Question about Lg800g With 1200 Minutes And TripMinutes For Life tracfone
Unable to enter an extension number
Numerical screen disappears before an extension number or a number required from a menu can be entered
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • LG Master
  • 102,366 Answers
Touch "Dialpad" on the screen to bring up the number screen.
Posted on Jan 02, 2013
How to reset unable to clean 50 on dcp-j125
Try to reset Purge, it just might help.
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Clean unable 46 error on dcp 135c brother printer
Jun 03, 2014 | Brother DCP 165C Compact Color Inkjet...
Unable to print 32 printer brother mfc 9490cw
Unable to.....
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine
Sep 15, 2011 | Brother MFC 6490CW InkJet Printer
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
How do I manually/automatically update the channels on my Samsung DNli DV3 TV?
Hi Hugh.
Please follow these instructions to manually/automatically update the digital (DTV) channels on the Samsung LE26R73BD.
Please use the following buttons on your Samsung remote control to navigate the on-screen menus:
- "D.MENU" - Opens/closes the on-screen menu (below the numerical key "0")
- DIRECTIONAL ARROW KEYS - To navigate up/down/left right through the on-screen menus
- "ENTER/OK" - Selects/confirms a selected option (in the centre of the arrows)
Automatic Channel Scan / Update:
1. Make sure you are in digital TV mode - Press the "TV/DTV" button on the remote to switch between analogue (ATV) and digital (DTV) modes.
2. Press the "D.MENU" key
3. Highlight "Installation" (first option) and press "OK/ENTER"
4. If asked for a PIN code, enter 0 0 0 0 using the numerical keys on the remote. If you have set a different PIN code, please enter your own code here.
5. Highlight "Select County" and press "OK/ENTER"
6. Use the LEFT/RIGHT arrows to select "UK" then press "OK/ENTER"
7. Highlight "Auto Scanning" and press "ENTER/OK"
8. Highlight "Scan Mode" and use the LEFT/RIGHT arrows to set the value to "Digital"
9. Highlight "Start Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 21 . . ."
10. Highlight "End Frequency" and use the LEFT/RIGHT arrows to set the value to "CH 69 . . ."
11. Highlight "Start Frequency" again and then press "OK/ENTER" to start the channel scan.
Some of the options above will already be selected so will not need to be changed. I've provided the correct settings just in case they are incorrectly set. Note: UK Freeview stations are on channels 21 to 69 inclusive.
The scan will take a few minutes to complete and the progress will be displayed. When the channel scan is complete, the menu should close automatically and the TV will return to viewing mode. If not, press either the "D.MENU" or "EXIT" button to return to watching TV.
Manual Channel Scan / Update:
7. Highlight "Manual Scanning" and press "ENTER/OK"
9. Highlight "Channel Number" and use the LEFT/RIGHT arrows to choose which channel number you wish to scan . . .
UK Freeview stations are on channels 21 to 69 inclusive. In manual tuning mode, these need to be scanned one at a time. Please note, many of these channels are "empty". UK Freeview only uses 5 of these channels (called Multiplexes or MUX) or 6 if you have HD. I am unable to tell you which 5 channels these are as they vary according to whichever transmitter or repeater station your aerial is aligned to.
10. Press "OK/ENTER" to start the channel scan.
11. Repeat steps 9 and 10 for each additonal channel you wish to scan.
Please note: Manual scanning can cause some unexpected results - particularly if your aerial has a reception from more than one transmitter/repeater. For this reason it is better to use the automatical scan unless you have a specific reason for needing to scan manually.
Hopefully this will be all you need to update the digital channels on your TV. If you have any questions or need further assistance, please let me know.
Regards,
BElectric
Jan 07, 2011 | Samsung Televison & Video
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
Derivative feature does not work
The newer version of the OS 2.0.0.1188 is quite different from the initial version. It would be a good idea to upgrade the OS.
Back to your question. Since I upgraded my calculator, I am unable to illustrate the calculations with screen captures that are meaningful to you. If you do not mind I will show you how to calculate derivatives and integrals using OS Version 2.0.0.1188
In Calculator Mode
  1. Press the Menu button.
  2. Use down arrow to highlight 4:Calculus or just press 4
  3. Select 1:Numerical derivative at a point and press ENTER
  4. An entry screen opens where you can select the name of the independent variable (default is x, not X), the point where you want the derivative and whether you calculate the first or the second derivative.
  5. After you make your choices, you press ENTER and a template is displayed in calculator screen.
  6. All you have to do then is to specify the function you are differentiating.
Here are a few screen captures to illustrate the process.
For the numerical integration
Select Calculus (see above)>Numerical Integration>ENTER.
Type in your integral using the template. Here is the procedure illustrated.
May 28, 2010 | Texas Instruments TI-Nspire Graphic...
Street name that is a number.
When you need to enter an address that is numerical such as the 52nd street, enter as normal until you reach the street name. At the bottom of the screen, you will see a button that says, "123." Press this button, then enter the number (52, in your case). Press done, and it should say something like, "52nd (Street, Ave, Etc.)" Press this button, and your address should show up. Please let me know if there is anything else I can do for you.
Mar 03, 2008 | Garmin StreetPilot C330 GPS Receiver
Errors list : 46, 50, A1
CP315C/310CN/120C/115C/117C/110C
(1) Press the (1) Press the
Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
enter the maintenance mode. enter the maintenance mode.
(2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
Set keys.* Set keys .*
(*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the display the numerical code to be entered and then press the
Set key. Set key. Repeat this operation for each Repeat this operation for each
numerical code.) numerical code.)
(3) Press the (3) Press the
Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
(4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
(5) Press the (5) Press the
Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
(6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
Lg800g With 1200 Minutes And TripMinutes For Life tracfone Logo
81 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
