NEC Plasma Monitor Plasmasync PX42VP4PG/S - Televison & Video
4 Suggested Answers
this is me
  • 48 Answers
SOURCE: NEC Plasmasync 42MP2 Long startup?
If you're NOT still under warrantee you should at least open the TV and check the board where the components are mounted and resoled any that look bad. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Posted on Jan 01, 2006
  • 9 Answers
SOURCE: i can viwe only small space in screen before it was half screen
I can guarantee to fix this tv for $400-900. I have all good boards and know the procedure to determine which board is bad.
Posted on Nov 22, 2008
SOURCE: NEC PlasmaSync 42MP2 TV Stand required
I need help to find a tabletop stand for my NEC
Posted on Apr 05, 2010
NEC plasma PX-50XM5A with ghosted images
tienes un problema en el plasma de imgenes fentasmas lo que te sugiero que le hagas un buen mantenimiento
Aug 24, 2009 | NEC PlasmaSync PX-50XM5A 50 in. Television
Plasma shows half screen
Have a technician come and replace the display drivers or buffers boards they are some times called.
May 15, 2009 | NEC PlasmaSync PX-61XM1A 61 in. Television
I can viwe only small space in screen before it was half screen
Nov 04, 2008 | NEC PlasmaSync 50MP1 50 in. Television
NEC plasmasync 42pd3
A Plasma Screen never need 're gassing'.
If you have verified the connections and leads are correct the the up converter is possibly faulty and in need of servicing.
Take it to an authorised NEC repair shop.
Jun 10, 2017 | NEC PlasmaSync 42PD3 42" Monitor
Turns on then clicks and turns off - HELPPPPPPPPPPPPPPPPPPPPPPP
You should take the monitor to the NEC service rep for your area.
This monitor is service with board exchange. They will try the modules to determine the fault, and then do the factory adjustments to match the module.
By your description, it is most likely that the fault is on the power supply and or the panel drive module.
This TV set will be on the expensive side to service. If the display was having good emission, it may be worth to invest the money in to it.
Jerry G.
May 29, 2008 | NEC PlasmaSync 50MP1 50 in. Television
Nec 42
who has manual for a nec 42 plasma monitor px-42vm2a date it was made is 12-07-01 it is a flat screen thank you email carl5545@bright.net
Apr 04, 2008 | NEC PlasmaSync PX-42VP2A 42 in. Television
Nec 42'' plasma
Try holding down the 'INPUT SELECT' button, then press the power button on, on the tv at the same time.
Oct 29, 2007 | NEC PlasmaSync 42MP3 42 in. Television
X10d
through the hole of the screen??? Im sorry I dont understand the question.
Apr 23, 2006 | NEC PlasmaSync 42PD3 42" Monitor
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
