Question about Kitchen Ranges
Belling FarmhouseCookcenter 111 - oven keeps going on and off, and igination keeps clicking
Oven stays on for 10 minutes or so then goes off and wil not come back on. Also the ignition keeps clicking which makes the oven light flash on and off.
    Sergeant:
  • 475 Answers
Your hoses may have to be replace in order for the gas to get to the stove right.
Posted on Jan 02, 2013
SOURCE: oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Posted on Aug 06, 2008
Bat1956
  • 585 Answers
SOURCE: Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
Posted on Dec 24, 2008
  • 10865 Answers
SOURCE: Whirlpool oven won't ignite
The good news for you is that your gas provider, the folks who bill you for the gas offer a free service whereby they will send out a technician to adjust your stove for no cost.
Posted on Apr 01, 2009
not a gas flow problem because i can manually light the burner just fine
Posted on Feb 20, 2010
SOURCE: Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Posted on Oct 06, 2010
My belling wall oven model number 444440560 keeps going out after only a few seconds ignition how can I fix this thNks
which is going out top or bottom? may want to check the oven safety valve though it does not normally go out compared to other components. may have a bad igniter ( does it glow or lite up at all) it may still glow but not put out enough current to ignite flame? check with multimeter as well. if oven top is going out also check the igniter model or infinite switch
Mar 10, 2015 | Belling Ovens
Belling gas oven will only work when holding in ignition
The oven piot light heats a sensor which keeps the pilot light burning after releasing the button. The pilot light flame must be sensed by the sensor, the sensor must be in working condition. Replace the sensor or make necessary adjustments to make the pilot light flame burn on the sensor. The sensor is either a thermocouple or a generator. Thermocouple is standard, a generator needs to be properly matched with its type rated in millivolts, same rating for the replacement.
Feb 10, 2015 | Belling Kitchen Ranges
Thermal cut out
Probably the internal temperature sensor, not a difficult job but if you attempt it yourself kill all power to oven.
Nov 19, 2013 | Belling Ovens
Vulcan Comenda VC200 Wiring Diagram Series: 200/31/0166
Hi i have a belling DF951 fan oven .the heater element stays on when the oven is switch off .Is it the thermostat that is faulty because i can not leave it on .I HAVE TO SWITCH THE MAIN SUPPLY OFF.Or the oven stays on all night
Aug 23, 2013 | Belling XOU174 Electric Single Oven
Belling Farmhouse Cookcenter Model 111 main oven wont reach temp
Same problem here too. Plus the in-game assisted oven has a similar problem inasmuch as the flame goes straight to max and won't reduce. Please help
Apr 05, 2010 | Belling FarmHouse 931 Gas Kitchen Range
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
I was wondering can i buy glass for the oven door seperate?
Providing the oven is not more than 10 years old, then there,sholud be no prob obtaining a new door glass.
Go to: www.belling.co.uk
Then click on: www.4belling.co.uk/spares
Pleas leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Belling Ovens
Electric oven switches off wen it been on for an hour or so
You may have a problem with the board. It is not hard to replace. Call a tech if necessary.
Jan 29, 2009 | Ovens
Belling Synergie fan oven.
the elemet has burned out round the fan
Dec 05, 2006 | Belling XOU174 Electric Single Oven
Kitchen Ranges Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
