Sony Bravia TV wont turn on, stand by LED flashes 4 times (approx 2 seconds) then is off for 2 seconds
mistersony
  • 320 Answers
SOURCE: sony bravia kdl40s2010u
A 4 flash indicates you have a backlight problem. Either the backlight inverter boards have failed or you have a backlight that has failed in the LCD panel. You will need a technician to check the set to determine which is the problem.
Posted on Nov 08, 2008
mistersony
  • 320 Answers
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Posted on Nov 10, 2008
prawinmv22
  • 106 Answers
SOURCE: light flashing 13 times on sony bravia KDL-46x3100
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Posted on Jun 16, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
What does 4-blink error code indicate?
These may help - the first just tell what it is and which ICs maybe the problem (quite technical)
Solved Sony Bravia Blinking Code
Bravia KDL46EX720 Red LED blinks 4 times and TV wont turn on What is the...
or, in the last resort you could try Sony support, either to get a service manual, or to ask a technician. Don't be fobbed with an expensive answer as in one the examples above.
Support for LCD TV BRAVIA Sony
18.November.2015
Nov 14, 2015 | Sony KDL-46EX720 BRAVIA 46 Class LED 3D...
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
I have a Sony Bravia KDF-50E2010 and after changing the lamp the TV stopped working. As i turn the power on the green light comes up for 2 or 3 seconds and changes to the stand by red light. Flashes t
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 02, 2018 | Televison & Video
Hi I have a Sony Bravia KLV-40S200A which wont turn on. The standby button flashes five times then pauses for about 4 seconds then flashes again. Any ideas?
Diagnostic Test Indicators
When an error occurs, the POWER LED will flash a set number of times to indicate the possible cause of the problem. If there is more than one error, the LED will identify the first of the problem areas. If the errors occur simultaneously, the one that corresponds to the fewest flashes is identified first.
LED ERROR DESCRIPTION CODE
1 Supply Voltage Trouble Panel 5V UNReg (10.5V)
2 DE5V Voltage Trouble FE5V (DCALERT2)
3 Voltage Trouble D3.3V/D2.5V/D1.8V. (DCALERT1)
4 Backlight Trouble
5 Main Supply Voltage Trouble (17.5V.DET)
6 Speaker Applied Voltage Trouble
7 Monitor an Increase in Inside-Temperature (esp. on the panel side)
8 Trident IC Trouble
Apr 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
May 14, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv powers off after 15-20min
chk fans 4 dust & clean if no help replace the largest visable fan approx 6"
Apr 27, 2009 | Televison & Video
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA 32 inch
I had the same problem with a old Sony TV.
To find out if the problem is temporary
  1. Turn off the television.
IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
If the light is still flashing the tv has stop working and you will need to buy a new one.
Dec 08, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
