Question about Bosch HES7152U Electric Range
Touch sensor Bosch HES-7152U /01
Cannot turn off oven
  • Frank Gracen Jan 04, 2013
    When I could not turn the oven off, and realized there was a problem, the obvious, was to unplug it ! Which I did and re-plugged in the next day. The panel sensors were still unresponsive. I googled panel problems, and read where a replacement board were purchased, only to realize the problem was not the panel ! The Fix! was as simple as the adhesive backing used to adhere the pane,l had become loosened, due to the heat over time. Allowing it to hang freely. Poor design, if you ask me. But I resolved my problems in less than three minutes, at no cost to me.
  • wackieworld
    wackieworld Jul 13, 2013
    Thank you very much. I found the problem thanks to you. I can't figure out how to keep it glued in place. Right now I have a tennis ball jammed in place.
    Sergeant:
  • 475 Answers
Maybe if you unplug it let it sit for for a half hour then plug it back in maybe that might work.
Posted on Jan 02, 2013
I am looking for a manual for a bosch microwave hmt9656au/01
Try Googling (bosch)(hmt9656au/01)(manual) without parens.
Jun 22, 2017 | Bosch Microwave Ovens
My Bosch (hbn13b251b) bottom oven and light is not turning on intermittently. Sometimes when I resetting the breakers it's comes back and works perfectly. What part do I need to replace? Thanks,
You may have some of the wiring that it exposed to metal. It nay be touching and turning it off. It may be slight and only does this when the oven is bumped. I don't understand when you say the oven and light is not turning on intermittently. It should not turn on intermittently to start with.
Jan 18, 2015 | Bosch Ovens
Changing oven bulb in main oven bosch hbm 91600b/01
Contact your showroom and ask to replace the oven bulb
May 27, 2011 | Audiovox Bosch 718 World Cellular Phone
I have an error code 45
As per Bosch,
Error Code: F45 Cause: Upper (or single) oven latch both locked and unlocked; Defective or jammed upper oven door or latch switches. Corrective Action: 1. Check P4 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are pinched to the appliance chassis. 4. If F45 persists, replace power board
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 19, 2010 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Bosch HBN745AUC control panel broken and needs to be replaced. Any DIY advise appreciate, included the parts no. and cost information.
If you mean the glass in front of the display and touch panel is smashed, you can buy a new glass panel, about $200, part 239424 (for a stainless oven), see bosch parts link below. Probably the electronic touch sensor board underneath is fine, but its basically glued to the glass panel so will be a bit tricky to peel off and re-glue to the new one.
http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=HBL745AUC%2f02&ESHOPTYPE=S
Jul 12, 2009 | Bosch HBL 745 Stainless Steel Electric...
Digital display of temp and clock on Bosch HES elec range malfns
Are the numbers missing parts to them or are they just not there in toto? If it is missing parts the lcd screen is fubar. Otherwise it is the electronics that are at issue.
May 03, 2017 | Bosch HES 232 / HES 236 Electric Kitchen...
Replacing interior oven light
Here is the manual for your unit:
Bosch HBN3550/01
The instructions are on page 31.
Hope this helps and please remember to rate this!
Dec 06, 2008 | Bosch HBN 3550 Electric Single Oven
Bosch HES255U Covection bake slow to get up to temp.
My Bosch HES255U Freestanding Electric Range has been reading an error code of all "E's" or r 2 E E. I shut it off completely through the circuit breaker and allow it to reset. When I turn it back on, it starts to beep and shuts off.
Nov 01, 2008 | Bosch HES 232 / HES 236 Electric Kitchen...
Oven control panel
Lok at your manual tp view all the possible control options. However, the solution could be; The touchpads, in conjunction with the dial, are used to select an oven mode,
set the oven temperature, set the time(s) and to set up your range. To use the
touchpad, press the center part of the pad with the flat part of your fingertip. A
beep will sound to indicate that the selection has been made. Turn the dial to the
desired setting and press START.
Pull the plug or flip the circuit breaker, wait five seconds and plug in the range or flip the circuit breaker to on. Always set the clock after installation or after a power failure. Once power returns to the oven, the clock defaults to 12:00 am.
Clock time display can be turned off. The default display is on.
1. Access SELECT FUNCTIONS Menu.
2. Turn knob clockwise until CLOCK DISPLAY is displayed.
3. Press START.
4. Turn knob to select ON or OFF
5. Press START to accept new selection.
Reset the Factory Settings This feature is used to change all the “Select Functions” settings back to the original factory settings (or defaults).
2. Turn knob clockwise until RESET DEFAULTS is displayed.
3. Press START. Display reads SELECT FUNCTIONS.
Dec 03, 2007 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Bosch HES7152U Electric Range Logo
101 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
