Question about Jacuzzi Pool & Spa
I have power and temperature readout but pump and heater do not come on.
I hear a clicking sound when i hit the pump switch
  • Jacuzzi Master
  • 717 Answers
This sounds like either the transformer is not working or you have a bad circuit board.
First thing to do is check the voltage coming out of the transformer.
RodUS Parts Center888-521-6183
Posted on Feb 08, 2013
Breville Cafe Roma , worked fine, stored for 2 yrs, now it will not pump. Powers on, heats up, but when the switch is placed on water or steam setting, no pumping sound at all, perfectly silent. One...
Just a guess, water is usually like oil (a lubricant) in your pump, so standing 2 years it's "dry" or there is no water being supplied or there is a screen or filter that is plugged.
Possible no power to pump, or an inline fuse or circuit breaker to the pump and heater has blown. Or a temperature safety sensor has disabled power to pump and heater. Owner's manual might help.
Feb 10, 2018 | Breville Coffee Makers & Espresso Machines
I have this model water heater. The past few days i haven't had any warm water and ive been hearing my water heater make strange sounds. I look on the little box and there's a light blinking 3...
Yes.
Copy following link for service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Plug blower in separately and see if blower motor functions. This will eliminate blower as suspect.
Have plumber check wiring, test and replace blower temperature switch, test and replace pressure switch, and conduct routine maintenance
Apr 04, 2013 | Bradford White M1TW40S6FBN 40 GALLON...
Tried several times to turn on heater..turned the switch in back of heater in the direction it should be..then hit on switch..no sounds coming from heater..water temp & set point..just blank..nothing...
Thank you for posting your question here on Fixya.com.
Is it an electronic with a digital readout and the readout is blank? If so, double check the toggle switch on the outside of the chassis on the right, looking at the front of the heater, is on. If it is and it is still dead confirm you have power up to the switch and then to the transformer inside the heater on the upper right sidewall. If you have power to the transformer then replace it; your problem would be the transformer secondary is dead therefore the heater is to. If you do not have power to the transformer but do to the switch replace the switch.
If you do not have a digital display please post a comment to that effect and include your unit's model number for further assistance.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Jun 26, 2011 | Raypak 2100 Pool Heater Gas 266000 BTU'...
My hurlcon mx series pool/spa heater stopped and displayed F2 fault. The operation manual action is" Allow water to cool,turn heater off then on again".Having tried this it did not fix it. Any...
Look at the pool water temperature readout. If this is a crazy figure say 60 to 120d deg C replace the thermistor line probe that senses water temp. its in the black water manifold.
Jan 23, 2011 | Pool & Spa
Heater dose not heat you cant hear the oil heting up anymore what is wrong
Heaters have several safety devices--
Perhaps one of them has opened:
If the heater is not heating (as evidenced by not hearing the sound any more..)
Can you look deeper into those devices-- such as:
1.) A tilt control (If the unit tips over-- it opens the circuit..)
2.) Overheating temperature limit (Sometimes a little fuse-looking device, that is also a temperature limit-- Can you remove it, and check it for continuity?)
3.) Some devices have a temperature reset button-- does this one?
4.) Can you hear the thermostat slick-- going up past room temperature, and click again, when you go down below room temperature?
When you look deeper, let us ow what clues you are finding, and maybe we can help further.
Mack B
Jan 10, 2011 | Lakewood Oil-Filled Electric Radiator...
I have a Dream Maker Eclipse spa. We just had the pump replaced, but the tub is getting TOO hot that we cannot even get in it. We opened the housing and see 2 metal heat sensors but they are not attached...
The readout may be getting it's temperature from one of those sensors that are hanging in mid-air, not surprisingly low. Both sensors have to be somewhere that they can read some water temp. One of them probably goes into the piping before the heater so it can tell actual water temperature. The other MAY go in piping after the heater in the event of high water temp, it will shut the heater off. Look for a schematic in and around the spa.
Dec 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
How can I tell if the thermostat is broken or not?
Before going to electrical components ,please firstly check the power supply ,then the electrical wire to the heater and so on .
Oct 04, 2009 | Honeywell Programmable Thermostat Heater
Pool & Spa Logo
42 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
