Question about Lenovo 3000 Y410 Laptop
Laptop lenovo 4152 38q
While typing email, my letter jumps erratically from one line to other where my cursor is. i am sure touchpad configuration has to be made right..please help
    President:
  • 2,559 Answers
Here is a link to all your drivers.
Posted on Jan 19, 2009
  • 2,229 Answers
Your touchpad is very sensitive. Be sure to keep your fingers away from it when typing. I have the same problem with my Toshiba laptop--I decided that unless I was in a travelling situation, I would use a small wireless mouse. I just disabled the touchpad.
  • manjaly Jun 28, 2011
    I had this problem for ever. After a lot of frustration and research, what I found was, this is common error for all kinds of Windows laptops that have a touchpad.
    I found a work around, which was to install a utility called "touchfreeze" from Google code. This utility will lock down the cursor while typing and so will avoid the jumping around problem. This is a small utility that sits in the system tray and does not create any overload for the laptop and it does the job well.
    See this article for more details about the cursor jumping problem and the solution:http://www.mywindowsclub.com/resources/4...
  • Art Ellison
    Art Ellison Jun 28, 2011
    Great tip! Thanks.
The cursur jumps all over the place when I type in lenovo e530
Make sure you disable or turn off the touchpad when you are typing. You are accidentally hitting the touchpad when typin that causes your cursor to be erratic. I suggest to plug in a mouse and disable the touchpad.
Oct 16, 2014 | Lenovo ThinkPad Edge E530 325978U 15.6"...
How do i fix keystrokes that jump backward as I type?
Some Lenovo touchpads are over sensitive and they cause the cusor to slip or jump around. In Control Panel select Mouse or Touchpad. A box will open and you can locate touchpad Properties and adjust the sensitivity. Lenovo also has updated touchpad software/drivers for one or two of the most troublesome models. i was able to reduce the cursor jumping around quite a bit by adjusting the sensitivity, but i still don't think it's a good design.
Aug 12, 2014 | Lenovo Computers & Internet
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
Runaway touchpad on HP laptop.
I have the same problem. An external mouse does not behave erratically. If the touchpad is wearing out, will a replacement touchpad solve the problem, or does the circuit board need replacing?
Mar 31, 2012 | HP Computers & Internet
I am loking for touchpad drivers of Lenovo laptop Model- 3000 G430
Hi appoddar1988,
I see you need drivers for your Lenovo G430.
what type of drivers do you need? you mentioned that you need touchpad Drivers, what issue are you experiencing with you Touchpad?
You can get the drivers from this link .
But if you are experiencing Jumping cursor issue then you do not need to reinstall your touchpad drivers you try installing touch freeze on your system this actually helps with the jumping cursor issues in th Lenovo G series Laptop.
Just google Touch Freeze you should see links where you can download Touch freeze for free.
I hope this helps.
Have a nice day,
mvincentc
Jun 15, 2011 | Lenovo 3000 G430 Laptop Charger...
Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
Jul 01, 2010 | Lenovo 3000 Y410 Laptop
Cursor on lenovo R61i jumps around for no reason in word, and emails
control panel, mouse, touchpad tab, there should either be an option to ENABLE PALMCHECK or to DISABLE Touchpad while typing.
Dec 20, 2009 | Lenovo 3000 Y410 Notebook
When I am typing he cursor jumps around
It is a fault with Lenovo laptops. My cursor jumps all the time, no matter what software I am using. It is NOT the 'sensitivity' of the touchpad, for my cursor jumps even when I am not typing, even if I don't touch the laptop! I can set the cursor to a certain point on a document and then, after about 30 seconds, it will just jump to another point, even if I am in another room.
Sep 24, 2009 | Lenovo 3000 Y410 Laptop
Cursor(pointer) cannot be moved by using touchpad but possibe wit
This happens to me also. Check whether the touchpad is enabled (laptops do have an option of enabling / disabling the touchpad). Secondly, you can try reinstalling the touchpad driver. Uninstall and then re-install the driver. Re-boot the system. Try using the touchpad.
Hope this helps., if so, rate me.. thanks - billa
Dec 20, 2008 | Lenovo Thinkpad R61i Notebook PC
Cursor jumps erratically
Most likely, your wrist is gently touching the touchpad, and your computer is interpreting it as a 'tap,' and it so happens your cursor was located several lines up.
Or if you use a separate mouse, is it on a wood or uneven surface? This will cause it to jump up those few lines and again, your wrist (or if you have big hands like I do, the bottom of your thumbs) will tap it.
Apr 02, 2008 | Dell Inspiron 6000 Notebook
Lenovo 3000 Y410 Laptop Logo
234 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
