When plug in the ac charger does not function when plug in battery it works can i connect external charger straight on battery or on pins that we plug the battery? THANKS
SOURCE: Compaq Presario Laptop lost power
the battery charger board, is what I would swap first.
Good luck, keep us posted.
SOURCE: Dell c640 charging problems.
Instead of spending alot of time trying to do something that could potentially harm your laptop..why not just buy a power supply?
You can get one here Click here for about 16 dollars. That's a great deal they are usually about $60 and its a Dell brand not some off brand.
Good Luck
SOURCE: Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
SOURCE: Acer 5100 laptop doesn't work on ac or charger battery
Motherboard is bad and will have to be replaced unless of course the AC Jack on the back of the laptop is loose. That would cause the ac adapter not to charge and then you would have to take the motherboard out and put solder on each leg on the bottom of the ac jack to make sure it stays in place then the ac adapter can charge the battery properly.
Even going thru the solder method the motherboard could still be bad and have nothing to do with the ac jack.
Gentlemen the ac charger is working fine with my wife's laptop, so it is good.The netbook is a Fujitsu Amilo mini ui3520.As for the battery charger board i do not nknow where it is.I will try find it and swap it as Thomas said.
