Question about Dacor Kitchen Ranges
How to replace bottom burner in range? - Dacor Kitchen Ranges
    Sergeant:
  • 475 Answers
If the store you bought the thing from is still there they should have replacement parts at that store for you.
Posted on Jan 02, 2013
Lofra service perth
Instructions
    • 1 Disconnect the range's power supply, either by turning off the breaker in your service panel, or unplugging the range from the wall outlet.
    • 2 Remove the burner grates, burner caps and burner bases. On some ranges, the burner bases are secured using screws, which you must remove.
    • 3 Insert a putty knifeicon1.png into the gap below the front of the each side of the range to release the spring clips securing the top to the range.
    • 4 Lift the top, and then have a partner hold the top up. If you are repairing the range alone, place a sturdy object under the top to secure it.
    • 5 Remove the burner orifice containing the igniter that you are replacing.
    • 6 Remove the screw securing the igniter to the underside of the orifice, and then remove the igniter.
    • 7 Pull the igniter wire off of the terminal, and then discard the igniter.
    • 8 Connect the igniter wire to the new igniter.
    • 9 Secure the new igniter to the underside of the orifice using the screw that you removed.
    • 10 Replace the burner orifice, and then secure it into position using the bolt that you removed.
    • 11 Lower the top onto the stoveicon1.png, and then press down to engage the spring clips.
    • 12 Replace the burner bases, caps and grates.
    • 13 Restore power to the range by plugging it back into the wall outlet or turning on the range breaker.
Read more: http://www.ehow.com/how_12064545_fix-ignition-switch-stove-top.html#ixzz2bSNNTBF9
Aug 09, 2013 | Kitchen Ranges
Viking gas oven model # VGIC3656BSS, serial #022404-2919 takes FOREVER to preheat up. Sometimes in excess of 40 minutes. Been a problem for a while. Looks like flames at bottom do not increase when oven...
When increasing the temp. on a gas range the oven's burners do not increase flame size as the cooktop burners do. It just keeps the burner lighted for a longer amount of time.
First if you can see the burners do they light within about a min. or less. If no you probably have bad igniters which are not lighting the burners as quickly as they should or they are "opening up" (stops working) when they get too hot. In this case replacement of the igniters should solve the problem.
Second if it lights quickly but still takes a while to heat; you want to look at the burners to ensure that the flames are down both sides of the burner tube and not dancing around too much. If only part of the two sides of the burner tubes are lighted then a pluged orifice or burner tube is the most likely cause. Once cleaned it should work fine.
As with anything mechanical there are numurous possiblities for something not working correctly and above are the two most popular reasons that come to my mind.
May 17, 2011 | Viking VGRC485-6 Gas Kitchen Range
Oven won't heat up
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 04, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Range works, but oven does not heat up and I smell the gas . What should I do?
  • remove the oven cavity bottom, remove burner shield and clean the burner inside the oven.
  • make sure all holes in the oven bottom are not covered with anything (i.e. foil)
  • adjust ignitor position (move it slightly closer to burner)
Nov 17, 2009 | Whirlpool GW395 Gas Kitchen Range
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Cgr3765adc, during bake mode upper burner does not ignite, gas smell. upper burner does ignite during broiler mode however. this problem seems to be in control module perhaps, not with igniter or burner...
In bake mode only the bottom burner will ignite. The gas smell could be caused by improper adjustment of the air intake on the bake (bottom) burner or something (foil) covering the holes in the oven cavity floor.
Jun 10, 2009 | Magic Chef CGR3725ADS Gas Kitchen Range
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Element burnt out
replace the swich for that burner.thats the one behind the knob.
Dec 02, 2008 | Hotpoint RB787 Electric Kitchen Range
Oven not working but burners are...
replace the glowbar just because it glowes doesnt mean its good the one you want to replace is the bottom one take the racks out and remove the bottom panel there are two screws remove the then under that will be a flame spreader remove that under that will be the burner bar and ignighter
May 22, 2008 | Frigidaire TGF317 Gas Kitchen Range
Kitchen Ranges Logo
52 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
