Question about Zee Line Lever Chemical and Biodiesel Pump, Model 377
I have a 2004 Renault Megane 1.9 dci . I am running it on biodiesel without problems but I heard that I shouldnt be doing this???
What type of rubber seals are used in the injector pump of a Renault megane 2004 1.9 dci? will they be affected by biodiesel?
  • jsouter
    jsouter Jan 02, 2013
    Is it a Bosch VP37 pump
What is torque setting on renault megane 1.5 dci (2004)?
I assume you are looking for cylinder head tightening torque specifications?
Stage 1: 25nm
Stage 2: 25nm
Stage 3: 90 deg
Stage 4: 90 deg
Stage 5: 90 deg +- 10deg
Yes that is correct- a total of 270 degrees!
Hope this helps!
Apr 27, 2014 | 2004 Renault Megane
What is the cylinder head tightening torque for a renault megane 1.5 dci (2004)
Stage 1: 25nm
Stage2: 25nm
Stage 3: 90 deg
Stage 4: 90 deg
Stage 5: 90 deg +-10 deg
Yes, that is correct- a total of 270 degrees (3/4 of a turn!)
Renault megane 1.9 dci starts and cuts out
Check your fuel filter and add some rubbing alcohol or heet to the gas tank. You more than likely have water in the fuel.
Dec 03, 2012 | 2004 Renault Megane 1.9
Spanner flashing on dash renault megane 2003 1500 dci
the spanner symbol is indicating your engine/car is due for service/maintainance which if your vehicle is high milage ?/ it may also require the cambelt renewal and the tensioner may i suggest you do not ignor this warning light i am sure you have heard horror stories of the consequences of engines cambelt breaking ?? hope this helps and you heed advice given ?
Mar 09, 2010 | 2004 Renault 181
Code do radia renault megane 2006 15 dci
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also confirm the MAKE of CAR it is fitted into.
Jun 05, 2009 | 2006 Renault 181
Injector problem megane 1.5 dci 2003
its a renault ??what else do you expect its an electrical nightmare
Dec 23, 2008 | 2003 Renault Sportwagon
Renault megane dynamique dci 80 2003
Check your plugs again, make sure they aren't gunked up already or covered in oil or anything. Double check the spark gaps on them as well.
Jun 10, 2008 | 2003 Renault 181
Zee Line Lever Chemical and Biodiesel Pump, Model 377 Logo
62 people viewed this question
Top Zee Line Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Zee Line Plumbing Expert? Answer questions, earn points and help others
