Question about Sony Str-d350z, Av Am/fm Reciever, Home Theater System, W/remote, Manual
Sony reciever shows protect on display - Sony Str-d350z, Av Am/fm Reciever, Home Theater System, W/remote, Manual
    Genius:
  • Sony Master
  • 1,054 Answers
May be bad connections on the preamp ic's. Otherwise there is a short in the amp that needs to be repaired.
Posted on Jan 02, 2013
Why is protect is flashing on display
There is a defect that is causing the light to come on. It could be a bad output transistor or some other defect that produces excessive heat. The cooling fan could be at fault too.
Aug 27, 2014 | Sony Str-d350z, Av Am/fm Reciever, Home...
Sony GX800ES protector
Make sure none of the speaker wires are touching each other. If they are, it will short out the stereo which triggers protection mode and cuts out all of the sound.
Sep 21, 2007 | Sony STR-GX800ES Receiver
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Sep 19, 2012 | Sony STR-DG600 Receiver
I have a Sony STR-DE 597 reciever. I have been using it fine for a few years with no problems and it sounded great. I turn the unit on recently and a message was displayed on the unit that said PROTECT....
Protect will usually show up if the receiver was turned up too loud to the point where the speakers will crackle, the receiver will switch to protect to not damage anything. Unplug it for about 30 seconds and check all the audio wiring in the back to make sure everything is plugged in good and tight and no loose cables or stray pieces of copper audio wire and plug it back in.
Aug 21, 2011 | Sony STR-DE595 Receiver
My reciever is blinkning 'protect' after being turned on. It starts up as normal but after the initial start it starts flashing 'protect' and after it starts flashing I can not do anything but turn it off....
It shows protect when it senses a problem with the output wires shorted or some internal fault. Try disconnecting all the speaker wires and power up again. If it still shows protect, then the fault is internal.
Mar 12, 2010 | Sony Audio Players & Recorders
I HAVE A SONY RECIEVER SRT-DE597 6.1 CHANNEL AND I ITS ON PROTECTED MODE CAN YOU HELP ME UN PROTECTED
Amp output is damaged and needs repaired. Protect mode cannot be deactivated. When amp is repaired and operating normally protect mode will not be displayed.
Aug 29, 2009 | Sony STR-DE597 Receiver
Protect displaying
Protect on any reciever usually means that it has reached its maximum capacity of volume (known as clipping) and at the reciever is now automatically reducing the volume to avoid damage. This some times is triggered if the reciever was used hard and is now damaged so you would need to bring it to a repair shop. Sometimes its caused by a bad wire to the speakers, a short to say. Check all your wiring, make sure its not overheating and getting plenty of air. Some where its recieving a signal telling it to go into protect mode.
Joe
May 28, 2009 | Audio Players & Recorders
Sony STR-DE698 7.1
in Sony receivers Protect display shows problem / fault in Amplifier output area. Qualified technician can repair the damage.
Regards,
Sep 04, 2008 | Sony STR-DE698 Receiver
Protect?
Overload protection circuit kicked in. Check all your wires (speakers,input,output cables), There is a short somewhere and lets hope it's not In the receiver.
Jul 12, 2007 | Sony STR-DE197 Receiver
Sony Str-d350z, Av Am/fm Reciever, Home Theater System, W/remote, Manual Logo
120 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
