Question about Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop
No sound I added more ram and am not sure if I hooked up the wires incorrectly but there is no sound at all...please please please help!!!!!! Thanks ;))
  • 2,229 Answers
Sound plug goes in the green hole.
Make sure under start>all programs>accessories>entertainment>volume control that the volume is up and the little "mute" boxes are not checked.
Posted on Jan 19, 2009
Hi i have creative sound blaster 5.1 surround sound. 2 rear, 2 front, center, and sub woofer. i am not getting sound out of the rear speakers. does this box have the capability of running all the speakers...
Your Dell supports up to 7.1 surround sound...I'm guessing you have something hooked up incorrectly. If not, make sure your drivers are up to date on the sound card.
May 03, 2011 | Dell Inspiron 530 Desktop Computer
No sound
Hi
Check the connection. Whether its connected properly..
Can u tell me model no and brand name so that i can help u clearly
thank you
Oct 05, 2008 | Onkyo Audio Players & Recorders
XO VIson DVD 7" works fine but when it is turned
sounds like you might have the wire that is always supposed to have power hooked to a switched power source
is it possible you hooked up power wires wrong
sounds like switched wire is hooked to battery and battery connection is hooked to switched source
only other option would be if ground is hooked incorrectly it should be hooked diretly to clean non painted metallic spot on cars body
if you need more help give me more details and i will try to help more
Good luck
Mar 13, 2011 | Panasonic XO-1515 XOVision Car DVD/CD/MP3...
I have a 98 dodge ram 2500 I installed a aftermarket radio and have power but no sound please help
Sounds like you hooked the wires up wrong. Crutchfeild.com sells the direct plugs that go from the deck to the stock wiring harness. Its a good investment. But check your wires.
Jan 17, 2011 | 1998 Dodge Ram 1500 4WD
Where is the fuse for the front speakers on 98 dodge ram 1500
Hi, unless you have a premium sound system with an amplifier, all of your speakers are powered by the same radio fuse. If you do have a premium system, it is probably an add on. The installers may have added a fuse to the panel on the left end of the dash. Check for a modification there--fuse that the map doesn't call for.
If you don't have an amp, there are 3 or so possibilities:
1. the fader control is turned to rear or is broken
2. both front power transistors in the radio are burned out.
3. Both front speakers are burned out or both wires are bad.
You can check for bad speakers and wires by taking one of the front speakers out and hooking up a known-to-be-good speaker (such as one from the back).
Please let me know if you have questions and thanks for using FixYa.
Dec 29, 2010 | 1998 Dodge Ram 1500 4WD
Why is the pc internal speaker beeping at me when i install the new ram - it won't boot. it is the right one.
Each memory slot can hold DDR PC2700, DDR PC3200 with a maximum of 1GB per slot. Make sure you have not added PC2100 RAM, and try adding a matched pair.
If you have the correct RAM type and spped, then try taking out all RAM modules and reseating them again, as it appears that one may not be slotted correctly. Be sure not to touch any of the Gold leads with your fingers, and of course make sure the power is off, the plug is removed, and then press the power button for 10 secs. to drain and charge in the board before proceeding.
Jan 10, 2010 | HP Pavilion a620n (PC028A) PC Desktop
Put new handle bars on and then after hooking everything back up the signal lights and also tail lights will not work??
Sounds like you have a blown fuse. Check the fuses. Chances are that when installing the new bars a hot wire got pinched or abraded and has grounded causing a blown fuse. If a new fuse blows right away, that would be the cause. Other things that would cause the lack of lights would be wires hooked up incorrectly, a wire not hooked up at all, a broken wire or a loose or dirty connection. If the new fuse blows you will need to find the problem. If the wires run inside the handlebars the entry and exit points for the wires are likely areas for abrasion and pinched wires.
A “very helpful” rating for this answer? Thanks!
Jun 13, 2009 | 2004 Suzuki VS 800 Intruder
Subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Jan 25, 2009 | Kicker CVR12 Car Subwoofer
No advanced graphics
ati ragepro series are the best but with 3 gig ram you will not need a expensive one as windows can access the ram thru the sm bus good luck
Dec 20, 2008 | Gateway GT5220 PC Desktop
Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
