Question about Home
Replacing eurobath bathroom tap
Do not know how to remove the tap in order to replace the washer.It is a eurobath brand bathroom sink tap
    Problem Solver:
  • 19 Answers
If you want to remove the tap for replacing washer then you should detach tap by looses it's screw. You can also hire a professional to do this work easily.
Posted on May 04, 2013
Have a Rannai R75LS and getting hot water everywhere except my sink in the bathroom. System doesn't come on with only bathroom sink running.
I think these have a water pressure s/w or water movement s/w id replace the aerator 1st to a non water saver one or if possible remove water flow reducer looks like a metal washer .. if this not help you may need to replace the pressure s/w...in tank..
May 01, 2011 | Rinnai Water Heaters
My waltec bathroom sink was leaking now that i messed with it ,its running by itself how do i fix this problem
It would help to know where is was leaking and what you "messed with"?
But in general, the idea is to replace the washers.
To do that, first turn off the water under the sink.
Then you first remove the handle on the leaking side.
There is often a small metal or plastic cover over a phillips screw.
Then remove the metal cap around the handle stem by unthreading or lifting up.
Then you can remove the valve by turning it as if to make the water go on.
It will have a washer on the bottom, held on with a screw.
Remove the screw, get a new washer, and then replace.
http://www.moen.com/shared/pdf/instruction_sheets/ins1923a.pdf
Dec 20, 2010 | Moen Kingsley Two Handle Bathroom Sink...
Change a tap washer
Turn off water at wall valve under sink. Turn on tap to ensure valve is shut off. Remove tap handle. Remove cap, collar or bushing holding shaft in place. Shaft may need to screwed out to remove. Replace washer on end of shaft, then re-install parts in reverse order.
Nov 10, 2010 | Home
I have rust spots/stains in my bathroom door frame which is alongside my showerwater appears to be getting into the door frame (aluminium not wood) and staining the paint its rust spots so i know its...
aluminium does not rust so the stain will not be rust stains
could be leaking fitting at the plumbing pipes at the taps
could be that the washer under the tap insert is leaking especially if not replaced when doing the spindle seals
May 03, 2017 | Washing Machines
When I turn on the cold water tap in the Bathroom Sink the water comes out in a very slow drip or not at all, the CW bath tap is ok
Confirm that the shut-off valve under the sink is open all the way. If it is, then close it and remove the cold water tap. If this is a single handle tap you will of course have to turn off the hot water shut off under the sink too.
With the tap removed and a bucket and towel handy, open the cold water shutoff just a little bit. If water comes rushing out, the problem is obviously with the tap. You may be able to clean or repair it, or you may have to replace it.
Mar 19, 2010 | Home
I have a wall hung sink with a drain that leaks because I can't get the washer tight enough to the fixture. I've tried a couple of different sizes of washers, but no luck. I don't know what brand it is.
There should be between the washer and the sink fixture a large rubber washer that you can compress to seal the joint. You can also get a small tub of "plumber's putty. Use a small amount of putty, roll in a ball and turn into a snake shape..wrap in a coil around the sink before you slide the washer up and squeeze the washer into it.
Be sure to check the small ball socket that controls the sink drain plug. Sometimes the retainer nut isn't snug and it can leak a little and it will appear that the main drain is leaking... Hope this sloves your issue.
k
Jun 21, 2009 | American Standard RAVENNA WALL-HUNG SINK -...
Installation of washer/dryer combo with no taps available
hello you can buy washing machine taps that screw on to the main water pipe. what to do is turn your water supply off at the stopcock and get the your new tap and clamp it on to the water pipe and tighten it up.it will make a hole into the pipe and to the same with the other 1 when your done turn water supply on make sure you have no leaks good luck
shaun
Mar 28, 2009 | Haier HWD1000
JADO BATHROOM SINK FAUCET DRIPS
Jado are ceramic disc cartridges no washers you should replace both sides.You need to remove the handle and unscrew the cartridge
Mar 13, 2009 | Plumbing
Home Logo
505 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
