Blank screen after boot splash screen
I have an emachine all in one EZ1711. At boot you see splash screen and with the 'Del for setup' and 'F12 for boot options', then the screen goes blank. If you press del quickly enough it says 'please wait' and then goes blank. I think it actually boots, but you can't see anything. I've tried a Windows 7 disk to try and repair, but although you can hear the drive working, the screen is still blank. Any ideas appreciated.
  • John Gorman Jan 02, 2013
    Update: It's like what happens if you have a laptop set for an external display, but has no external display connected so can't see the output. In this case, this machine is an all in one and has no output for an alternative display and hence to way on the keyboard to change the display. Anyone with any ideas?
  • Simon Crisp May 03, 2013
    I am having exactly the same issue with a customers machine, if you have any luck let me know, thanks
  • 4,806 Answers
Hi.
After you see the press Del and F12 message repeatedly tap the F8 key, see if that gets to the advanced boot menu, if it does select "Repair my Computer" from the list, and then follow the prompts. Have your Win 7 disk ready just in case you need it.
Let me know how you get on and good luck!!
Posted on Jan 02, 2013
  • John Gorman Jan 03, 2013
    No joy, but thanks for your time. Any further ideas appreciated.
3 Suggested Answers
bigbiggs
  • 326 Answers
SOURCE: Acer Aspire T180 Frozen
Select the del and in bios, select optium defaults. next select F12, will it go any further?
Posted on Jun 09, 2008
  • 21 Answers
SOURCE: XPS 600 BIOS setup problem
light 1&2 is a memory configuration error.make sure you have the memory in correctly
Posted on Jan 18, 2009
Emachines e528 load to blank black screen after windows loading
Sounds like you lost your Operating system, Probably going to require a reformat to repair
Apr 12, 2013 | MSI Emachines E528 Original Laptop Genuine...
Hello my emachine n450 doesn't boot. After I power on, only blank screen appear... What's should I do?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 26, 2013 | Acer eMachines 3502074 Netbook
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Emachine t1150 boot order
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this will set the boot order
hope this helps
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
http://www.easyhelpguide.com/easyusermanual.asp?mnf=eMachines&mdl=eMachines
Jul 29, 2012 | E-Machines Computers & Internet
Screen on presario 2500 is black blank and won't change
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 19, 2012 | HP Compaq Business Notebook NX9010
I can't enter cmos althouh i press del or f2 when i press del ,next screen appear blank with cursor. will this problem solve by upgrading bios?
Restart your computer do you see prees f2 or something else
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Hope this helps
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Jul 03, 2011 | MSI PM8M-V Motherboard
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
My daughter forgot her password on emachine E725 and can not boot. How can we reboot the computer? Thank you.
Assuming that you mean the Windows log in password, try using blank (none) as password (otherwise at the log on screen hit "enter"). If this doesn't work log on at the administrator's account. To do this if you can see the administrator's icon click on it and use blank (none) for password again. If you can't see the administrator's icon, hit ctrl+atl+del TWICE and type as user "administrator", blank (none) for password and hit enter. After you log on as administrator change your user's account as you wish and you are ready to go.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Apr 02, 2011 | Acer eMachines 520-2890 Notebook
Laptop won't boot. No splash screen. Crash
Take out any USB device from the PC when rebooting: some BIOSes will incorrectly try to boot off them.
If that doesn't work, enter the BIOS Setup (F2 or Del key at boot) and find the Boot Devices menu, confirm that the highest-priority one is "Internal HDD" (or the name of your internal hard disk).
Nov 07, 2009 | Acer Aspire 5670 Notebook
PC doesnt POST or boot to bios screen
Please try to press 'Del' key during start-up / manufacturer splash screen, it might display the Bios set-up screen. regards
May 12, 2009 | Computers & Internet
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
