Question about Kitchen Ranges
The gas will light but stays on very low even if you turn to gas mark 9 why?
    Sergeant:
  • 475 Answers
Did you make sure that your hose doesn't have a kink in it,Or, is your half go on it yet?
Posted on Jan 02, 2013
My gas Dearborn model#drc40mc pilot light stays lit.when I turn to on position and heater comes on , it burns high , even on low number setting, then after few seconds goes out taking pilot out also
clean/replace the flame sensor. Your heater doesn't recognize that it has lit and continues to try and light the gas. when the sensor doesn't tell the 'brain' it lit? it shuts down the gas for safety reasons.
Oct 19, 2014 | Heating & Cooling
Warning light for low fuel stays on
The sensor is part of the fuel pump module inside the gas tank.
The signal is sent to the body computer, so it could be a faulty module or a problem with the body computer.
The circuit would need to be checked with a meter.
Feb 08, 2013 | Volkswagen Cars & Trucks
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Tom
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
2000 Toyota Corolla DX Gas Light Stays On
Yes, I believe the Sending Unit is probably bad. I presume the guage works, it is just that the light stays on. The light is getting an electical connection because the ECU thinks that gas is low. It is not getting the signal from the Sending Unit. I hope this assists you, if you need further assistance p[lacvse come back and we will continue as needed. Please rate this free service after your solution is posted. Thank you gfor trusting FixYa.com to help get you going!
Apr 15, 2010 | 1991 Toyota Corolla
Have cleaned the oven ..flames are low even when set on gas mark 9
check that the sensor has not been dislodged from over the flame
Mar 25, 2010 | Ovens
Instrument panel battery light stays on even after turning off and key has been removed. Also gas low tank, low oil indicator light and side airbag lights come on.
has vehicle been recently jump started? could have a blown fusible link... check all the fuses with a test light......or may have a bad ignition switch. have alternator tested also a bad diode in the alternator could be backfeeding
Jan 21, 2010 | 2004 Ford Focus
Charmglow Patio Heater
The yhernocoupler would snuff the pilot if bad. What ignites the overhead burners? and what regulates the overhead gas supply? Look into this. Too much gas will not light as easily as proper balance gas and air. Even more so in a tower type heater.. Turn the gas on low and the pilot should grab it. Good luck
Jun 05, 2009 | Coleman (5040B750) Patio Heater
Need Instructions to use Fireplace Gas Logs
There should be a set of metal cards attached inside the fireplace.
First you should read everything there.
I know you have to first light the pilot light.
And then there should be a wall switch.
The problem I have currently is that it won't stay lit when the artificial logs are there.
Nov 03, 2008 | Heating & Cooling
Gas Grill - flame always stays on high even though I've turned in on low
hey buddy that use to happen to me so what i started to do was once the fire was high i use to turn the gas off i hope this helped.
 infamouspk
Oct 07, 2008 | Sport & Outdoor - Others
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
