Question about iflo Home
I have an iflo thermostatic bar shower mixer which no longer delivers hot water for the shower. Do i need a new Bar Mixer?
The water does not get hotter when I turn up the temperature
    New Friend:
    Problem Solver:
  • 19 Answers
To get rid of this problem, you should consult with a professional. Apart from this, you can buy attractive and best quality shower mixer by visiting this site: showerenclosures
Posted on May 06, 2013
5 Suggested Answers
  • 26 Answers
SOURCE: To whom it may concern,
Need Model # and brief description of particular model. You may be left with no option but to call in a professional who can pull the mixer and repair it without leaving any visibly noticable marks. Pulling the tile and drywall is a simple and straight forward repair that any competant general contractor can perform. There is no modification option to a mixer. My only question is "How did your plumber manage to install your mixer upside down?"
Posted on May 16, 2010
  • 4 Answers
SOURCE: shower grab bar has rusted
u could always repair the rod, its cheaper and easier, first of clean the rust off with viniger, white works best, then go buy some enamel paint, a small jar of whatever colour it is make sure its water prof, i suggest u do this in the morning then it will be dry for u to use at night, and there u go, if ur lazy however spend the money and change the bar, gd luck!
Posted on Apr 12, 2009
  • 26 Answers
SOURCE: I I have a 3 way bath/shower/overhead shower mixer
When installing a flexishower head, install it in front of the actual shower head with a diverter switch. If you try to operate two shower heads at once, you may suffer poor water pressure. There are handheld shower sets sold which are installed to existing shower assemblies with ease. Rememer to use plumber's tape and protect your stainless steel by wrapping you pliers teeth in electrical tape.
  • 16 Answers
SOURCE: I am unable to obtain any water flow from the cold
Hello u need to adjust the cartridge inside the diverter. Make sure u shut off water first!
Posted on Jun 30, 2011
Hot water does not get hot enough, is there a way to adjust the mixer
Yes, it could just be that the intervals of the mixer are getting stuck. This video may help
Sep 16, 2015 | Home
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
How to clean Axor Terrano Showerpipe - hot water part of mixer seems blocked
There are filter screens on the thermostatic cartridge inside this unit. You will need to remove the thermostatic cartridge and clean the filter screens. If cleaning the thermostat cartridge does not resolve the issue you may need to replace the cartridge. If you need further assistance feel free to contact me at Hansgrohe Technical services. 1-800-334-0455. prees 2 for tech and ask for David Scarborough.
Aug 30, 2012 | Home
We have a neptune bar mixer shower that has been fitted to the wall and plumbed. All the water has been turned back on, the hot water is working fine but nothing is coming through the cold water side. cold...
Possibly switch off hot and cold water then undo cold water flange closest to the outlet and see if water comes out.if it does, tap assembly is faulty. If not, go back to where next available connection to the pipe was made. Work back untill you find the problem.
Aug 05, 2010 | Home
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Got a gocta w-26mixer shower bar fitted cold tap
from a plumber all hot and cold connections on all major showers are hot on the left and cold on the right just like the taps on your sink or washbowl
Dec 09, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Mira thermastatic shower problem,pressure&temprature.
you mixing valve may be going bad,do you have hard water? you may just need too take it apart and clean it
Mar 06, 2009 | Plumbing
Home Logo
433 people viewed this question
Top iflo Home Experts
john h
Tom Chichester
Are you an iflo Home Expert? Answer questions, earn points and help others
