Question about Canon imageRUNNER 400S Copier
Canon GP 405 error code E 014 - Canon imageRUNNER 400S Copier
  • 3 Answers
• The rotation of the main
motor does not stabilize 1
sec after it has started.
• While the fixing motor is
rotating at a constant speed,
its revolution has deviated
from a specific value by 1
sec or more.
Posted on Jan 30, 2013
SOURCE: ERORR E677 ,CANON GP 405 DRIVER SETUP PRINTER
printer not ready
Posted on Aug 31, 2010
SOURCE: CANON GP 405 ERROR E 051
hi
horizontal registration home problem sensor(ps14),motor,dc controller
Posted on May 04, 2009
SOURCE: Error code 005 for canon GP 335 CONTINUES TO APPEAR
press additional function button once and press 2,8 buttons at a time & press additional function button again & execute the following
select <copier> <counter> <misc> <fix web> then press clear button on the display.
automatically the web counter will be zero , the proble also cleared.
Posted on Jan 27, 2009
SOURCE: Cannon GP 405 error code E100, E301, E220
Sir My machine Cannon GP 405 showing code E100. please suggest what can i do to resolve this problem
Posted on Sep 13, 2010
  • 452 Answers
SOURCE: CODE e001 pour cannon GP
E001: probleme au niveau de l'unite de fixation
  1. •Thermistance court-circuitée.
  2. •Carte d'alimentation C.A./S.S.R. défectueuse.
  3. mauvais contact au connecteur
.n'oublie pas de voter Svp
Posted on Dec 06, 2010
Canon 405 error code e805
http://www.copytechnet.com/forums/canon/9744-canon-gp-405-error-e805.html
Quoting:
  1. Canon GP 405 error E805
    E805 (The fan rotation is faulty.)
    If no detail code is indicated,
    suspect the feeder fan (FM1) or the
    reversing guide cooling fan (FM9).
    Is the connection of these fans
    normal? Is the drive signal of the fan
    identified in the previous step about
    22 VDC while the fan is rotating orabout 12 VDC otherwise?
  2. 05-14-2008 #3 songela Senior Tech 100+ Posts
    Join Date Mar 2008 Location dar es salaam
    That is one side with the fans,
    Secondly, if the fans are found right, then for sure you need to change the DC Controller.
    Regards!
  3. 08-02-2013 #4 mehta Junior Member Re: Canon GP 405 error E805
    Originally Posted by logimix
    Could somebody tells me... what this error (E805 - Canon GP 405) is... and how to resolve it? thanks a lot. john pl check detail code after 805 .Fan related fault. Also power supply(composite)
Apr 29, 2018 | Canon Office Equipment & Supplies
Canon gp 335 erorr code e805 what is the problem
Canon GP 405 error E805 E805 (The fan rotation is faulty.)
suspect is feeder fan (FM1) or reversing guide cooling fan (FM9).
try Check
Mar 25, 2012 | Office Equipment & Supplies
My Canon copier, gp 405, Shows the error code : E 604. What is the problem ? How can I Solve it ?
Hi
This is an error on your Copiers memory,hard drive or the main controller board.Any of this may need changing.Have it checked.
Mar 02, 2012 | Canon imageRUNNER 400S Copier
Error code e220 for canon gp 405
That is a scan lamp error on all Canons that I know of. Check continuity on the lamp. Then check the in line fuse. It could also have a shorted scan cable.
Nov 09, 2009 | Canon GP-200 All-In-One Printer
What's the solution to fix the error code E014 for canon gp 405
Check whether the fixing roller is tight. If yes check why?
Nov 06, 2009 | Canon imageRUNNER 400S Copier
My machine gave me an error E051 and it could not start. when i restarted, it still ended at that.
i decided to switch it off and wait for the technician to come and fix it.
the next morning i arrived before the technician came and when i switched on, it was very fine.
what could have happened.
Tonny Obwin Telecommunications engineer.
May 02, 2009 | Canon imageRUNNER 400S Copier
E805
J'ai un problème e805 photocopie canon gp 405
Quelle est la solution de détails, s'il vous plaît
Aug 24, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
113 people viewed this question
old marine
old marine
