Question about Lexmark X364dn All-In-One Laser Printer
How do I get to the Disable scanner menu on a Lexmark X925de?
Error 840.01
2 Suggested Answers
Printtech
  • 1087 Answers
SOURCE: 840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Posted on Aug 19, 2011
INVALID SCANNER CODE error
You need to download the firmware from support.lexmark.com then send it to the printer either via the network connection or usb. If you are connected by ethernet you can put the devices IP address into internet explorer and send it via the printers built in webpage, you will find an update firmware option there in the configuration menu. To use usb you would need to get the usb flash utility first
Jan 21, 2013 | Lexmarkr X646E Multifunction Printer -...
Unrecoverable scarn error X6650 series
The " unrecoverable scan error " indicates a scanner hardware problem. Please contact Lexmark Technical Support for assistance.
Feb 03, 2012 | Lexmark Office Equipment & Supplies
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
Lexmark e450dn print head error: 935.1x, 935.2x --------------------------------------------------------------------- what can i do? i cleaned the scanner unit and error its present on...
935 error indicates that scanner motor cannot reach proper speed. Likely the scanner motor is bad but it can also be the controller board.
Mar 10, 2011 | Lexmark E450dn Laser Printer
WHEN BOARD BOOTS ERROR 512 - CHASIS FAN NOT DETECTED APPEAR LET ME KNOW HOW TO DISABLE THIS ERROR it does it every time i start, or restart the computer, and i have to hit F1 to get it to boot, what...
hi this is a setting in the cmos or bios you have to hit delete key or F2 depending on make of system to get into the menu, locate the setting for the chassis fan speed then disable that and you should not see the error on boot again...hope this helps
Jan 14, 2011 | Computers & Internet
Lexmark T642 When printing, LCD displays
this error is a scanner lost lock error and can be caused by the scanner or the logic board. if this error comes up immediately on power up the scanner motor is not initializing by percentages of failure the scanner is approximately 85% the logic board 15% i would change the scanner
Nov 23, 2009 | Lexmark T642 Laser Printer
Lexmark 6100 cartridge error 50c
Are you using a factory "New" Lexmark cartridge?
Lexmark does not support the use of refilled cartridges or third party cartridges in their products.
Lexmark considers this to be Product Tampering and will void the printer' warranty.
Don
May 11, 2009 | Lexmark X6100 Flatbed Scanner
Error 2200 on a Lexmark P6250
This is a scanner error. The light bar that goes back and forth during a scan is getting stuck for some reason. You might also double check your cartridges. There is a complete article about this on the Lexmark website at: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:462:0:0&framed=&docid=ENUS24402&relevance=1 The user's guide should be installed on your computer (Look under Lexmark 6200 Series in your Start Menu) You can also find the manuals at http://www.lexmark.com/publications/eng/6200/index.html
Sep 18, 2007 | Office Equipment & Supplies
Lexmark X364dn All-In-One Laser Printer Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
