Question about Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L300 white screen while charge.Its working on Battery power absolutely fine.
When i put charging to my laptop getting white blank screen after some period of time (after 10 mins).But on battery its working fine..Please help me on this.
Geekman
  • 32281 Answers
SOURCE: "Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
It sounds like the power socket on the laptop is faulty and needs replacing or resoldering. To check this, power up the latop with the power adapter, wriggle the plug in the power socket and check if the battery charge indicator flicks on and off indicating charging and not charging. If it indicator flicks on and off then you have a faulty power socket.
This can be repaired but required the laptop to be completely dismantled to access the power connector.
Posted on Feb 18, 2009
  • 253 Answers
SOURCE: Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Posted on Mar 30, 2009
RescueTechLA
  • 2653 Answers
SOURCE: my toshiba satellite m305ds4831 laptop will not
It's a motherboard hardware issue in all likelihood.
There is NOTHING you can do but update the firmware bios. The problem is that most bios firmware update programs require both ac and battery power at the same time :(
You can try to do it anyways by visiting Toshiba's support page for your model and downloading the firmware from there.
It probably won't fix the problem but it's still worth a shot....sometimes it works ;)
Posted on Nov 21, 2009
SOURCE: Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Posted on Jul 04, 2010
SOURCE: Toshiba Satellite L305-S5907 won't charge battery.
Thanks to avatar8.jpgJesse Lohse .
My battery is charging now. As per your say to remove the battery and check to see if the prongs are dusty or if it is blocking the main connector or anything else. So, i removed the battery and checked and it was quite dusty so i removed the lint and dust from it. Now it's starting to charge. Now it's at 19%.....Thanks you're the genius
Posted on Mar 22, 2012
Satellite pro L300 screen is blank. Power light is on (green), battery light is yellow, HDD light is off.
Sounds like it's broke. Blank screen means it's broken, battery light is yellow I beleive it means time to replace the batteries.
Apr 16, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite l300 not charging, doesnt work on the power supply
Try removing the battery completely and running it with the power supply connected. If that doesn't work, try borrowing a compatible power supply, or buy a universal one, and try with and without the battery connected.
The problem may be the power supply, in which case the battery won't charge and the laptop won't get any power.
Apr 06, 2011 | Toshiba Satellite Pro L300 Notebook
I own a Toshiba Satellite L300 bought last April, working fine yesterday but today it won't turn on and when the power cord is in there are no lights. I tried using another power adapter (My Brother has...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 05, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite L300 freeze when adaptor plug in.
This is a middle pin issue, you will find the laptop doesn't charge either but will power the unit, if the power is connected, the laptop will hang and use reserve resources, if you unplug it, the machines performance will dramatically increase.
replace your power adaptor and all will be fine, i have had the same issue.
Sep 02, 2010 | Toshiba Satellite Pro L300 Notebook
When I turn on my Toshiba Satellite Pro L300 nothing happens. The power(DC) and battery indicator lights are both ON but the screen remain black and hardly any vibration to show any device booting
1. you may have a non functioning adapter and it is not charging the battery
2. You may have a defective battery that needs replacement.
3.To see if the battery is defective take it to a laptop service tech to check with a new battery and have him also check the power adapter.
Jan 06, 2010 | Toshiba Satellite Pro L300 Notebook
Compaq nx6325 laptop will not power up
Perhaps try taking the battery completely out of the laptop for 5-10 minutes and then replacing it and trying again. My Dell wouldn't work on battery alone but was fully charged and leaving the battery out for a while before replacing it worked for me. Also keep your eye on how much the battery charges. It may be a faulty AC adapter also. Best of luck.
Sep 24, 2007 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 Notebook Logo
480 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
