Question about Gauges for Ford E250
Temperature and oil pressure gauges not working
All other gauges and all warning lights work. Temp and op gauges register nothing. Oil level is fine. Engine warms up and heater works fine.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ford Master
  • 1,449 Answers
Check the sensors .take off the wires one at a time clean them check for breakes in the wiring.
Posted on Dec 02, 2013
Oil pressure gauge on 2007 mitsubishi shogun sport not working but no oil warning light. Anyone had similar issues?
As a first step you should have the pressure gauge sender unit replaced which has most likely failed prematurely. It is not an expensive part but the OP gauge will not work without it functioning.
If the gauge then shows no pressure I would also have a mechanic check the oil pressure on the vehicle with an independent gauge.
Nov 30, 2015 | Mitsubishi Cars & Trucks
Signs bad temp sensor
Bad oil pressure sensor, oil pump, balancer-shaft bearings..
Which grade of oil did you use? Did you try to check the pressure with an oil-pressure gauge?
Sep 14, 2017 | Saab Cars & Trucks
2006 f150- temperature gauge stays cold but "check gauges" flashes in mini message center.
Since the temp gauge is not working correctly, you get the warning message.
Could be a faulty temp sensor or a problem in the wiring harness.
Apr 08, 2013 | 2006 Ford F-150
Oil light on 2006 Chevy Aveo but oil levels are fine
The oil warning light is for oil pressure, not the oil level in the engine.
Your owner's manual will explain it in detail.
You need to have the oil pressure checked with a mechanical gauge or replace the oil pressure sending unit to see if it is faulty.
Oct 05, 2012 | 2006 Chevrolet Aveo Hatch
Gauges work fine when engine's started, then oil gauge falls below zero and warning light comes on saying "Check gauges," so I check the oil and transmission fluid levels and these are fine but...
start by checking the ground strap to the engine, and engine to body. The oil pressure sender unit may be bad. You may have to hook up an oil pressure gauge to the oil pressure sender port to verify proper oil pressure. Senders are cheap- I would just replace it and go from there.
Jan 07, 2011 | 2001 Dodge Ram 2500 Truck
2000 Ford F-150. The oil temp warning light came on and the oil pressure gauge dropped to zero. While accelerating, the pressure gauge goes back to normal and the warning light goes out. No drivability...
Make sure the oil level is correct. If the engine bearings are getting worn, the oil pump is worn or it's screen plugged, that can cause low-RPM weak oil pressure. Try running with 'high mileage' oil at your next oil change and always replace the filter. At some point, you may need to consider overhauling or replacing the engine. Good luck!
Jun 06, 2010 | 2000 Ford F150 Flareside SuperCab
Oil light flickers when in idle. Oil on dip stick measures fine.
install a mechanical guage to test the actual pressure, if its fine the sending unit is faulty, if nor remove the oil pan and check the oil pickup for blockage,
May 24, 2010 | 1999 Chrysler Concorde
Why won't the oil and temperature gauge work on
you should switch the temperature sensor and oil pressure sensor you had on your first engine,because your new engine must come with the light indicator dashboard so the sensor of your new engine are not compatible with your gauges....lipak!...
May 05, 2010 | 1988 Ford Ranger
Gauges for Ford E250 Logo
61 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
