Question about Honeywell Thermostat Pro 4000 Programmable Th4110d1007
Can you change the temperature differential on a honeywell th4110d1007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 45 Answers
Am I able to adjust the 'hysteresis' of my digital thermostat?
Some thermostats allow you to change the differential value - that is how far below the heating (or above the cooling) set point before calling for heat (or cooling in the case of air conditioning). The built in 1 degree differential setting provides the most even temperature in the space at the expense of more frequent furnace firing and stopping. Many people prefer this mode as opposed to allowing wider swings in temperature for less frequent furnace firing and stopping. If you wish to change this setting, you'll need to replace the thermostat as it is not user adjustable in this model.
Nov 02, 2015 | Honeywell RTH6350D1000 5/2Day Prog...
What is the other slider button used for? How do I set the differential +/-
Setting thermostat differential to 3 degrees? - HVAC-Talk
hvac-talk.com/vbb/showthread.php?...Setting-thermostat-differential-to...
Dec 27, 2006 - 12 posts - ‎5 authors We set both the differentials on the thermostat to 3 degrees. ... very low, but I doadmit to changing the differentials to 1 degree on the thermostat ... How does an adjustable temperature differential work?
Apr 5, 2011
Honeywell Thermostat TH8000 Series
Jun 27, 2009
Honeywell Thermostat Cycle Time
Feb 3, 2005
More results from hvac-talk.com
Oct 16, 2015 | Heating & Cooling
I have a baseboard heater controlled by a Honeywell YCT410B1000 thermo that only clicks on when turned past 17.5C... How can i adjust it to click on at a lower temp.?
In the setup the temperature differential is adjustable somewhat, 2-3 degrees.
www.honeywell.com
1-800-honeywell.com
Dec 13, 2013 | Heating & Cooling
We had a Honey Thermostat model # TH4110D1007 installed in our house, our technician did not leave an instruction manual with it and we don't know how to run it, can we get a website to download a...
yes just go to honeywell site. The address is inside the thermostat. Just pull the front part of the thermostat off and read the lable inside. Hope this helps.
Sep 06, 2011 | Honeywell Heating & Cooling
We have a fairly new furnace. I have the temp set at 65 the furnace only runs for 3 min at a time and comes on every 5 min. This sounds extreme to me?
It depends on the differential that you have programmed into the thermostat. In most of them you can set the temperature you want the thermostat to activate, and then you set the run differential such as three degrees below 65. In other words, the thermostat will activate at 62, and drive the temperature up to 65, cut off and wait for the temperature to drop to 62, where it cuts on again. see:
http://yourhome.honeywell.com/home/Products/Thermostats/
Check http://homeappliance.manualsonline.com/manuals/mfg/honeywell/8000.html to see if you can find the manual if you have lost yours.
Dec 07, 2010 | Honeywell Heat/Cool Thermostat
I can not set the temprature differantial of my honeywell beutler thermostas
well back when i worked on honeywell controllers, you don't set differentials on thermostat you set the temperature and it has its own differentials like + or - 1 or 2 degrees to the set temperature they don't let you play with this setting, you set your temperature and it will maintain around that temperature you shouldn't need to change the differentials around that temperature as controller does what the heater needs to get to the temperature you require setting the differential closer to set temperature will make the unit cycle a lot more and coast you more and having it to far away can let the conditioned area start to get back out of comfortable range so they set these in factory and you shouldn't be able to change them as they are set to how it should work to wrok properly so i wouldn't change them even if you could!
Nov 25, 2010 | Honeywell Programmable Thermostat Heater
I JUST INSTALLED HONEYWELL TH6110D1021 THERMOSTAT FOR A STEAM ZONE VALVE. I SET THE THERMOSTAT FUNCTION BY PRESSING THE UP ARROW AND FAN BUTTON. THEN CHANGING THE RIGHT NUMBER TO 2. NOW I WANT TO CHANGE...
Hi and welcome to FixYa. I am Kelly.
Suprizingly enough there is an abundance of manuals for your Honeywell Programmable Thermostat. Use this link and at the bottom of the page you can download any of the manuals.
http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1021
Just note that pop ups must be enabled to download the manuals
Printable Quick Reference Sheet (after download)
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1778ES.pdf
Thanks for choosing FixYa,
Kellly
Oct 15, 2010 | Honeywell Programmable Thermostat Heater
Switching thermostat from farenheit to celsius
My thermostat was set on celsius and couldn't get it to change back to fahrenheit. My son suggested pressing both up and down arrow buttons at the same time and it worked. It changed back to fahrenheit.
Feb 16, 2008 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat Pro 4000 Programmable Th4110d1007 Logo
309 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
