Question about GE WBVH6240F Front Load Washer
Need to check drum in a wbvh6240fww, seized - GE WBVH6240F Front Load Washer
  • Awilda Chaparro Jan 02, 2013
    So how can I access the drum to check?
  • Leigh Perlmutter
    Leigh Perlmutter Jan 02, 2013
    More than likely you will need to remove the back panel to access thye drum assembly. It might be easier to figure out if you could get an exploded drawing of the parts and a parts list from the manufacturer on its web site.
    Genius:
  • 1,669 Answers
Does that mean that the drum is jammed? if so you will have a job and a half accessing the drum and looking at its rollers as well as the drive mechanism to see if it is damaged... It probably got knocked off its guide rollers when you had your laundry unbalanced in the drum and it was banging around!
Posted on Jan 02, 2013
Belt snapped ..motor shaft turns freely
could be bearings or a brake for the drum energized
Call in a technician and get a repair quote
Jan 10, 2016 | Electrolux Washing Machines
WBVH6240FWW loud bang
that would be the bearing and housing gone on the drum, if you can lift the drum with your fingers at the bottom of the drum in the door hatch even by putting lifting inside then the bearing has gone. the plastic is the drum.housing usually were the bearing housing is. if there is a lot of movement then the bearing has gone. usually the front bearing but you will need to remove the drum and separated the drum to remove the drum then the bearing, rust on clothing is the bearing as its the only part in the drum that is metal.
Jun 27, 2017 | GE WBVH6240F Front Load Washer
Hi I have a Beko / flavel TD162 W dryer . The belt broke so I replaced it yesterday , however when i opened it the drum was actually seized so I thought the back bearing but no it was fine . The front of...
I believe you will need to replace the drum glides since the drum rollers are good:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 16, 2011 | Dryers
The drum inside my ge wbvh6240fww washer is loose. I can move it around with my hands. During spin cycles it sounds like a tornado, and the room fills with smoke from where the drum rubs. The belt is fine,...
There is one bearing in rear tub/bearing is part of rear tub...To repair that unit you will need a rear tub/inner basket with spindal and possible a front tub if it damaged..If i was you I would price the parts b/c you may not want to repair it as it can be costly .....Good luck
Jan 31, 2011 | GE WBVH6240F Front Load Washer
I am having the same problem.
Did you find a solution.
Our washer is just a little over 2 years old and I am trying to decide if I should just cut my losses and never buy a GE product ever again.
Oct 12, 2010 | GE WBVH6240F Front Load Washer
Drum is stuck and does not move after a noiny spin. pls advice.thanks
Sounds like possibly the main drum bearings have seized.
To check, remove the rear panel of washer, remove the drum belt, and try to turn the drum by hand, if it is noisy or rumbling, or not turning at all, then likely the the drum bearings have seized.
This is a major repair, and could be expensive!!!
Mar 17, 2010 | Indesit W 123 Front Load Washer
With the Kenmore series 80 Dryer plugged in, Pressing the start button causes the motor to hum as if the belt, pully or motor is frozen. The drum doesn't turn during the humming and is difficult to turn...
You'll need to remove the back panel and determine the cause. Look for:
Seized drum support rollers (3)
Seized drive and/or idler pulleys
Burned out or seized motor
Possible bad motor start capacitor (if equipped)
Drum alignment
Mar 29, 2009 | Dryers
Hotpoint WF740 Aquarius Plus Drum Seized.
hi the code will flash that because of the drum being seized in my opinion the bearings have seized to replace them you will need to remove the front of the machine disconnect all the wires from the drum not the machine there are two plastic pegs holding the suspension legs to the drum which you will need to remove. push the pins in at the backof the pegs and pull out the pegs,sorry you will need too remove the two concrete blocks top/bottom first, then remove the pegs lift out the drum remove the fixings around the drum with a t-30/t-40 bit,then split the drum now comes the tricky bit - AT THE BACK OF THE DRUM IS A 13MM BOLT UNDO THIS ONE TAKE OFF THE FLY WHEEL AND THEN REPLACE THE BOLT HIT THIS BOLT AS HARD AND AS CLEANLY AS YOU CAN WITH A LARGE HAMMER SO THE STAINLESS STEEL DRUM COMES OUT THEN YOU NEED TO GET THE OLD BEARINGS OUT THESE CAN BE A PIG SOMETIMES SO DONT GIVE UP THEN REPLACE WITH NEW ONE'S PUT BACK TOGETHER IN REVERSE ORDER.hope this helps if you can think you can do it it's not as bad as it looks ,good luck
May 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
GE WBVH6240F Front Load Washer Logo
196 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
