Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Maybe motor when you plug in the the opener the motor acts like it is stuck turning one way...i have tried ajusting the limit switches and it is hung in that one way any ideas....
  • ioldman46 Jan 20, 2009
    motor hums when I try to operate door opener. lights flash and motor hums like it is stuck in one direction
    Champion:
  • 244 Answers
How old. what model. if old, gears may be stripped. take off cover and watch limit switches. are they moving; contacts ok ; wires connected.
Posted on Jan 19, 2009
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
Shark navigator will not turn on
Plugged in:
Try moving the cord around at the strain relief, where cord enters the vac, as internal wires may have broken.
Unplugged:
Check brushes of electric motor, they may be worn down.
Unplugged:
Check main switch continuity with a meter on ohms or buzzer.
Limits:
No.
But there could be a thermal fuse either in or on the motor, to avoid overheating damage and smoke signals!
Nov 20, 2017 | Euro-Pro NV22 Shark Navigator Bagless...
I have a GPX D200B DVD Player and cant get the Disk Tray to open.
unplugged the dvd player and then re plugged, power on then press the eject button. if still the loading tray won't open, at this time you will need to remove the cover of the player to access the loading tray mechanical assembly. then check for an stuck up or broken rail plastic loading assembly it was installed drive by the loading motor.if ok, check the limit switch might not get contact which the processor not turn on the supply for the motor.
Nov 15, 2012 | Televison & Video
I have a liftmaster garage door that doesn't work. When I hit the button it clicks and the motor spins maybe two turns. All my safety sensors are lit. I know this isn't the problem. However after further...
YOU COULD TRY
RECONNECT THE RPM SENSOR, UNPLUG THE UNIT. TURN THE MOTOR BY HAND (DOWN DIRRECTION) TO CLEAR THE LIMIT SWITCH.
PLUG THE UNIT IN IF. IT STILL OVERSHOOTS THE LIMIT IT COULD BE A BAD LIMIT SWITCH. IF THE SWITCH TESTS GOOD FOR CONTINUITY REPLACE THE BOARD.
HOPE THIS HELPS
Jun 03, 2010 | liftmaster Chamberlain Garage Door Opener...
I get 4 blinks it say open limit switch what does that mean
Your induce fan motor senor is out. The little fan motor that take out the heat has a sensor that tells the furnace thats its working. Some time it get stuck. Try blowing and sucking into the tube. you should hear a click
www.fastacservice.com
Oct 16, 2009 | Goodman GMS90703BXA Heater
I have a grandview elegant electric projection screen and when I retract it, it stops about a foot below the case and won't retract entirely into the casing. Help please.
Electric screens are just about the same as a garage door opener. They have a up and down limit setting. Usually screens will have the motor on the left as you look at the sceen, this is where the limit switch ajustment screws are. If they are labeled great, if not hopefully they are obvious to see on the motor or roller. Hope this helps.
Aug 05, 2009 | GrandView Elegant Electric Plug-In Screen...
99 malibu sunroof stuck open.
The motor is in the front area of the roof unit.If you can drop the switch and trim around the front of sunroof unit and headliner ,you can can access the sunroof drive motor.The drive shaft of the motor can be turned mannually with an allen wrench which will assist in closing and identifying the problem area.If its hung very badly ...remove the sunroof motor then push the roof closed.
Jul 09, 2009 | 1999 Chevrolet Malibu
The seat belt gets stuck and makes a loud and distracting noise
The system can be operated manually by removing round cover cap on the B pillar (Just behind door). manually turn crank knob on top of motor.
There is a limit switch on the A pillar to turn off the motor for forward movement. There is a limit switch on the B pillar to shut off the motor for rearward movement.
You may need a B pillar limit switch if the belt is going all the way back but not shutting off. Unfortunately the rear limit switch is serviced with the track & motor assembly. Get a used one at car-part.com. Page with * is cheapest part.
You need to remove A pillar trim, B pillar lower trim, B pillar upper trim, and front door opening upper trim.
disconnect front limit switch
disconnect rear limit switch
disconnect motor electrical connector
remove 3 motor bolts
remove 2 limit switch bracket bolts
remove screw at A pillar near limit switch
remove 3 screws at track assy to roof.
pull back carpet & remove 4 screws at floor where you step into car.
remove track & motor assy.
Apr 10, 2009 | 1993 Mercury Villager
Trasmission seems stuck in park
Did you chk. to see if you got an ajustment on cable, wear it hooks to trans. or maybe cable came out of bracket that holds it.
Feb 08, 2009 | 1994 Buick Century
I have a Ruud Acheiver 90, I'm having some problems, the rollout (burner) limit switches are opening, and there is an electrical burning smell. It seems that sometimes the squirrel cage isn't kicking on,...
Thanks for your question,
yup your fan motor is bad, if you need to manually start it each time then the motor winding are bad and it is not getting the air across the coils, which in turn are over heating, thus causing a burning smell, and then tripping your limits, you need to replace this motor ASAP, before it does cause a fire, if the limits ever fail !! I hope this was helpful for ya, if it was please give this a rating, thanks again,
mr.grzz
Jan 23, 2009 | Heating & Cooling
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
