Question about Bunn VPR Coffee Maker
Water leaking out of back plate - Bunn VPR Coffee Maker
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 15 Answers
Most likely a bad thermostat grommet.
Posted on Mar 24, 2014
Leaks water only when wasing or draing cycle ubder front of machine
Look for a leaking hose on the pump housing. May be just a loose clamp.
Jun 27, 2017 | LG WM2077CW Laundry XL Front Load...
Freezer door leaking
I thought my leak was also coming from a line but nope - it's the black drain grommet that fits over the drain located just above the compressor in the back bottom of the unit. I had to use a blow dryer inside the freezer section to unthought the ice that was behind the freezer back wall. No need to take the freezer inside back plate off just use a blow dryer to melt the ice where the grille is located inside the freezer. You do have to take the back plate off where the water lines go into the bottom of the fridge. Once the back plate is off you then disconnect a yello and Orange plug that goes to the water line selinoid valve. Then prop up the back plate with the water lines still attached so you can access the black grommet on the drain. You must also disconnect the black drain tube from the water tray. Be careful not to break it as there is a small push clip that must be pushed in while you pull up. Once it's off then take the black grommet off of the drain that is just above the compressor. Mine was plugged with lint and sticky - wash throughly and then take a small pick or screw driver and insert it in the drain - once I did this about 2 cups of water came out so be prepared with a cup to keep it off the wires right below the drain. Clean up the water in the freezer and then reverse wha thou took off and then plug the fridge back in - you just saved $150 on appliance house call. Bad design for a high end fridge - my sears in the garage is 20 years old and not one problem. Cold beer on hand. Hope this helps!
Aug 13, 2012 | KitchenAid KBFS20EVMS 36" french door...
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck,
Gene
Aug 10, 2011 | Whirlpool Refrigerators
I have a Kenmore Coldspot Model 106.70182000 that is leaking water from the freezer into the refrigerator. Any ideas? Thanks!
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain, then totally flush w/warm water.
Good luck
I hope this helps you to stop that leak,
Gene
Aug 08, 2011 | Refrigerators
Belling dishwasher IDW604 error code E4 on control panel
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Feb 25, 2010 | Dishwashers
Belling IDW604
Jan 20, 2010 | Belling 24 in. IDW603 Built-in Dishwasher
Error code e4 flashes on belling dishwasher idw604 , washer is empty cant get any programs to work
Dec 27, 2009 | Dishwashers
My d1716 continues to run, but does not move forward in the cycle. I can even open the door and it continues running. If I didn't unplug it, the motor would likely burn out. Do I need a new dial? Thanks.
Hi
I would suggest that your flood switch has been activated. There is a float on the bottom plate or base plate of the machine. If there is a water leak, the float rises and triggers the flood switch.
Once the switch has been activated, the machine will go on a continous pump.
Disconnect the power and the hoses from the machine. Pull the machine out and lay it on its back.
If there has been a leak, you will notice water pouring out the back.
See if you can open the bottom plate, and reset the floater and flood switch. Sometimes you can access this by openning the front kick plate or front bottom plate.
Try the machine again. Leave the front bottom plate out and look into the bottom as the machine is working. If you have a water leak, this will happen again and you may be able to notice where the leak is from.
Be carful not to touch the live wiring while you are monitoring the machine.
Good luck
Ash
Nov 20, 2009 | Asko D1716 Built-in Dishwasher
When it pumps up it leaks right back down that is when it actually pumps up but with soapy water in a spray bottle i can not find a leak one. but there is a leak in the main line t still it is very small...
I am going to assume you are referring to the front airsprings. The right hand side has a top cover plate that actually seals the bag to the strut. In some instances the a/c line that runs over the top of the plate leaks condensation onto the plate, over time rust forms and pits form under the plate, and that is where the leak is coming from.
Oct 16, 2009 | 2003 Lincoln Navigator
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Bunn VPR Coffee Maker Logo
158 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
