What can I do my mecer xpresion w76t shows a window writen bootmgr is missing press ctrl+alt+del to restart
My mecer xpression w76t does not boot when presing f2 it shows a phoenix securecore(tm) setup utility window which ask me to enter password
pagebor
  • 2785 Answers
SOURCE: Acer Aspire 5315 Booting Error
check in bios the first boot device is the cd/dvd rom then you try to reload the os
Posted on Jun 30, 2008
  • 17 Answers
SOURCE: bootmgr is compressed
I know of three solutions, none of them will work without recovery or OS discs, and I can only guarantee one of them--the one that whipes your system. Try these in this order (assuming you have system discs);
#1 Boot from the system disc and choose the "repair" option. This is the quickest fix, and you lose anything.
#2 Boot from the system disc, and in your Start menu search type "Command Prompt". Open Command Prompt and type (hit enter after each line);
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
#3 Run a full system recovery from your system discs.
Now, if you don't have your system discs, and you're running Windows Vista, there is another possible option. If your computer is fairly new then you probably have a WinRE partition for recovery, (a "factory image" drive)? I won't go into this now, if you have your discs option 1 or 2 should work for you.
Posted on Feb 27, 2009
sidlas
  • 95 Answers
SOURCE: my laptop says BOOTMGR is missing what does that means?
tap f8 when boot,in menu go to last good known configuration>enter,post reply if not helps will give further instructions if needed.
Posted on Jun 15, 2009
jaye_ellen
  • 591 Answers
SOURCE: BOOTMGR is missing
This error can be corrected by reloading your Laptop's Operating System from the Restore disks you got with your computer. Place your Restore disk into the drive and restart the computer. The install will re-create the missing Boot Manager.
Posted on Dec 18, 2009
Bootmgr file missing
The system Post unable to proceed due to a defective Drive.
I corrected that same problem in less than 15 minute.
You are unable to boot,the error message comes up .
Bootmgr file missing ; > press ctrl alt del .
This is what I did ..I enter the BIOS I set the boot order.
(1) 1st Floppy 2nd CD ROM 3rd HDD
(2) I replace the DVD Drive with a new DVD Drive
(3) I put Gos Linux operating CD in the DVD drive
(4) I then boot the system.
(5) All went well, I format and install........
From ; mjsullkeys@hotmail.com
Posted on Apr 10, 2010
Windows cant open bootmgr is missing, press ctrl+alt+del but not working how to fix it aspire one D257
Have you tried a System Restore/Recovery? Can you boot to safe mode? Try the restore/Recovery procedure: Shut down, unplug, remove battery, plug in, push the on button and When Acer splash is on screen hold Alt and keep pressing F10...
Apr 14, 2013 | Acer Aspire One D257 Netbook
Missing boot manager and blue on everything
if you boot pressing F8 can you get to the repair option?
Nov 27, 2012 | Computers & Internet
Solusi untuk BOOTMGR is missing pada acer aspire one happy2 N578Q
This sounds like a hard drive failure, try your recovery disc if available, if no change! have the hardware checked for possible replacement.
Oct 26, 2012 | Computers & Internet
My satellite L455D-S5976 is showing BOOTMGR is missing and when i press ctrl+alt+del to restart it shows the same thing PLease help
Are you using Windows 7 or Vista?
If so have you tried Windows repair using the Windows DVD? Boot off the winDVD and click on repair instead of install.
Aug 25, 2011 | Toshiba Satellite L455D-S5976 Notebook
On start up the machine shows the acer logo press F2 for set up. Then the screen reads: "bootmgr is missing press ctrl+alt+del to restart"
This is a common problem, here is a link to a very detailed guide: http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
Jul 16, 2010 | Computers & Internet
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Bootmgr is compressed and press ctri+alt+del to restart
Hello ajay1 8 83
You need run SFC /SCANNOW
Read this first for more understanding http://support.microsoft.com/kb/936212/
Try booting to your Vista installation CD. Choose Repair. Select your operating system, should bethe only one. It will repair the BOOTMGR.
Jul 12, 2009 | Microsoft Windows XP Media Center Edition...
Bootmgr missing
Windows Vista?
Insert the installation CD. Once it boots from CD, click "Repair Your Computer", select the drive, and then "Startup Repair". This should fix it.
More info here.
Apr 16, 2009 | Computers & Internet
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Aug 28, 2008 | Computers & Internet
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
