Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Error code F71 f71 error code comes up. What does it mean? I'm not sure when it happens during cycle.
  • 3 Answers
It seems the only solution any one has is to pull the plug. If this doesn't solve problem replace board. Seems to me if so many people have this same problem with fairly new washers its a design flaw and should be addressed by whirlpool. $600 for a new board seems outrageous for a new washer.
Posted on Jan 20, 2009
MHWE3000VW error codes F70 & F71
The F70 and F71 codes both refer to a communication error between the main control board and the motor control board.
The problem could be a simple loose wire or a cut in the wiring.
It could be as bad as a failed control board.
Unplug the washer and remove the top panel by taking the screws out of the back side of the top panel.
The top panel will push backwards and then lift up.
This will give you access to the main control board and the wiring to it. Make sure all connections are tight and secure. Inspect the wiring and make sure there are no breaks.
You will also need to remove the kick panel that is below the door on the front.
This will give you access to the motor area. Make sure the plug on the motor is tight and secure. It will also help if you unplug the motor and then plug it back in to make sure the contacts are good.
After verifying that everything is good and tight try the washer out. If the codes come back then you will need to replace the main control board on the washer.
Read more: http://www.justanswer.com/appliance/4xj01-does-f70-f71-error-code-mean-kenmore-elite.html#ixzz3aEn5aNnn
Read more: http://www.justanswer.com/appliance/4xj01-does-f70-f71-error-code-mean-kenmore-elite.html#ixzz3aEmtZDnP found this helpful answer from an appliance technician on JustAnswer com found this helpful answer from an appliance technician on JustAnswer com
May 15, 2015 | Washing Machines
Kenmore Elite HE 3t steam washing machine shows a code of F71
The F71 error code means "User interface heartbeat failure" to put that in simple terms what it means is,the touchpad/cycle selector is not talking to the main control board. To check to see why that code is being displayed ya would need to make sure that all the wire plugs between the selector and the control board are tight and in fully pressed in and making good contact at the respective connection point on the circuit board.
If ya find the wire connections to be good and tight,ya would need to start the washer and if the drum rotates the cycle selector would have to be replaced. If the drum does not rotate the main control board would need to be replaced. oldtech2332_146.jpg
Oct 20, 2011 | Kenmore Elite 45986 Front Load Washer
What do the following codes mean: F70 and F71. My washer is a Kenmore Elite HE5t. Thank you
The F70&F71 mean basically the same thing
F70 means the main control board is not communicating with the cycle selector/touch pad control
F71 means the cycle selector/touch pad controlis not communicating with the main control board
What needs to be checked is the wires between the main control(CCU) and the selector(user interface) for good tight connections
If all connections are good and tight the CCU has to be replaced IF the drum will rotate under power from the motor
OR if the drum will NOT rotate under power of the motor the USER INTERFACE needs to be replaced
Gene
Aug 18, 2011 | Kenmore Washing Machines
Troubleshoot washer code reads F71 no displays
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Jan 03, 2011 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My washer is not operating properly. please tell me what code F71 means and how to fix the problem. Thank you.
Regards.
Dec 11, 2010 | Kenmore 47081 Front Load Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
What does F71 mean ? This comes up half way through the cycle
Regards.
Oct 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code shows F71. door is locked and there are clothes in there soaking in water that I need to get out!! what does F71 mean and how do if solve the problem
Hi.
Sorry for the late reply.
If you get similar problems in the future, and machine gets stuck in error mode with clothes inside, empty water from tub disconnecting the drain filter, located behind a panel in front lower side of appliance. After emptying water the door will normally get opened.
Regards.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
154 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
