Question about Health & Beauty
Battery condition meter does not work anymore
  • anderson_519
    anderson_519 Jan 07, 2013
    craftmatic comfort coach 4
  • anderson_519
    no the led one on the front
  • 1,263 Answers
Hi, what the scooter brand ?
Regards
Posted on Jan 02, 2013
  • 1 more comment
  • anderson_519
  • Robin Hill
    Robin Hill Jan 07, 2013
    do you mean the charger indicator located at the rear or the one located on the tiller ? regards
  • anderson_519
The battery condition meter on my Celebrity X scooter is always lit up to full. The meter never moves below the full, even when battery is not completely charged. What could be the problem here?
Hi possible fault with the little computer ( control box ) if the batteries r in good condition & u r driving on flat ground over short distance's they won't change much .try going up a few hills to check them ....cheers
Jun 19, 2017 | The Health & Beauty
Tip
Battery Testing
Batteries can be measured with a volt meter, this usually gives a reading in volts such as 11.5 or 12.0. The voltage reading will not indicate battery condition.
All electrical requirements are established in amperes. Amperage of a battery can not be determined with a volt meter. The battery is a storage of amperage, however in order to measure this amperage it must be on the move, meaning operating something that requires power.
The only way to determine battery condition is by the use of a load tester. A load tester basically shorts the positive side of the battery to the negative side of the battery through a large resistor, this measures the amperage inside the battery, thus giving battery condition.
You can and will get readings, from a volt meter, anywhere from 10.5 to 12.0 volts on a bad battery. So if you suspect you have a bad battery, have it load tested to determine it true condition.
on Mar 27, 2009 | 1999 Ford Escort
No power to anything
hi its no use checking youre batteries with a voltmeter .multimeter this will not tell u how the condition of the batteries r u need a battery load tester to check condition of the cells ..u can buy them of E/BAY.....good luck
Nov 29, 2015 | Hurricane Pride PMV Mobility Scooter -...
Survelliance headset won't work anymore with motorola t9500
Try leaving the batteries out overnight and see what happens
Aug 13, 2014 | Motorola Talkabout® T9500 Two Way Radio
Solidtek ask 4251 this is a wireless keyboard, I had to replace the batteries in the keyboard, but still won't work.
Does the battery light come on? Then it's still the batteries, try them in something else or a battery meter. Otherwise you have fried the circuitry of the keyboard (probably spilled something by accident on them). They're no good anymore.
Jul 27, 2011 | Computers & Internet
Hello, I recently purchased a nikon F2AS, it was in top condition, except there was no battery in the meter. Installed a new battery, and it occurred to me that the metering in the viewer was not clearly...
In Canada the cost of such repair would be about $100.00. I'd suggest not attempting the job yourself because the meter and shutter will need to be timed and a repair facility would have the necessary tool for doing this. An internet search will reveal several service places other then Nikon to have this done. I've even seen auctions on e-Bay selling service and had a Canon A 1 serviced. If the camera is in otherwise good condition and you enjoy the creative aspects of a manual film camera then you have a great classic to work with.
Oct 05, 2010 | Nikon F2AS Photomic 35mm SLR Camera
I think I have a bad battery... What should the voltage be
If you use a multi tester, it should come up at 24 volts or 25 volts on the meter, if it's less than that, then the battery isn't going to work anymore.
Jun 24, 2010 | Peg Perego Gaucho Superpower
My 2003 chevy ventuew will not start anymore
battery probably bad or you have drain somewere
start with the easy,have battery charged and load tested
Mar 25, 2010 | 2003 Chevrolet Venture Passanger
No power
Is the AC plugged directly into the notebook or is there an external power supply? If it is the latter, any multimeter would tell you if the external supply is still doing something.
If you have a meter (or a friend with one), don't get confused if the output if much higher than is stamped into the case since these are often only crudely or totally un-regulated with the bulk of the work being done inside the case where circuitry regulates power for the board with the computer on and the batteries under all conditions.
Sep 14, 2008 | Panasonic Toughbook CF-27 Notebook
Health & Beauty Logo
20 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
