Can you recommend the best way to troubleshoot what the exact problem is? How can I test the door latch motor? Can I measure the voltage to see if it is getting power? How much should it read?
Thanks.
Thanks.
I want to start the self-cleaning but the the door is not locking. It keeps blinking "door" and beeping. How do I fix it? I want to start the self-cleaning but the the door is not locking. It keeps blinking "door" and beeping. How do I fix it?
You can't post conmments that contain an email address.
The hi limit thermostat probably tripped during self clean. It can be manually reset. Turn off the power and remove the grill under the control panel. There is a two wire switch behind the door latch press in the red button on the switch. Reassemble and turn on the power. If it works you can reset the cooling fan to run longer which could cure your problem. Press and release upper broil button, press and release the up arrow, then hold down the broil button until it reads COOL 000. Press the up arrow until it reads COOL 200. Press cancel. Done.
I have had the same problem for ten years. After a few years of the tech coming out everytime
I self cleaned, I had him show me how to reset, and he also gave me a new reset gizmo in
case that doesn't work. As for resetting, the top plate on top needs to come off and then you'll
see the gizmo with a dark red reset button that is attatched to the floor of that top compartment, which I leave unattatched for easier access. Push button down, of course turn off the electrical power to oven before doing all this. Works everytime.
You should have a function switch that says " self clean ". Normally, all you have to do is turn the control on to "self clean" and let the oven do the rest. It will take about 3 hours or so to complete the cycle.
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
15 problem 8. door will not open. 9. oven will not heat after Self cleaning. possible Cause oven is in Self-clean mode. time of day is not set due to power failure. oven settings are not correct. remedy if oven is hot, door latch will release automatically when oven temperature falls below 390˚F at end of cycle. if Self-clean was just selected and the oven is still cool, press “caNceL•SecuRe” to turn off Selfclean. the door will open in about 30 seconds. Press “cLock” touch pad, then press “tiMe•teMP” pad to set correct time of day. follow mode selection and clock settings as specified in the oveN oPeRatioN section. oven will turn on automatically at preset time. if desired, press “caNceL•SecuRe” touch pad to cancel out of delay timed mode. Troubleshooting Guide (Continued) Important: If a Failure Code is displayed, the oven will beep continuously until the user presses the “CanCel•seCure” button. the oven will not heat after a failure. Call a qualified appliance technician to repair the oven. Oven Failure Codes Clock Display Cause f0. touch pad is stuck in depressed position. f1. Relay circuit failure. f . oven temperature exceeded the clean runaway temperature (Self-clean mode only) or the cooking runaway temperature (cooking modes only). f3. Short circuit in the oven temperature sensor. f4. open circuit in the oven temperature sensor. f6. failure in the eePRoM check comparison. (only time of day and timer will operate.) f7 failure of the Self-clean automatic door latch circuit. f8. failure of the door latch motor. occurs when the motor runs for two minutes without the door locking in Self-clean mode. befOre yOU Call fOr servICe No maintenance, other than the Care anD CleanInG InstruCtIons identified in this use & Care manual, should be attempted by the owner/operator. all other maintenance and service must be performed by a qualified appliance technician. first, review the recommended checks listed in the preceding troubleshooting Guide. then, be certain that the appliance has been installed properly and is being operated correctly. familiarize yourself with the warranty terms and conditions listed in the proDuCt WarrantY section. if the above checks have been completed and the problem has not yet been remedied, call your local authorized dacoR® service representative. your dealer can normally provide the name and telephone number of the nearest service company. prOdUCT maInTenanCe If yOU need servICe... dacoR® works diligently to ensure your satisfaction when service is necessary. However, if you are not completely satisfied with the service provided, contact the company that performed the service and express why you are not pleased. Normally, they will be willing and able to resolve the problem. if the service agency is not able to respond effectively, call or write the dacoR® customer Service department. the phone number and address of this department are listed on the inside front cover of this manual. Please include your telephone number if you choose to write. we will then do our utmost to assure your happiness and satisfaction. Here is a snipet from www.dacor.com You can view the manual there by enter ing your oven model number.
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Thanks.
