Question about Microsoft Xbox 360 Console
Red light just got 1 red light on my xbox can you tell me why please
  • VIDEOGAME REPAIR SERVICE
    Is there an error on the screen like E74? If yes then you will need the system serviced. We can help if your interested email us for freee estimate xbox360fixer@verizon.net
    Novelist:
  • 174 Answers
Try the following to resolve the problem:
  1. Turn off your Xbox 360 console, disconnect and reconnect all cables, and then turn your Xbox 360 console back on. If this step doesn't resolve the problem, try step 2.
  2. Turn off the console, and then disconnect any connected accessories, such as controllers, Xbox 360 memory units, and the Xbox 360 hard disk. With these accessories removed, restart the console to see whether the problem persists and to pinpoint whether it is the console or an accessory. If this step doesn't resolve the problem, try step 3.
  3. If you continue to experience the problem, contact Xbox Customer Service. If the Xbox Customer Service agent cannot help you resolve the problem, you may have to return your Xbox 360 console to Microsoft for repair.
This is usually the similar sort of problem to what causes the 3rrod (3 red rings of death) and can be fixed by trying the above or by re-heating the mainboard with a heat gun and this in turn will reseat the solder point. we also fix this error www.fixmyconsole.co.uk
Posted on Jan 19, 2009
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
I have an xbox360 I had almost a year I went to switch it onan a red light apear and tells me to go to xbox custemer care E37
Jan 21, 2011 | Microsoft Xbox Console
Xbox-360 elite lower right hand red flashing led light code error E73
Jan 17, 2011 | Microsoft Xbox 360 Console
Someone plugged there xbox 360 HDMI cable into the USB port in a laptop. Now they get a E74 and 1 red light lower right side . What can they do now.
Jan 14, 2011 | Microsoft Xbox 360 Console
Xbox 360 one red light bottom right
Nov 05, 2010 | Microsoft Xbox 360 Console
One red light on xbox 360
In most cases If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages.
HERE IS THE RED LIGHT REPAIR MANUAL: http://docs.google.com/viewer?url=http%3A%2F%2Fpdftown.com%2Fpdf-ebook%2FXBOX%2520360%2520Repair.pdf
Oct 19, 2009 | Microsoft Xbox 360 Console
How do you fix an xbox 360 red lights?
depending on the age microsoft had extended the warranty of the 360 you will have to contact xbox and send your unit in to get repaired
Jul 26, 2009 | Microsoft Xbox 360 Console
Red Ring of Death : 1 Red Light
Well the why part of your question can be answered here - http://www.xbox.com/en-US/search.aspx?keyword=one+red+light
They go into many of the error codes, as to how to fix it without voiding the warranty; If it's under warranty send it in to be fixed, or if you're dying to play right now try the 'towel method' shown here -
http://www.xbox360rally.com/the-red-ring-of-deathcure-found/
Beware- purposefully overheating your xbox 360 may damage your system further.
Please rate my response :)
May 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 e74 error
Having the e-74 code is when the video chip on the 360 over heats and becomes un soldered your best bet is to turn the 360 on with a towel over it and wait for 3 red lights the call microsoft and tell them the 3 lights issue dont mention the 1 light or it will cost you dearly around 150$
Mar 17, 2009 | Microsoft Xbox 360 Console
X-box360 one red light on console
1 red light tell you that your video cable is unplug or broken
2 red light tell you that your xbox are over heating
3 red light tell you that your heat sink is incorrectly installed because of the overheating
so for your problem make sure that your xbox is correctly plug and if it don't work again change your video cable for a new one
good lock :-)
Jan 06, 2009 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
53 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
