Question about HEWLETT-PACKARD Hewlett Packard Hp 1/8 G2 Lto-5 3000 Sas Autoloader (BL536A) LTO Ultrium Tape Drive
HP 1/8 tape autoloader login name and password
Someone can tell me the login name and password. I am use the telnet to connection autoloader. I want to login this autoloader. Thanks.
Which Default Passwords Are Used on S Series Switches?
On the S series switches of all versions:
· When you log in a switch through a console port, no default user name or password is provided. The system asks you to set the user name and password when you log in to the switch for the first time.
· Before you log in to a switch through Telnet, create a Telnet account.
· You can set the Telnet login authentication method in the VTY. If the password authentication mode is configured, set a password in the VTY. If the AAA local authentication mode is configured, set the user name and password in the AAA view. If the remote AAA authentication mode is configured, set the user name and password on the AAA server.
May 27, 2016 | Huawei Computers & Internet
How to reset password of username in 6506e switch through telnet not console plz give reply as early as possible.
login through telnet, remove the current username and password.
configure the username with the new password
config t
username xxxx pass xxxx
1. do not exit the current session, telnet the sw with new session and give the username and new pass. if does'nt work roll back the config.
or
2 excute login in current session and try with the username and new pass
Feb 21, 2011 | Cisco Catalyst 6506E Switch Chassis...
Forgot service password for HP Surestore Tape Autoloader 1/9 DLT 1 Tape Drive
This legacy devices service password can be reseated by following this steps:
The following is required before resetting the password:
  1. Access to the front panel of the HP Surestore DLT library.
  2. From the Home screen, press Main.
  3. From Main, press Information.
  4. From Information, press More.
  5. From this menu, press Date and Time.
  6. Write down the date (including year) and time.
The display shows a valid date and time
Do the following:
  1. Press the left-most button (button 1). This button is not labeled. A warning message to call service will appear.
  2. Press OK.
  3. The Call Center must then calculate a special password based on the date and time, using the following formula:
    1. (Hours * 1001) + (Days * 101) + Month + Year (all 4 digits) = subtotal
    2. Multiply the subtotal by 123. If this multiplication results in a number greater than 99,999,999 (this should never happen), use the special password of 44122333.
    3. Since the only valid choices are 1-4 for each digit, follow these rules:
      • If the digit=0 (zero), make the digit=1
      • If the digit=9, then make digit=1
      • If the digit>4, subtract 4 from the digit
      • If the digit does not meet any of the above, leave the digit unchanged. If the result is less than 8 digits, add leading 1s to make it eight digits in length.
        NOTE: As an example, 2000 02/07 2:30 is displayed (February 7, 2000 at 2:30). Plugging in the numbers: (2 * 1001) + (7 * 101) + 2 + 2000 = 4711
        4711 * 123 = 59453
        Convert all digits to be between 1 and 4 = 131413
        Add the leading 1s to make it eight digits long - 11131413
  4. Enter this special code to the front panel.
  5. Press OK. The screen will confirm that the password has been reset.
  6. Set a new password.
Mar 08, 2010 | HP Surestore Tape Autoloader 1/9 (C7147A)...
Can't telent to belkin cable router model f5d9230-4
You are trying to set up the router with the Telnet connection. I think it is a DSL connection.
Are you able to go online when connected to the telnet modem only ?
or do you have user name and password for the ISP.
Click Here for Step by step solution
Oct 28, 2009 | Belkin (F5D5231-4) Router
Telnet password
Use this step:Router>enable Router#config t Router(config)#line vty 0 4 Router-2(config-line)#login% Login disabled on line 66, until 'password' is set % Login disabled on line 67, until 'password' is set % Login disabled on line 68, until 'password' is set % Login disabled on line 69, until 'password' is set % Login disabled on line 70, until 'password' is set Router-2(config-line)#password newpasword
Mar 08, 2009 | Cisco 800 (CISCO802) Router
Error code 90
NO PC stated, it has a HP name, like DV6-12345,
no OS stated, XP , w7 , w8 or w10. we can not guess OS, ever.
start a post by telling the helper what is in your hands.
we cant look for you, you must tell it.
tapes, sounds , RELIC for sure...
May 08, 2017 | HP Computers & Internet
Lanier ld122 503 service unavailable
This can occur if the Web services has been turned off in either the Web Image Monitor or from a telnet command for this device.
To check the status of these services you will need to telnet into the device.
1. From a command prompt type : telnet then the IP Address of the device
2. Telnet will respond back with a request for a login and then a password. Enter the login and password. The login and password used for Telnet are the same credentials that are used to log into the device’s Web Image Monitor (WIM).
3. Type in show at the msh> command prompt.
This will output many lines of information. The information you are concerned with is under the TCP/IP-Mode heading. You may need to scroll up in the command prompt window to see these services. The device’s services will be shown followed by their status. The ‘show’ command will show if the services are enabled (UP) or Disabled (Down).
4. If Web shows a down status, at the command prompt msh> type in set web up.
5. At the command prompt msh> type in logout
6. To make your changes Active you must type yes when prompted to "save configuration data"
Note: Always check with your system administrator before making any changes on a network device.
Aug 19, 2008 | Ricoh Office Equipment & Supplies
Ultrium LTO 3 Tape Autoloader Error
what software are you using? try not backing up the system state to see if that changes anything?
Feb 07, 2008 | HP StorageWorks ESL712e Ultrium (AA934B)...
Reset a password for IBM NWAYS Router 2210 Model 12E
Does this mean anything to you Remote Login Names and Passwords During a remote login, the device prompts you for a login name and password. You can display the login name when logged in to the device from a remote console by using a device status command. Logging in Remotely or Locally Logging in to a local console is the same as logging in to a remote console except that you must connect to the device by starting Telnet on your host system. To log in remotely, begin at step 1. To log in locally, begin at step 3. To log in from a remote console: 1. Connect to the device by starting Telnet on your host system. Your host system is the system to which remote terminals are connected. 2. Supply the device?s name or Internet Protocol (IP) address. To use device names, your network must have a name server. Issue either the device name or the IP address as shown in the following example: % telnet brandenburg or % telnet 128.185.132.43 At this point, it makes no difference whether you have logged in remotely or locally. 3. If you are prompted, enter your login name and password. login: Password: It is possible that there is a login and no password. The password controls access to the device. If a password has not been set, press the Enter key at the Password: prompt. Logins are not set automatically. For security, you can set up user names and passwords using the add user command in the CONFIG process. For additional information, see the add user configuration command, on 56. Remember to reload or restart to activate any changes. Note: If you do not enter a login name and valid password within 1 minute of the initial prompt, or if you enter an incorrect password three times in succession, the device drops the Telnet connection. 4. Press the Enter key to display the asterisk (*) prompt. You may have to press the Enter key more than once or press Ctrl-P to obtain the * prompt. Once at this level, you can begin to enter commands from the keyboard. Press the Backspace key to delete the last character typed in on the command line. Press the Delete key or Ctrl-U to delete the whole command line entry so that you can reenter a command. See ?Command Completion? on page 20 and ?Command History? on page 23 for more information. You can also use local Telnet commands on your Telnet client to close the Telnet connection.
Jan 21, 2007 | IBM NWAYS Router 2210 Model 12E
HEWLETT-PACKARD Hewlett Packard Hp 1/8 G2 Lto-5 3000 Sas Autoloader (BL536A) LTO Ultrium Tape Drive Logo
82 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
