Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
I have a phillips 55pw936317f I would like instructions on how to change the coolant.
  • ajzstuff Jan 20, 2009
    How does the red wire come off the tube in the TV ? The green and blue tubes have a growth but the red is fine, need to have the glycol changed.
    President:
  • Philips Master
  • 1,779 Answers
The anode lead comes out of the HV transformer, unplug the convergence plug for the tube you are doing, also unplug the yoke plug, remove black ground leads from under-side of that tube, then remove the 4 screws from the brace of the tube(crt), do not remove the screws that hold the black optic lens just yet, make sure all leads are disconnected and ready to remove crt from the cradle. Note the position of the crt before you take it out, the blue if you notice faces reverse of the R+G. such as the expansion chamber vent. Look for the drain plug, it removes CCW 1/2 turn. empty fluid into a container, then you can dismantle the lens and clean the face of the tube with alcohol and you cannot leave a speck of anything in there, it will show up in the picture. re-assembly is just the reverse, just make sure you put the exact amount of fluid back in and do not over tighten anything but secure. After you install the tube you will have to do a complete convergence alignment. This is not a procedure a novice should attempt. I do admire you willingness to attempt it, but please don't. Contact a SVC co. you won't regret it. Hope this helped in your decision.
Posted on Feb 05, 2009
How hard is it to change the cooling fluid in phillips projection tv.
The CRT coolant change is all mechanical which involves removing the crt and disassembling the coolant chamber so it can be cleaned then reassembled and filled with coolant the phillips CRT coolant kit from www.tvrepairworld.com has the coolant and the instructions for the repair on cd
Jul 31, 2011 | Philips 60PP9352 60" Rear Projection...
I have a phillips 60" rear proj. the converge will not adjust what is the secret repair and what does it take to change and replace coolant on picture tubes
You can get the convergence repair kit which contains full instructions on Cd and you can also get the Phillips CRT coolant Kit with instructions at www.tvrepairworld.com Free shipping within the US
Nov 28, 2009 | Philips 60PP9352 60" Rear Projection...
I have a philips 55pw936317f I have about given up on, I got it free looked at it myself then thought a pro could do better, 500 later and no tv. They replaced the large signal board. the ssm. the power...
Does it go into shutdown (LED flashing) or just goes off?
Any symptoms before shutdown?
here's another soul with similar issue:
http://en.allexperts.com/q/TV-VCR-Stereo-1749/2009/10/55pw936317f-1.htm
Oct 23, 2009 | Televison & Video
Picture faded model number is fp4620w103
This sounds like the coolant fluid needs to be changed - the coolant turns milky after awhile and you'll get a dull image.
Google TV repair world . com and look for philips/magnavox coolant replacement:
PHILLIPS CRT Coolant Replacement Kit This is the complete coolant kit for Phillips CRT rear projection televisions. Kit contains 48oz of top quality High purity optical grade coolant with complete detailed instructions produced in clear easy to understand terms with detailed photos and illustrations that takes you through the process step by step safely dischargeing the CRTs and eliminating the need for complete realigning proceedures.Restores the vibrant colors and focus issues commonly associated with coolant that needs replacement
Oct 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Phillips 50p8341a
Replace the coolant in the CRts thats a common problem with Phillips and magnavox rear projections. Heres a link to the coolant replacement kit for your model. The kit contains the replacement coolant and step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Jun 12, 2009 | Philips 50P8341 50" Rear Projection...
Phillips magnavox 55" projection
The coolant needs to be changed in the CRTs ( picture tubes) this is a very common problem with all phillips and magnavox rear projections. Changing the coolant will restore the color and brightness and stop the halo effect. You can get the phillips CRT coolant kit at the following link and it includes all the coolant and the step by step instruction CD with pictures. Its actually a fairly easy job. Heres the link its listed under the repair Kit category.
Oct 14, 2008 | Televison & Video
Magnavox 55" projection Television. Picture not as sharp as used to be. Lenses and screen have been cleaned picture still not clear...
You need to change the coolant in the CRTs. Its a common problem with phillips/magnavox TVs. You can get the coolant replacement kit at the following link with all the coolant and the step by step instructions with pictures on CD. Its listed under the repair kits. magnavox and phillips are the same TVs. here is the link.
Aug 06, 2008 | Televison & Video
Changing the coolant fluid on a magnavox 6p6030
There is no free service manual for your model as its a large service manual that covers many models. You can however get the Phillips coolant replacment instructional CD, or the entire coolant kit with the coolant and instructional CD at the following link. Its listed under the repair kit category.
Aug 03, 2008 | Televison & Video
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
175 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
