Question about Polaroid i830 Digital Camera
SD Card Locked; Tried formatting SD card still no luck
Hi, can you help please? my SD card continues to say "locked". I have tried going into the setup>format>yes. When I do this it continues to say "locked". When I do the same exercise and take the SD card out....it indicates "format completed". any other thoughts?
  • 684 Answers
There will be a small slide switch on the SD card u need to just slide that switch on the Opposite side that then insert it to the camera it will work fine....... Good Luck
Posted on Jan 19, 2009
Ok,please,help!I've just bought a BenQ DC C1450 digital camera in black which came without an SD card,but I had two of them at home.So I came home and put in one,but when I turned on the camera it said...
Make sure the card is not locked. Move the slide switch on the side of the card back and forth a couple of times ending with unlocked. Let me know the results.
Apr 22, 2011 | BenQ Cameras
Everytime i try to take a picture it says card error
Hi, try to format your SD Card on your camera (backup pictures first).
If you can't then try to format on your PC. To format on your pC do the following steps:
1) insert your SD card
2) right click the SD Card Drive (make sure you select the correct one) choosing the wrong
drive would cause BIG problems for you. If you don't know which drive it is Do Not Continue
3) Select Format.
If you PC doesn't format properly or has a problem with the card then you know the problem
is the card and not your camera. Make sure also that the SD Card is not Locked.
Feb 04, 2011 | Casio Exilim EX-Z57 Digital Camera
Purchased 8 gb microSDHC Card with adapter for my cannon SD500 & WHILE TRYING TO FORMAT memory card GET AN ERROR saying card locked. I've moved the slide tab to the UP position but continue to get card...
The SD500 uses SD cards (and by extension, microSD cards). SDHC and microSDHC cards are electronically incompatible. While SDHC cards and microSDHC adapters will fit into the slot, they will not work in SD devices. This is a hardware issue and cannot be updated by firmware. You need to go with SD (and microSD) cards, 2GB and smaller.
Nov 15, 2010 | Cameras
SD card locked
The lock switch on the SD card looks like a bit of plastic without any electronics. A bit like the write-protect tab on a 3.5" FDD.
So there must be a sensor in the reader / camera which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card, but you could try blowing out any possible dirt and see if that fixes the problem. Can the camera write to the SD card?
Try moving the switch to lock and unlock status.
Apr 07, 2010 | Canon PowerShot A75 Digital Camera
Locked SD card
There should be a switch on the left side of the adapter just reverse it.
Jan 19, 2009 | SanDisk 1GB microSD Memory Card
Unlock 1 GB micro sd memory card of Kingston Made
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
Jul 19, 2008 | Nokia N95 Cellular Phone
my memory card is locked .i use a nokia 3110c model. please give me the solution
Jul 15, 2008 | Nokia 3110 Cellular Phone
Locked card, that isnt locked.
Hi Try useing SDCARD FORMATTER V1.2 . This prog is put out by PANSONIC. i have used it to resuce quite a lotof sd cards.
Good Luck.
Douggie11
Apr 27, 2008 | HP Photosmart R727 Digital Camera
SD Card error 31
Hi Simon, what do you mean with 'update the SD-card'? I hope that SD card is not “locked”.
Sep 11, 2005 | Toshiba e400 Pocket PC
Polaroid i830 Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
