Heil furnace electronic ignition module red light flashes
Furnace states look in service manual, where would i get one? i have all manuals that came with furnace.
    Problem Solver:
  • 7 Answers
The flash codes are usually on the control box or the back of the furnace door
Posted on Feb 23, 2013
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: I JUST WANT TO FIND THE DAM MANUAL FOR MY HEIL
[PDF] 2100-016 (1976 11)File Format: PDF/Adobe Acrobat - View as HTML
Operate the manual reset button on top of control. ..... 19 Fuel Unit - Sundstrand A1VA-7012. 20 Fuel Unit Mounting Screw. 21 Oil Line Fitting ...
www.bardhvac.com/digcat/volume_3_cd/install.../2100-016.pdf
Posted on Jul 22, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
Posted on Oct 17, 2009
Why wont furnace light past the thermol coupler
There is really not enough information here to go on. If this furnace has a thermocoupling, the pilot will need to be lit manually. Follow the manufacturers lighting instructions carefully. If it still will not light you may have a dirty pilot assembly or a defective gas valve. Modern furnaces do not use a thermocoupling. There is no standing pilot light. Each time the furnace needs to be lit it will be done electronically. Many reasons why it wont light in this case. Safety control could be preventing it from lighting for safety reasons. A bad ignitor, ignition module, circuit board, gas valve, pressure switch, gas supply, induced draft motor, blocked or restricted flue pipe, cracked heat exchanger, dirty flame sensor, ect. ect. ect.
Oct 07, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evon BGU10016A put in new ignition light and still wont heat up, what next
Check to see if you are getting power to the ignitor... if not then the ignition control module is bad or there is another control that is keeping the control module from trying to light the furnace...
Check for 24v power going to the control module and also check that all of the saftey controls are closed and completing the safety circuit...are you getting any flashing LED'S on the control module?
Oct 21, 2011 | Coleman Propane Forced Air Heater...
Pilotlight needs to be lit
Your furnace does not have a standing pilot light. The GMS-9 furnaces was furnished with Electronic Ignition Control. I'm attaching a link for the service manual for your furnace. Good Luck in your endeavor! :-)
http://securenet.goodmanmfg.com/pdf/infoPdf/Lit/RS6610004R4.PDF
Mar 01, 2010 | Goodman GMS90703BXA Heater
The heil furnance ignitor module error code
Remove the cover from the control box,there's a guide posted inside to trouble shoot the codes.
Jan 02, 2010 | Cross Furnace Draft Inducer Blower 115...
HEIL 80% furnace T-STAT calls for heat, Inducer runs and nothing else happens, Ohm meter reads 4.9 on ignitor. MDL#NTGM100EHA2....Any help with this?
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Nov 03, 2009 | Heating & Cooling
Igniter does not turn on
need more info....Remove the front panel and look for a sticker that will tell you what the Diagnostic flash codes are...3 . 4 . 5....etc...I service many funaces and cant memorize all the codes..lol...we always need the \manual....What does the furnace do??...Turn the power off (after you observe the code)...then turn it back on with a call for heat....What happens????The exhaust fan starts......then the ignitor starts glowing....etc.////this info is more important than flashing codes
Oct 31, 2009 | Goodman GMS90703BXA Heater
Furnace won't turn on....
jump out thermostat or try jumping out the pressure switch
Feb 23, 2009 | Goodman GMS90703BXA Heater
Furnace integrated control module
The light is supposed to be on, if there is a fault in the furnace the light will begin to give u a flash pattern... ie; three flashes...or two flashes.. on the furnace exterior or on one of the doors there should be a fault code chart.... read the chart on the unit it will tell you what light is on and when..
Jan 14, 2009 | Goodman GMS90703BXA Heater
16 year old Heil 75K btu furnace, some times does not ignite.
recommend getting a carbon monoxide indictor or having some one test it. with it being over 15 yrs old if checks good replace ignitor assy should fix it ok
Dec 14, 2008 | Cross Furnace Draft Inducer Blower 115...
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
