Question about Lowrance MapCreate 6 and MapCreate TOPO CDs GPS Receiver
Mmc sd card registry with mapcreate7
Will not create map on card because card will not register
  • h2oc novice Jan 19, 2009
    its mapcreate7 not 6 sorry
5 Suggested Answers
  • 17 Answers
SOURCE: map loading from SD card
Yes go to the Lowrance web site and down load the fix to a sd card , put the sd card in the i finder and it will update it automaticlly. I have not done it for map create 7.0 but have for map create 6.3. On the web site look under suport or downloads and you should find it. There is also a lot of free lake maps that you can download to sd card also. Good luck
budman630
Posted on May 15, 2008
  • 14 Answers
SOURCE: unocking Garmin SD maps
it is in the box it came with, on the back of the instruction book.
If you did not buy it 'new in the box', you will have to refer to the 'activation' code sent to you email.
The Garmin Nuvi 760 does not require SD card maps if you are using it in the US, btw...
-d
Posted on Feb 20, 2009
  • 30 Answers
SOURCE: Why cant I download my waypoint data to a 2 GB SD
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Posted on Jul 11, 2009
  • 13 Answers
SOURCE: HAVE NAV-CAM 7000 GPS....NEED UPDATED SD CARD W/SOFTWARE
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150362945965&ssPageName=STRK:MESELX:IT
Posted on Jul 31, 2009
Tip
How to update your Garmin Satnav maps
To update your garmin satnav map you must have your satnav registered. If it's already registered skip to paragraph 2 below.
1. To Register your Garmin Satnav
  • Connecty our satnav to your computer and go to www.garmin.com
  • Select your country
  • Click on Register your garmin product
  • Follow the prompts
Note you will be asked to create a username and password. Write them down and keep them safe as you'll need them again anytime you want to update your maps
2. To update your maps
  • Connect your satnav to your computer and go to www.garmin.com
  • Click on myGarmin and log in
  • Click on myMaps.
  • If there's an update available it will be shown beside the name of your map.
  • Click on Get Update and follow the prompts.
Note map files are large so you'll need a broadband connection to download them. If you don't have broadband you'll have an option to buy the update on DVD.
  1. If The Map Is Too Large To Install To Your Satnav
    When you go to download the map by default it tries to download it to the satnav i.e. not the SD/Mini SD card. You need to change this. When the website recognises the satnav follow the prompts. It will give you 3 options for the download destination.
    • Download to satnav,
    • Download to Computer and Satnav or
    • Download to computer.
    As the website is updated, from time to time, the method of selecting the download destination changes. Sometimes it shows up as a drop box with a drop-down arrow showing your satnav name. Click the drop-down arrow and select the option to download the map to your computer. Sometimes it shows the 3 options as text headings with tick boxes beside them and you get to tick the option you want. Whichever way it shows up select the option to download the map to your computer. This will install it on your computer's hard drive.
  2. After it's downloaded the map should begin to install automatically. (If not double click on it and it will). It should be allowed to install to your satnav first as Garmin will not allow it to install to your SD/Mini SD card unless it's first partly installed to the satnav. This is so they can ensure that it's installed to the correct satnav.
  3. To Install The Full Map To Your SD/Mini SD Card
    To install the map to your SD/Mini SD card, insert the card into the card slot of your satnav and connect it to the computer. Click the windows start button on your computer. Then click the GARMIN progam and then MAPINSTALL. This runs the map installation program. When the install program finds your satnav and you get the option to install the map there again by default. Click on the drop-down arrow, where it shows your satnav as the destination, and select the drive letter of the SD/Mini SD card. This will be different to the drive letter for your satnav. The map will then be installed to your SD/Mini SD card.
  4. Problems With Older Nuvi Satnavs Reading Maps On 4 Gb Or Higher SD Cards
    When you install a map to an SD card older nuvi satnavs can have difficulty getting the satnav to read it. It will install to it without problem but when you try to operate the satnav then it cannot load the map and will close down the satnav unless you remove the SD card. The reason for this is that 4 Gb and higher cards are SDHC which operate differently from SD. To solve this problem you should use a class 2 SDHC card, which is the slowest type available. You can identify the class by the small figure on the card. It will be either 2, 4, 6, 8, or 10. Before you install the map format the card as described below. Also use webinstaller to check that you have the latest version of operating software on your satnav.
  5. Format the SD card with "Panasonic SD Formatter" available from http://panasonic.jp/support/global/cs/sd/download/sd_formatter20.html rather than the standard windows format function. Select the fast format option and be sure you have selected the drive letter of your SDHC card as it will format your hard drive or indeed your satnav just as easily if you select one of them by mistake.
  6. To update your software or check that you have the latest version, you can download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
    Connect your satnav to the computer and run the program. It will search for any updates to your software.
Class 2 SDHC cards are harder to find in shops today as they are being replaced by the faster classes. They are however still easily available on ebay if you can't find one in the shops.
on Aug 17, 2010 | GPS
What is a sd/mmc card
USE IT! go out and buy at least a 2GB and backup your device I didn't and now I don't have any maps at all! Trust me its worth the 15 bucks!
Feb 13, 2013 | Magellan Maestro 3200 GPS
Can i download pictures from my aspire 6920g to a sd memory card
1. open Windows Explorer
2. push the sd card into the sd card reader with its contact side down until it is flush
3. sd card is detected and displayed as a drive called SD/MMC (N:) where N is its drive letter
4. clicking on the SD/MMC drive will list any folders that are in it
5. with SD/MMC high-lighted, click on File and on the drop-down list, hover cursor over New
6. on the New list that opens, click on Folder to create a new folder on the SD/MMC drive
7. right click on the new folder and from the drop-down list click on Rename
8. rename the folder appropriate to the photos you want to download to the SD/MMC drive
9. navigate to the photos and high-light using shift+click for a block or ctrl+click for individual
10. with cursor over high-lighting, hold down right click and drag to new folder and release
11. select from the pop-up list that appears on release to either Copy Here or Move Here
12. repeat from 9 for more photo downloading and when done do an eject before removing ....
13. for Windows XP, click on the Safely Remove Hardware icon at the right side of the Taskbar
14. for Windows 7, can do same as XP or just right click SD/MMC and select eject from the list
15. **WARNING** failing to do an eject or Safely Remove Hardware can result in corruption!!!
16. once message appears that media can be safely removed, push the card in until it clicks
17. once click is heard, stop pushing and it will pop out sufficiently to be grabbed & pulled out
Apr 30, 2011 | Acer Aspire 6920 Notebook PC
I am in india and i want india map where i can buy
You can buy the map from the garmin website. You need to have your satnav registered. If it's not registered this is how to register it;
  • Go to www.garmin.com
  • Select your country from the drop-down list
  • Click on the "myGarmin" tab at the top of the screen
  • Click on "Register your garmin product"
  • Click on "Automotive" and follow the prompts
You'll be asked to create a username and password. Keep them safe as you'll need them to buy or update maps. Before buying the map of India take a look at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps where you'll find information on how to save your map to your computer or a memory card if you want to keep the map that's already on your satnav. If you download it directly to your satnav you may overwrite the map that's already on it.
When your satnav is registered;
  • Connect your satnav to your computer with the mini USB lead
  • Click on the myGarmin tab at the top of the page and log in using your username and password
  • Click on the myMaps tab at the top of the screen
  • On the left side of the screen, click on "Shop for more maps"
  • Click on "View additional maps for this product"
  • Scroll down to the map of India and click on "Download" if you want to download it or MICRO SD/SD if you want to buy it on a memory card.
  • Follow the prompts.
Jan 28, 2011 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 205 is in american but i live in the uk how do i change it
If it's the map you want to change you'll need to buy the UK map. To do this you need to have it registered.
To register your garmin nuvi satnav connect it to your computer.
Click on "Register your garmin device"
Select "automotive"
Follow the prompts
You'll be asked to create a username and password. Keep them safe as you'll need them if you need to update your maps later
When it's registered Log into your account.
This will bring you to a screen where you have the option to buy more maps. Buy UK and Ireland or Western Europe. Don't go for the complete map of Europe as it will not fit on your satnav. If you download the new map to your satnav it will overwrite the map already on it. If you want to save the American map you can install the new map to an SD card. You'll need to download it to your computer and then install it on the SD card. Details on how to do this are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
There's more information there than you'll need but it gives very detailed information on installing maps to an SD card.
To change the voice from American English to British English;
Press TOOLS (the spanner symbol)
Press SETTINGS (the spanner symbol) or LOCALE if there's not a settings icon on your satnav.
Press LANGUAGE (the lips icon)
Where you see VOICE press it and select a British voice.
Dec 18, 2010 | Garmin nuvi 255W GPS Receiver
Where can I buy a map card with the United Kingdom info be bought in Canada?
Go to www.garmin.com and if you've registered your satnav log into myGarmin.
Click on the myMaps tab at the top of the page.
There you will see the maps on your satnav and you'll have the option to buy new maps.
When you're downloading the map be sure to download it to your computer and NOT your satnav. Otherwise you'll overwrite the map already on the satnav.
When it's downloaded click the windows START button and you'll find a folder called GARMIN. Click this and you'll find an item called MAPINSTALL. Use this to install the map to an SD card which you must have inserted into your satnav. It's best to use a 2Gb SD card not an SDHC. Again be sure you do not install the map to your satnav but to the memory card. You get the option of where the map will be installed during the set up process.
If you have not registered your satnav you can do so by going to www.garmin.com. Click on the drop-down arrow and select your country. Click on myGarmin and then on REGISTER YOUR GARMIN DEVICE. You'll be asked to create a username and password. Keep them safe as you'll need them anytime you need to update your maps or buy new ones.
There's more information on installing maps at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps if you need more help.
Dec 12, 2010 | Garmin nuvi 255W GPS Receiver
How to upload maps in garmin 200w from sd card
on menu touch tools, maps, map info, tick the box, you may need unit I.D. and serial number.
Regards.
Mar 21, 2009 | Garmin Nuvi 660 GPS Receiver
Map loading from SD card
budman630
Feb 11, 2008 | Lowrance iFinder GPS Receiver
GPS Logo
175 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
