Question about RCA TH1602 MP3 Player
RCA Pearl TH1602 MP3 Player i can not get my songs on it
  • 684 Answers
It depends sometimes some songs may be copyrighted and cannot be played on the Mp3............ But as u say ur able to play 67 songs............ Just format your Mp3 player...... Formatting the Mp3 Player: Connect the Mp3 player to the Computer.......... Go to My Computer> Right click on the Removable Disk and click on Format and click on Start..... Know reload all the songs back to the Mp3 player..... Good Luck............
Posted on Jan 19, 2009
My RCA pearl mp3 player will not go from the first setting and i cant listen to the music.
my RCA pearl mp3 player will not go from the first setting and i cant listen to the music.
Aug 23, 2011 | RCA TH1602 MP3 Player
Tip
How to Fix Your RCA Pearl TH1602 MP3 Player from Freezing at Startup
Does your RCA Pearl TH1062 MP3 player freeze on startup at the Pearl logo?
Whenever your player acts up, the best solution is to reflash/upgrade the firmware.
Download the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and follow all the troubleshooting instructions that popup when you start the program:
  1. start the program,
  2. remove the battery,
  3. hold the play button while plugging the RCA player into your computer's usb port,
  4. release the play button when the term "initalizing" replaces "searching",
  5. check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
  6. click the start button to replace the firmware.
This solution will fix your player.
I hope that helps.
on Jan 17, 2010 | RCA TH1602 MP3 Player
RCA pearl th1602-a with new battery will not power on. Old battery will power on, but freeze at pearl logo. Player dosn't power on when plugged into USB of computer
Try a firmware recover. Download the firmware update from the RCA website and install the app. Start the updater and connect the player holding the PLAY button until it gets detected.
This is a similar player with the recovery procedure explained:
Oct 28, 2009 | RCA TH1602 MP3 Player
RCA pearl th1602-a with new battery will not power on. Old battery will power on, but freeze at pearl logo. Player powers on when plugged into USB of computer. It is already at the latest firmware.
When was the last time you flashed the firmware? Even if it already has the latest firmware, it sounds like it is still corrupted and need to be reflashed. It appears you already know where to find the latest firmware update based on your comments, but just in case you can download it here:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2557
Oct 22, 2009 | RCA TH1602 MP3 Player
My mp3 rca th1602
You can d/l the drivers for you Pearl here http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1. Follow all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button when the the term "initializing" replaces "searching",
You might want to leave the "format data" box unchecked to see it that works. After I did this, my pearl started normally, and my computer recognized it again.
Jul 06, 2009 | RCA TH1602 MP3 Player
RCA TH1602 MP3 Player in locked
You should be able to force the Pearl into recovery mode by removing the battery, then hold down the "Play" button while inserting into USB port, after a few seconds, Windows should detect "USB Human Interface Device" (see Device Manager). Now you should be able run the firmware update. Worked for mine after it froze up one day and would not be detected as a USB device by Windows.
Nov 14, 2008 | RCA TH1602 MP3 Player
Hey i have a Problem
Make sure the lock by the headphone jack is not engaged first.
If it is not locked, then reset the player by removing and reinserting the battery.
Make sure the player is fully charged before transferring songs - transferring large amounts of songs in one sitting can sometimes drain the player's resources faster than it can recharge.
-Tha Mp3 Doctor
May 24, 2008 | Audio Players & Recorders
RCA TH1602  MP3 Player Logo
235 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
