
    1,346 people viewed this question
    Top Jaybird Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Jaybird Audio Player and Recorder Expert? Answer questions, earn points and help others
