Question about Ricoh Aficio 2238C Color Copier Printer
SC680 FUNCTIONAL PROBLEM WITH RICOH COPIER
Error with copier code SC680???how do i fix it?
spinal
  • 287 Answers
SOURCE: ricoh aficio mp 2510
Hello e3tech, faatmaan has given you some valuable and accurate information. I would like to offer you some additional information that may help. i am not sure to what degree you have technical experience regarding problems as deep as you are experiencing. I just want to try to help you starting with the basics. We can get the proton accelerator out as a last resort. :-) In the event you have not tried to reset the code (which you can in the event that this code was a temporary condition or erroneous to start with) let me walk you thru the process of resetting the code and lets see if the copier can recover without going into the ugly (but prehaps necessary) and expensive stuff. Again I am just trying to help and this is the first thing anyone should do. We need to enter service mode, usually accessed by the expensive on site technician but you can handle it. This is the first thing I would do if I was onsite. I have been working on copiers for 20 years, which may merely mean I have been on a reign of terroe for that long, screwing everything up! LOL .Ok in order to enter sevice mode on your machine you will need to press the yellow button marked "clear modes" then then numbers 1-0-7 in slow but firm sequence, and the the orange stop clear button and hold IT down tull the screen changes and you will hear a beep. Once again......Clear modes,then 1>0>7 (in sequence) then hold down the orange stop/clear button till the screen changes and you hear a beep. (note....the beep is not guaranteed as it can be turen off prior to what we are doing but you will see the screen change). the new screen may say a number of things but for sure it will have a block named copier. Press that block which will bring up another new screen with all kinds of stuff that you need not be concerned with.The fact that you are at this screen is the cool thing. At this point, turn the main power swith off....!!!!!! THE ONE NEXT TO YOUR LEFT KNEE!!!!!! not the one on the op panel. Unplugging the copier will do the same if you are unsure.The point is to totally de-energize the copier. Turn the copier back on, and this point it will know that some one who knows what they are doing it attempting to help it recover andthe copier will wake up witha new outlook on life and will try to successfully restart back to normal. Without the steps we just went through the copier would have not went through the servicr mode process required foe it to truly have a chance to recover. When you turn it back on, the copier will look at all the critical sub systems it monitors before it feels comfortable to say "READY". In this case the errer code has to do with the very high temperature area called the fuser. As you probably understand, the manufacturer of the copier has designed the copier to keep close tabs on this area as to not burn down your building. So id there is any oddity in this area the machine throws a temper tantrum. So, lets hope hope the machine restarts, and it was a temporary thing , and you wont have to go the route that faatmaan suggested, which again may be absolutely accurate and well detailed. I just thought we could try the reset and hope for the best as it is a genuine and viable option and alot less expensive. I wish you the best. By the way, in the future, ALL error codes you get in the future(and there..are a hell of alot of them) can be reset in the manner I described ealier.This can be a big help for you . It just so happens that this and a few others in the "500" series are less likely to stay reset. I hope I have helped save you alarge wad of cash, but a minimum you are armed with a few valuable tools that may save you buttocks in the future. Take care.................. SPINAL
Posted on Feb 19, 2008
SOURCE: Error code E5 41 on Ricoh copier model 4527, or FT 4527
It is a fuser error (low warm up temp), often caused by fluctuating voltage.You have a blown fuse, lamp, or thermistor. Can only be reset in service mode after the problem is solved.
Posted on Mar 12, 2009
SOURCE: I have a Ricoh AFICIO
• Fusing thermistor defective
• Poor connection of the fusing unit
Inspect the parts mentioned later:
Enter SP 5-810 (SC code reset) and select “1”. Then hold
down the Photo mode key and the ! key at the same time for
at least 3 seconds (this does not require the main switch to
be turned off and on).
If the problem persists:
• Power supply board defective. Can have defective soldered.
Posted on Sep 02, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
Toner reset
SC680 is a communication error, usually relating to the chip on the toner cartridge. Check that it is clean and that the electical connection is properly made when the cartridge is in place. It can result from a wiring error, but that is much less likely, and a failure of the BCU board - even less likely. Hope that helps.
Jan 17, 2014 | Ricoh Office Equipment & Supplies
I have a ricoh 1232C multifunction and it has just stopped working and gives an error code sc440 " Functional Problem with the copier "
The problem is Main motor error.
The problem can be two diffrent things.
1. Defective main motor
2. Too much load of the main motor drive
Oct 18, 2010 | Ricoh Aficio 1232C Color Copier
I still need help on how to solve or fix my Ricoh Aficio 2022 b/w copier functional problem error code sc545.the error code doesnt allow the copier to operate any time you turn it on. thank you
You can check the following.
1. hot roller thermistor is out of position or dirty.
2. Fuser lamp is broken.
3. Thermostat is open. (Like a thermal fuse, there SHOULD be continuity)
4. Clean and scrap clean the gold pins that connect into the copier. Sometimes they get corroded or bent slightly out of shape so they don't make contact with the terminals.
Aug 03, 2009 | Ricoh Aficio 2022 Black and White Copier
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
Aug 03, 2009 | Ricoh Aficio AP410N Laser Printer
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Am having ricoh 1013 photocopier, and its giving an error message that "functional error,switch off mainpower and on"!
Low fusing temperature. Either the thermistor is bad or power supply board (unlikely). Service code can only be reset in service mode by a technician after problem is fixed
Mar 24, 2009 | Ricoh Aficio 1013F Copier
Ricoh Aficio 2238C Color Copier Printer Logo
53 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
