Question about Siemens Washing Machines
Siemens s14.49 washing machine motor is not turning !
Timer ticking, programs finishes OK, drum not rotating due to motor not going round , belt is OK
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Posted on Feb 15, 2007
  • 43 Answers
SOURCE: zanussi washing machine drum will not go round at all
Tracy
The bearing may have siezed or you have something jammed between the drum and outercasing
Posted on Mar 23, 2008
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
Posted on Apr 23, 2008
  • 958 Answers
SOURCE: washing machine drum won't turn under power
is the washing machine went to its usual cycle? put water in?
if you think the motor should have run already, then it could be the motor or the motor inverter.
check the motor leads for equal resistance, if i'm right, you may have a three phase motro so the three leads that comes out should have equal resistance.
also, if you can monitor the voltage present in the motor leads while it is plug in and you are waiting for the motor to run, if there is voltage then there is a problem with the motor, if there is no voltage present, then the inverter unit would be the defective part.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
SOURCE: My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Posted on Jun 27, 2009
My Estate washer ETW4400WQ1 will fill with water then run for about 2 minutes then stops. I can let it sit for about 20 minutes and go back to it and then turn it on and it will run for about 2 minute
this sounds as if the drive motor for the drum to rotate has some sort of obstruction to it's turning freely , unplug unit then remove the lower back panel , locate drive motor ther on bottom (round thing) see how difficult it is to rotate the drive belt one complete drum rotation with your hand , if drum does not turn freely then i suggest looking further for a missing drum roller or maybe a forign object getting caught down in drum lip seal
Feb 10, 2015 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My becko wma150w washing machine fills and but the drum doesnt go round
Motor brushes need replacing. check belt tightness too
May 19, 2012 | Washing Machines
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
Drum not rotating on washing machine
change the carbons in the motor
Jun 28, 2010 | Washing Machines
Drum not going round
Hi Friend,
welcome to fixya....
may be the drum belt is the fault, Here are some possible causes of a washing machine belt coming off :-
1.The drum pulley is loose
2.The drum bearings have gone (collapsed) causing the drum pulley to wobble
3.The drive belt was to slack
4.A motor fixing bolt or bracket securing the motor to the tub has broken or come loose
5.Water has got onto the belt causing slippage
6.An obstruction or item of clothing temporarily jammed the drum causing the belt to spin off ,,,,,,,,,,,,
first check whether it is hard to turn the drum if not then check the above situations,,,ok
if you think that i helped you please rate it\\\\\\\\
thank u...
Apr 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Drum won't turn even though maachine is working. Water flows in and emptes but drum will not rotate. Filter has been checked and emptied.
It could be a drive belt problem, a motor problem or a programming problem.
If there is a removeable rear cover, then have a look to see if the belt is o/k.
Hope this helps.
Jan 30, 2010 | Siemens Washing Machines
The drum will not go round
Possible belt snapped or motor brushes need replacing.
Jan 24, 2010 | Washing Machines
I have a Tricity Bendix AW1000W. The drum will not rotate. The belt is fine, the brushes on the motor seem ok, the machine fills with water ok and the pump drains it ok but there is no drum wash rotation...
Could be anything , from a loose connection or broken wire to a control board or timer fault..You say the brushes are o/k, but if they are less than 3 or 4mm long, they need replacing.
Even the motor itself could be faulty.
I assume the drive belt is o/k, and correctly tensioned..
It is difficult to advise you further because thier are too many variables involved.
Please leave your comments on my suggested solution.
Thankyou.
Nov 25, 2009 | Tricity Bendix AW1000W Front Load Washer
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Nov 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
Hotpoint wf240 replacment of belt, i cant get it on.
Hi, put the belt on the bottom pully and feed the rest up to the top pully, fit the belt on to half of the top pully, now open the door of the washer and very carefuly turn the drum while holding the belt tight to the pully, take care not to get your fingers trapped, make sure that the belt stays on both pullys by rotating the drum by hand a few times, if it all looks ok and central then the jobs a good un.
Mar 03, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
106 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
