Question about PDP PS3 - Bluetooth - Afterglow AP.3 Communicator PDP
Afterglow Headset won't turn on.
A few days after I got my headset I went to charge it, everything was fine I continued using it that night after it fully charged. However the next day, it would not turn on. I still haven't gotten it to turn on, it will still charge though. I don't know what the problem is, nonetheless how to fix it, please help. Thanks.
    Prodigy:
    An expert who has answered 500 questions.
  • PDP Expert
  • 537 Answers
The battery is shot. These aftermarkets sit on the shelves for a long time, probably because they aren't made very well, and tend to break not long after purchase.
Posted on Nov 06, 2013
  • David Kuhns
    David Kuhns Dec 10, 2013
    I have the same problem on my computer it was working fine, but then it shut off. I thought it was dead so I put it on the charger, later I tried to use it again and it still did'nt turn on. I just got it 2 days ago!
Hi mine show fully charged drilled 1 6mm hole and went flat yet sometimes is ok
Try fully discharging the battery first and let it sit for a few days. Then fully recharge before use. What happens with battery operated drills is the batteries develop what is called memory of the charge level when they are recharged and will not charge past that point but the charge light will show full charge. It happens when the drill is used for a period of time and then the battery is placed in the charger ready for next time instead of using the drill until it is flat or leaving a partially used drill on the bench and not recharging it until it is flat
Jun 25, 2013 | Milwaukee Tool V18 Battery
I used the mute feature on my new headset and after 20 min it discontinued the call. Now the headset will not connect to the lifter. I tried resetting and it still will not connect
Sometimes just unplugging the power adapter on the base of the CS70N and letting the power drain out will help. If you can leave the unit unplugged over night that's even better. Plug it back in the next day and let your headset charge up for a few hours. Then try repairing headset to base. I have included Headsets Directs link for pairing headset to base below.
Plantronics CS70 Pairing Instructions
Good luck from Headsets Direct!
Jul 12, 2011 | Plantronics CS70 Wireless Headset
I have an htc ozone, what is the proper way to charge it for maximum battery life? seems to drain out shortly after an all night full charge. Thanks.
I just got my Ozone a few days ago. What you should always do with an electronic device is charge it fully before turning it on. Then using it until it dies completely with no battery. Then fully charge it again for maximum battery life.
You can go to Start, Settings, More, Power, Power Management. Change the different things to make it save on power. Also a big help is Start, System tools, Task Manager and delete everything that is being used. That just turns it off in the background, it doesn't delete the program.
Aug 31, 2009 | HTC Touch P3450 Smartphone
Plantronics Pulsar 590A headset won't charge anymore.
I too have the same problem as jessehaye154, does anybody know of a solution?
Apr 10, 2009 | Plantronics Pulsar 590A Wireless Headset
Motorola h700c
Hold the mutifunction button with the mouth piece close, until it turn purple, then open the mouth piece so that it will stay in the pairing mode. Now go ahead and have your phone or blackberry search for H700c
Good luck
Dec 13, 2007 | Motorola Mobility Bluetooth...
Battery
A fully charged battery should last up to 4 hours if it's being used A LOT! But I lost mine and it was in standby mode for pretty close to 3 days and when I found it I was still able to use for quite awhile before charging it again.. So yes, it sounds like it had a weak battery..
Oct 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Connected then Disconnected!!!
that could mean your headset is not charging. make sure the light is doing what it is supposed to when charging. you probably have a defective charger. happened to me. you could try pairing it with another phone to see how long it lasts. I found the Moto HS850 to be the only good, reliable one.
Jul 09, 2007 | Motorola Mobility H500 Wireless Headset
My phone can't connect to the headset!!!
I don't know if it is the same case as mine, but my H700 does not connect or work at all after a few days of non use. Battery discharges completely. It is odd but if I connect it to charger - it is lit red and starts charging again... So try to charge your H700 fully, then after a few days try to connect (knowing you gave it a full charge a few days ago)and see if will work. If not - connect to a charger. If light goes red - you got a battery problem just as me. Hope it helps at least a little bit.
May 04, 2007 | Motorola Mobility H700 Wireless Headset
PDP PS3 - Bluetooth - Afterglow AP.3 Communicator PDP Logo
1,735 people viewed this question
Top PDP Video Game Consoles & Games Experts
James Wishart
Are you a PDP Video Game Console and Game Expert? Answer questions, earn points and help others
