Question about Philips Magnavox 42MF521D/37 Television
My Magnavox flat TV 32MF301B/F7 power supply won't turn on
Where can I download a power supply circuit diagram?
  • 586 Answers
SOURCE: Plugged in my tv. It
first, make sure the Tv is correctly plugged into the wall. You can try another outlet. If that doesn't work, then your Tv is certainly having a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.......
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes).
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.......
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
Yours sincerely.
Elect_Comp.
Posted on May 14, 2011
  • 13 Answers
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Posted on Dec 26, 2008
  • 1156 Answers
SOURCE: Hi my philips flat tv won't turn on? The green
Power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
You can change the power board yourself , it very simple, but must taken to avoid high voltages in panel, please note
Posted on May 06, 2011
  • 96 Answers
SOURCE: My Magnavox flat penal TV just stopped working, i
What is the model number of your tv?
TeeVeeMan2@gmail.com
Posted on Sep 16, 2011
gopakumarg43
  • 74383 Answers
SOURCE: philips 42pfl3603d/f7 shut off on its own and
Check its main board. It is a skilled work. Seek tech support.
Posted on Jun 05, 2012
Want the circuit diagram for ps 5161 7d
you could get the circuit schematic drawing from this site.
DELL PS 5161 7DS POWER SUPPLY SCHEMATIC Service Manual free download...
After clicking on the link wait a few minutes and then scroll down the page to the Get Manual link.
Sep 23, 2014 | Computers & Internet
Need circuit diagram of power supply panasonic th-42px80b
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Power supply section schematics to many popular brand TVs are given.
Aug 05, 2014 | Televison & Video
Str f6707a circuit diagram (power on power led glow but power led off after 1 second)
LG may be able to supply a circuit diagram that will enable you to determine the cause of power supply failure.
Apr 29, 2014 | LG Televison & Video
Diagram sony kvSZ29M50
Circuit diagrams are in PDF, and cannot upload by this window. To get more details, http://electronicshelponline.blogspot.com/. Power supply section circuit diagrams of many brand TVs are given. Search with IC number used.
Nov 15, 2013 | Televison & Video
Need circuit diagram for pd2171 23590258B power supply
What is the main problem in the power supply...? if u need any part no, pl send us the mail with pic, we can send u the part no's.
Jan 23, 2013 | Toshiba 32WLT58 32 in. LCD Television
Wont turn on
Check its main power supply regulator circuit for any damaged components. Working with main power supply section circuit is fatal to any one, who have no experience in this kind of work. If you are confident; sound in electronics circuits and schematic diagrams, you can proceed after downloading the repair manual to this model set.
Aug 02, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Schematic diagram example of AC DC regulated power supply 1.5volt to 35volt
You will need to add transformer and rectifier diodes before this circuit to be able to get the voltage you need.
See the link below of the regulated part of the circuit
http://simpleelectronic.com/2010/06/11/simple-adjustable-regulated-power-supply-circuit-diagram/
If you need more help let me know.
Sep 29, 2011 | Computers & Internet
I am looking for a circuit diagram for a Boshert 3T20AP-6115 Power supply - 60v input , up to 15v O/P @ 20amp
You might try emailing the company to see if they have the diagrams, they may charge you for it. There are also sites on the internet that collect circuit diagrams, try doing a search for that model and the words circuit diagram to see if that might help. Almost all of those sites charge a fee for downloading the schematics.
Feb 28, 2010 | Computers & Internet
Circuit diagram
I'm afraid I cannot comply with your wishes, as there are copyright laws governing this, for one. (For existing circuitry)
Two, there is the liability issue. Take for example that I design the requested circuit, give it to you freely, and you or someone in your group is injured using my circuit.
Will state that this is a basic circuit design. I believe that if you 5 put your minds together, you can build this circuit.
Sep 14, 2009 | Powerline 200Watt DC to AC inverter...
Need a circuit diagram for ups
hello sir, i need a circit of ups and usb and other circuit.i am student of DAE in electroics this diagram need a project of DAE send me plz i shell be very thankful you.
Apr 02, 2008 | Powerware Invensys FERRUPS 1400VA...
Philips Magnavox 42MF521D/37 Television Logo
2,615 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
