Question about Superwinch 2320200 LT2000 ATV Series Utility Upgrade Switch
Superwinch lt2000 only works one way - Superwinch 2320200 LT2000 ATV Series Utility Upgrade Switch
2 Suggested Answers
  • 31 Answers
SOURCE: Superwinch LT2000 will only work one way? Help?
you may have burned the controller a winch works by reversing the polarity remove the two nuts on the winch itself that the wires go to and reverse the wires now your winch should only work in the other direction if this is the case amazon.com has some pretty reasonable priced controllers
Posted on Jan 12, 2011
Winch only works one way
Sounds like bad internal connection between terminal and brush
Feb 12, 2014 | Cabela's Mile Marker Warn Trail Tamer and...
Need a wiring diagram for my superwinch S4000 for my quad
try (860) 928-7787 first you need to make sure a 60 ampere alternator and battery with 440cca capasity are there-this is a min. requirment as far as install call above number i hope this helps a little
Nov 26, 2013 | S4000 Winch: 1440200 Trailer, Towing &...
Wire diagram for 9' ATV Rocker Winch Handle Bar Mount Remote Control Thu to the winch
Here's the owner's manual - it includes wiring & installation information:
http://mediacdn.shopatron.com/media/mfg/4377/media_document/4398/10991.pdf
If you're looking for information that is not provided in the manual, you should contact Superwinch directly:
In the USA:
Superwinch, Inc.
Winch Drive
Putnam, CT 06260
U.S.A.
Tel: (860) 928-7787
Fax: (860) 963-0811
e-mail: info@superwinch.com
Elsewhere:
Superwinch, Inc.
Unit D, Union Mine Road
Pitts Cleave Ind Est
Tavistock, Devon
PL19 OPW England
Tel: 44 (0) 1822 619222
Fax: 44 (0) 1822 615204
e-mail: sales@superwinch.net
I hope this helps & good luck!
Jan 13, 2012 | Superwinch 1120210 Atv Lt2000 Series Winch
Wire a winch
The 1585202 winch is capable of pulling 8500 pounds when provided adequate DC power. With no load (winding up slack the cable) the motor requires 84 amps and winds at 18 feet / second. When fully loaded (8500 pounds), the motor requires in excess of 320 amps and winds at 3.5 feet / second. That's an awfully large amount of current and it will need heavy duty power supply cables to work without overheating or melting insulation. I suspect your 1585200 is the same model with same electrical requirements, but did not include a fairlead, mounting plate, etc..
Superwinch has wiring kit #2007 for front mount (5 foot cables) and #2008 for trailer mounts (25 foot cables) and can simplify the installation with other accessories as well. They're a U.S. company and can be contacted them directly:
Superwinch, LLC
359 Lake Road
Dayville, CT 06241 US
Ph: 860-928-7787
F: 860-928-1143
www.superwinch.com
Dec 22, 2011 | Electric Superwinch 12 Volt DC Winch -...
I havea LP8500 superwinch. I unhooked the cover wires RED,WHITE and Black and I can remember how they go back onto the solenoids. can you help me. thanks mark
This may help (or maybe not):
The Black wire is the ground wire, and the other two are considered Hot wires, and their
order does not matter - they carry 240 Volts AC.
So, once you identify which terminal on the solenoid is ground, connect Black to it, then just hook up the remaining two Hot wires in any order.
Jul 04, 2011 | Electric Superwinch LP8500 Series Utility...
When I try and use the winch all I get is a clicking sound from the control box. The winch motor will not engage in or out. When the winch clutch is placed in the out position I can free spool the cable...
It sounds like you have broken a pinion tooth. Remove the screw from the end housings and open to inspect the drive gears. Parts can be purchased from Superwinch for these or off e-Bay.
Jan 16, 2011 | Electric Superwinch LP8500 Series Utility...
Jan 12, 2011 | Superwinch 1120210 Atv Lt2000 Series Winch
Wiring up super winch
I am wiring a Superwinch 4500 to my Yamaha Rhino.
Problem the two red wires go to the key switch.
Do they just splice into the 12 wire ?
Sep 25, 2009 | Electric Superwinch LP8500 Series Utility...
LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Superwinch locking hubs
i would think so other wise you will have a large vacume leak and truck will run bad too.
Feb 01, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Superwinch 2320200 LT2000 ATV Series Utility Upgrade Switch Logo
110 people viewed this question
Top Superwinch Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Superwinch Hammering Expert? Answer questions, earn points and help others
