Canon Pixma 5100, no black ink, but blue won't print? why?
Trying to get my printer to print some notes for travel, ran out of black ink, need to print ASAP, changed to blue, purple and red, but it just won't print regardless that it has those colours in bulk.. why?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Main Cartridge is black it is required for printing it is not possible to print black with other cartridge.
Posted on Jan 02, 2013
  • bannistr
    bannistr Jan 03, 2013
    Of course I can't print black, I have no black. I'm not printing black, I'm printing blue, red or purple. but the Print won't print. I have secondary black 526, but I have no idea why that does not work, is there a hack to force my printer to do what every printer in the world does? or should I sue Canon for false and faulty products?
3 Suggested Answers
  • 8 Answers
SOURCE: canon pixma MP540 printer: unable to print black
Have you checked the ink level on the black ink cartridge? It's probably out. Or if it's a new cartridge, make sure the tape covering the connecter has been taken off.
Posted on Nov 06, 2009
  • 164 Answers
SOURCE: Coloured printer with black not printing?
Breath and Relax... this should resolve your problem.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
Cannon Pixma MP780 won't print. Just replaced black ink cartridge, do I have to replace all of them for it to print
Not normally but the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 08, 2013 | Canon PIXMA MP780 All-In-One InkJet...
My Canon Pixma ip6000d isn't printing any images or text. There is plenty of black ink, I ran the tests for alignment and nozzle check. The paper feeds through fine and it sounds and acts as tho
Did you try a test print. Most printers have a option to set the ink color, this is done when your computer asks you if you want to print. Look for an options tab and search for ink color options pick black only and try a test print. The test print is done on printer set up. If all else fails try the manual it usually has a troubleshoot section. Oh yes make sure you have the correct usb port some are configured at a lower level ( mine has 2 different ones a 2.0 and a 3.0 the 3.0 is blue when you look inside of it) my 2.0 port wouldn't set up my printer I had to use the 3.0 port. Hope it helps you some!
Feb 15, 2013 | Canon Pixma iP6000D InkJet Photo Printer
Can I print with one cartridge at canon pixma ip1300 with out replacing or installing other cartridge.
Absolutely, the only thing you need to do is to configure your setting to the right appropriate ink, say for example you ran out of black ink you can go to printing properties and select to be printed in blue, in this case the color match will use magenta and cyan to create blue.
1 select your default printer 2 select printing preference from your printer from there you can change the color of your desired print 3 you can select print in color for example or grayscale 4 then print your document.
cheers
Jan 06, 2010 | Canon PIXMA iP1300 Printer
Printer wont print (colured ink low) canon ip1600
TYPE IN ON ADDRESS BAR OR MENU
CANON PIXMA IP1600 PRINT ERROR 5200
ENTER
ROD
Feb 09, 2009 | Canon PIXMA iP1600 Printer
Can't I print with only one black ink
I have a similar machine ip5000. Currently have a problem getting the big one to print and have posted for a solution elsewhere. If I print withjust the small tank it does some black work i.e. type but it needs the other big tank to give full photo pictures.
If you are just looking to print typing try changing your font collour to a dark blue or other. This gets round the black problem but you will need the 2nd black cartridge for full colour work.
Hope this helps.
Mike
Mar 07, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
160 people viewed this question
jasbo
jasbo
