Question about Saeco Magic De Luxe Espresso Machine
Cannot remove central unit to clean
I have tried to remove the central unit to clean it. I was able to do so in the past. I can open the door and press the tab that says "Press". The unit will move a bit, but is stuck on the lefthand side, possibly where the little tube is. Thank you for any help, which I urgently need!
I finally gave up pulling on the central unit - so I just closed the door & it reset & I was then able to easily remove the central unit to clean it.
Posted on Oct 30, 2012
  • 29 Answers
Two possibilities. You inturrpted the cycle and need to put it all together and turn it on and let it finish the cycle. If this does not work: It is possible that the gear motor is bad or it was overfilled and just can't compress the coffee in it. The brew unit has a small screw on the inside back rail. If you remove this small screw and pull out on the unit it seperates the unit from the receiver that is stuck to the boiler right now. If you can seperate this and depress the switch that the brew unit trips when in and with all the other parts in close the door and let it finish the cycle. If it does you should be able to reinsert the unit. If this does not work go on line and look for an authorized Saeco repar center they can help you.
Posted on Jul 30, 2007
  • Diane Collyer Ayers
    Diane Collyer Ayers Oct 30, 2012
    Thank you thank you! It worked!
  • 432 Answers
Push the left side as your push the "Press" button. Push down and back. They do get stuck sometimes. Keep trying. Don't break it, but I used a screw driver one time. Be gentle. Take a deep breath.
Posted on Jun 25, 2007
My right side passenger door does not lock automatically anymore. Is there a fuse that operates this.
no all is related to one fuse you can remove the door internal controls and decore and remove center lock motor plug and test two connectors with multimeter with set on 12v and then lock un lock door and check the reading of the multimeter if it read signal then all plugs and wires from central lock control unit to the door central lock unit is okay it this cae you have to replace the door central lock unit with the same if no signal is readed while you lock unlock the door then you have to check central control unit and all wire plus out of it to the door plug
2- you can remove central control unit from driver door and test it in passenger door (usually the same unit ) if it works with lock unlock its then the replaced unit is faulty and needs to be replaced if it not work then check plugs wires from central lock unit (usually found inside driver door ) to the central lock unit in passenger door
3- check signal for said door fro the output of central door unit if no signal then it mean that faulty central lock control unit
Feb 23, 2015 | 2005 Honda Accord
I have several problems with my Whirlpool washing machine AWO 12763: 1 .- For a long time do not make spin until we press the door. 2 .- For the past few weeks, when entering water, says suddenly we...
Hi.
F-22 is door lock error. The door lock was already defective and now has failed completely. You need to replace the door lock.
Here the error explained in detail:
F22
DOOR LOCK ERROR
Theme Door Lock message is prompted when the door cannot be locked. The CCU (central control unit) will try to lock the door six times before displaying the F 22 error code.
Possible Causes:
The door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
Repair Procedure:
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock, and the central control unit.
Regards.
Ginko
Jun 04, 2011 | Washing Machines
My whirlpool duet GHW9100L washer door will not unlock and code comes up F dl, any idea's?
Ff dl (failure fault door lock)
Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
The door lock may have to be removed and replaced to get past this failure.
Mar 18, 2010 | Washing Machines
Machine light turns on, cycle light blinks, door is closed but the door lock light doesn't come on and washer won't start. Code shows f dl?
The door lock and switch assembly has failed. You may actually hear it click several times before the code appears. If not, it may not be receiving power or signal from the central control unit to activate.
Disconnect power to the washer to avoid electric shock.
Remove the three screws from the rear of the top panel attaching it to the cabinet then slide the panel rearward, and then lift it off the cabinet.
Disconnect the third and the fourth from right, facing the front of the washer, wiring harness connectors from the central control unit. Clean the connector terminals thoroughly then reseat it several times to ensure a good connection between them. Do the same with the connector second from the top on the left side of the central control unit.
After ensuring that the connectors are properly connected, slide the top panel back in place, and then secure it the three attaching screws.
The next thing to do is visually check the door lock and switch assembly for physical damage.
Remove the wire and spring assembly that holds the door gasket to the lip of the door opening. Use a pair of needle-nose pliers to stretch the retaining spring then remove it together with the wire.
Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness. Clean the terminals and reseat it several times.
To replace the door lock and switch assembly (part #8182634); connect the wires properly then secure the assembly into position behind the front panel with the three securing screws.
Put the eased part of the door gasket back in place over the lip of the door opening.
Check that the door gasket is properly seated before securing it with the retaining wire and spring around the lip of the door opening and the door gasket.
Mar 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My door keeps locking and then it wont open. It beeps DL or F11.
Hi There
I have found the codes for you and hope this will help you.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Thank you for writing to fix ya.
Best Regards Richard
Dec 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have a kenmore elite 3 washer...stopped with 8 mins left in cycle...try to restart but getting F DL code...cannot open washer door
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Replace the door lock mech if the wiring is ok
Oct 11, 2009 | Kenmore Washing Machines
Door locked , i cant open, tried soo much, Frigidaire WL 5892
this is almost always caused by a defective ccu, central control unit. Try unplugging the washer for 5 minutes.
Aug 31, 2009 | Washing Machines
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
Saeco royal coffe machine
Clean the central unit whenever the coffee bean container is filled, or at least once a week. If the water hose seems dirty it is probably due to hard water and needs to be descaled.
Descaling is done with a special citric acid you can buy in any grocery store or dealer of such machines. follow the directions and run clean water through afterwards.
To clean the filter:
Switch off the machine and open service door
Remove grounds coffee container .
Remove central unit, by holding the handle and shortly pressing the PRESS key. Wash the central unit with hot water; do not use any solvent.
Make sure there are no coffee residues on the two steel filters: the upper filter can be removed by unloosening and turning the plastic pin anticlockwise using the tool supplied with your device. Dry thoroughly each central unit component, fit the filter again and tighten it properly with the screw .
Remove coffee rest drawer and clean it, using a non-abrasive solvent. Clean the service area thoroughly and fit the coffee rest drawer again. By holding the central unit by its handle, slide it back into its original position, making sure it is correctly engaged. Then close the door. Fit the coffee grounds container again.
good luck, stephen
Jul 04, 2008 | Saeco Royal Professional Espresso Machine
DL error code
DL is a 'Door Lock' error code.
A Door Lock Error occurs if the door cannot be locked. The Central Control Unit (CCU) will try to activate the lock 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism has failed
• Wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Central Control Unit (CCU) has failed.
There really isn't much you can do except replace the defective parts. The door locks have been troublesome and have replaced some. But there are cases where the CCU will develop an internal intermittent connection to the door lock causing it to work then not work. Check your owners manual for limited warranty on the CCU. The door lock only warranted for 1 yr.
Regards;
reg501
The FixYa Team
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Saeco Magic De Luxe Espresso Machine Logo
229 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
