DVDR3480 Player/Recorder--- Disc Tray will not open .Please Help!
The recorder and player is perfect but lately the Disc Tray has been giving problems (not working on the first instruction sometimes only opening on the3/4instruction.) To-day it justs refuses to open 02/01/2013.I have tried on several occasions without success..I am at a loss at what to do next. I would appreciate any suggestions thanking you in anticipation Mr Edward Canning.
  • 130 Answers
SOURCE: Disc Tray: Daewoo DVDS151 DVD Player
Some have a little hole in the front, you pull the power and use a paper clip. Bend it out so its fairly straight then you poke it into the hole and it unloads the mechanisim. If there is no hole you may have to remove the cover.
Posted on Apr 21, 2006
  • 8 Answers
SOURCE: DVD player/ recorder problems... PLEASE HELP!!!
I have now had two Panasonic recorders 3 years apart and both have gone down with this same fault.
It's a shame as they are a fantastic recorder, I would have thought Panasonic would have put this right by now. It now 5 years on since I bought my first one and it sounds as if they still have the same fault.
Why the hell can't they just fit a standard computer dvd drive that’s cheap to replace, and not this abortion they fit.
I was looking on E-bay for Panasonic recorders that where faulty and found around twenty.
ALL WITH THE SAME FAULT
"DVD drive faulty"
I’m now looking for a new one but don’t know what to do as I have a ton of discs that need to be finalized, may just forget about them and keep clear of Panasonic in future.
Posted on Jul 09, 2008
  • 3 Answers
SOURCE: My Memorex DVD Recorder (MVDR 2102) won't open
Most likely one or more capacitors on the main board went bad. I just fixed one last night with the exact symptom.
Posted on Oct 09, 2008
pishta68
  • 593 Answers
SOURCE: I cannot open the DVD
The DVD drawer might have a small hole under the tray. You can use a straightened paper clip to push into the hole and this is supposed to manually push the slot out enough to grab and pull out. The DVD might not be seated in there.
Posted on Nov 27, 2008
SOURCE: Eject tray will not open when pressed, just comes up with blocked.
The small slot on the underside of the machine seems to be basically there to provide access to the manual opening lever (the white nub). That white nub popped the drawer open straight away for me. So now I have drawn an arrow on the underside to remind me which way to move the lever next time it happens! You can also move it the other way to get the disk to play. I also think you should never leave the machine without a disk in it - ejection of the empty drawer seems much harder for some reason. And possibly the ejection works better if you use the stop control on the remote instead of the eject button on the front of the machine.
Posted on Dec 15, 2008
My hk 30 player tray flashes (disc error) with every digital audio disc. help
Often times the tray and pickup lift assembly are related and there is a cam alignment. IF you pulled out with force the tray the alignment may have been upset to where the cam is not completing the lift of the Pickup and if not in the right position the laser will not be able to focus. The correct solution is at a Technicians bench where a new belt could be put in, lubrication that is required and some cleaning will be done.
Jan 21, 2013 | Harman Kardon CDR30 2-Disc CD Recorder
I got a 765 phi lips cd recorder player and every time i put a digital audio cd to rec it indicates no disc but the right tray plays perfectly what can i do it is a very important material for my work plz...
make sure check your manul for the correct disc it could say digital audio,but look carefully on disc for scratches or dust clean lens and check disc for cd-rw or cd-r digital audio i had the 770 and have the same problem and i kept buying the wrong disc.
Jul 30, 2011 | Philips CDR775 2-Disc CD Recorder
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
Recording with a philips DVDR3480 using dvd+r
my phillips dvdr3480 will not let me record from my camcorder it states writing has failed please help
Dec 10, 2009 | Philips Televison & Video
Disc tray keeps opening/closing on DVD recorder
my dvd player sony cinema entertainment system dav-dz111 the tray is opening again after closing
Sep 22, 2009 | Televison & Video
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
LG DVD REcorder disc tray will not open
Most likely the tension band that is attached to the mechanical parts of motor and the tray detached. you'll need to disconnect the power and unscrew the cover open and put the band back in place.
May 21, 2009 | LG DR787T DVD Recorder
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
TDK DA 3826 disc tray not functioning
Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
Philips dvdr3480 picture problem
swap the scart inputs around. See if that solves it
Sep 02, 2007 | Toshiba DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
