Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
When machine starts to spin machine clunking sounds.
The tub does spin, takes longer to dry because all the water doesn't spin out of clothes. Took the back off washer from the back when you take hold of the the tub it moves what I believe is way to far. It moves around inside the cabinet to the point that it almost touches inside cabinet walls. from the front pulling back the rubber and seeing the tub there is the plastic outside and stanless steel inside . When we try move the inside tub it doesn't seem to move. there is nothing that appears to be broken. The machine is 7 years old what we are thinking is maybe the shocks could be worn. to the untrained eye it looks like the shocks is what determines how much movement to tub does inside the cabinet. Many people refer to a spider and a bearing when looking at the diagram it refers to a pulley and a nut. they are the part between the tub and the back panel if I'm looking at the right parts they don't seem loose or worn.
    Top Expert:
  • Whirlpool Master
  • 33,359 Answers
If it is a front loader, odds are the bearing is defective.
Posted on Mar 09, 2017
catriver
  • 878 Answers
SOURCE: Tub and Basket
Fairway, sounds like you have a worn drive block. You are going to have to remove the agitator and inspect the drive block. If it is the drive block you will get some good hammering when the spin cycle stops. I will attach some photos of a worn out drive block. If you want to attempt to handle this yourself, we can walk you through it. Catriver..post back.
Posted on Oct 23, 2006
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
SOURCE: whirlpool GHW9100LW1, belt came off
I had the same problem and being a procrastinator, I waited until the belt came off before launching a full scale investigation into the knocking noise it had been making for about a year. Here is what I found and below that is my no guarantees fix.....
I removed the nut and pulled the tub pulley off. I noticed the tub shaft has a "shoulder bolt" and the pulley could not be tightened onto the shoulder bolt with enough squeeze to keep the tub pulley from wobbling. Tolerance issue... maybe? I decided to measure the keyed tub shaft with calipers and found the thickest part of the shaft to be 1" ish. The Shaft is part of the tub bearing assembly (from my observation) and the tub shaft is part of the tub bearing which measured 1 1/4" diameter. I found a washer that was 1" inside diameter and 1 1/4" outside diameter and placed it over the tub shaft behind the tub pulley. I tightened the nut snugly and reinstalled the belt. Ahhhhh, quiet operation and no more wobble. I will let you know if it causes another problem but from what I can tell.... replacing the tub pulley with another of the same dimensions will not work.
you don't need a very thick washer(my washer is too thick (.1"ish) so I will replace it soon(yeah right) with 1/32" or maybe 1/16"...I used rubber but I think steel or brass or what ever would probably work too.
Purists will tell you that the lock nut should be replaced, or if you don't use the permanent thread locker you could use loctite.
Hope that helps.
Posted on Oct 02, 2008
  • 4 Answers
SOURCE: My Whirlpool Duet front loader is ripping my
My washer ruined 2 king sheets 3 shirts and brand new jogging suit, so I know what you mean! The rubber gasket ...it had 2 metal bands..one on the inside which is a wide one and a small thin one on the outside of the gasket. You really can't see the wide one unless it has started to slipped off or break. or by taking the ting one off,..my wide band came loose which caused the screw to be exposed just enough for something to catch on it, tearing the material, it kept wrapping around and around untili eventually the band came completely off. I hope this helps.
Linda
Posted on May 08, 2009
Karthik316
  • 187 Answers
SOURCE: LOUD RATTLE ON WHIRLPOOL GHW9150 ON SPIN CYCLE
Try this link
http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
pls rate my suggestion....
Posted on Jun 26, 2009
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
Can't get the water in the tub & it doesn't spin.
TRY THE LITTLE SWITCH THAT ENGAGES WHEN U SHUT THE LID... MY GE WASHER JUST HAD THE SAME PROBLEM ABOUT A MONTH AGO
Mar 14, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
Maytag navigator washer not draining all the water out
Here are some things for you to check out
Please read fully this covers a couple of different brands but it is all the same things to check ok?
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jun 23, 2011 | Maytag Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
Washing machine that no longer can spin dry laundry
The washer has a reversable motor. One way it washes and everything is sweet. the other direction the water pumps out and the brake gets released allows the tub to slowly start spinning and eventually spin out the water from the clothes. So what can go wrong? The thrust washer will not release the tub and let it spin. A new kit comes with everything you need to replace it.Since you never said what brand you have I am oly guessing of course by the symtoms you have given.eee0328.jpg
Dec 15, 2008 | Washing Machines
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
85 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
