Question about Denon DP200USB TURNTABLE W USB Turntables Turntable with USB
I connected my Denon DP200USB TURNTABLE to my Yamaha RX V471 AV reciever through the AV cable that came with Denon turntable. I'm new to vinyls but i must say the sound is very uninspiring compared to CD playback through the amplifier. I'm playing a brand new vinyl of Opeth's damnation and I can't hear anything that the audiophiles are raving about. I know that the info i've given here is limited, but can you please tell me what I'm doing wrong? Many thanks
  • Nikita Tissera Jan 04, 2013
    I have the same album on CD and now on brand new Vinyl. This is only my second vinyl purchase, but the CD sounds loud, bright and detailed while the vinyl playback sounds rather muted and needs a lot of volume (both through the same Yamaha RXv471 amplifier) What do you think i should do different? .
  • Denon Master
  • 5,190 Answers
You have either connected (wired up) the cartridge wrong or the amp needs a magnetic cartridge pre-amp.
Posted on Jan 05, 2013
  • Nikita Tissera Jan 07, 2013
    Many thanks Grubhead.. But my Vinyl player is an entry level Denon DP200USB and the cartridge came pre-fixed. All i had to do was plug and play!I will get myself a pre amp then. Anything you could suggest for a budget concious wanna be audiophile? :)
5 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: denon turntable DP 26F turntable doesn't turn
Add a couple drops of mystery oil to the motor shaft under the motor pulley and do what the 1st guy said
Posted on Jul 30, 2009
dunnbiker
  • 8546 Answers
SOURCE: How do you adjust the
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Posted on Apr 14, 2011
djredskyy
  • 670 Answers
SOURCE: My drive belt came off
just out the belt back on where it was
Posted on May 05, 2011
AJIN G
  • 6694 Answers
SOURCE: Which thickness setting should I use when playing
hi,
There are only two types of records available like 17 and 30. the size 30 will be as same as the turn table plater's size. 17 will be in half sized of the 30.
OK
Posted on Oct 29, 2011
Do I need to connect my older Fisher Turntable to a pre-amp before connecting to my Yamaha RX-V850?
No, you don't need a preamp if your turntable has a moving-magnet (MM) cartridge, it should work as-is! Happy vinyling =]
See page 27 of the manual:
Yamaha RX V850 User Manual Page 27
Aug 09, 2016 | Yamaha Rx-v850 Audio Video Receiver Black...
Denon dp200usb skips new records
Do you have a a weightscale for the needle pressure, anti-skate right and the table straight. An overhang gauge and set the needle in the right angle. If that't ok make sure the record and needle is real clean, since you often don't see that piece of does which causes it.
Apr 16, 2014 | Denon DP200USB TURNTABLE W USB Turntables...
Vinyl recording turntable
The Denon will act just like a standard tape recorder. It should have an audio in, for recording. If that socket is connected to the audio out of a tape socket on your receiver, the Denon will pick up the signals that are sent to your receiver from whatever source. All you have to do is follow the instructions for recording on the Denon then. If you have lost the user manual for it, it's free on-line.
Jun 22, 2017 | Denon CDR-W1500 2-Disc CD Recorder
I have just purchased a belt drive turntable and want to play vinyl through the s-302. I've connected the phono leads to the aux3 connection but the sond is not loud enough. Can you advise whether I n
Yes you need a RIAA preamplifier for magnetic phonograph cartridges. It connects between the turntable outputs and the AUX (or any other) input of your AV receiver. The only other way to make it work properly is to get a receiver or amplifier with a Phono input.
Dec 07, 2013 | Denon S-302 Theater System
NEED A REPLACEMENT STYLUS FOR MODEL 62904201
Hi, I can supply a stylus for your Denon. Cheers John. Styluscity@gmail.com
Jul 29, 2011 | Denon DP200USB TURNTABLE W USB Turntables...
How do I connect a Akai AP207 turntable to my Yamaha HTR 5630 receiver???
If you want to connect the turntable all you do is get an audio cable white and red on the end. Then hook one end to the back of the reciever and the other end to the same connectors on the turntable. Make sure its output on the turntable and input on the reciever. Good luck...
Mar 29, 2011 | Yamaha HTR-5630 Receiver
How do I connect a technics turntable to an RX-V463 AV reciever? Thank you in advance
Modern AV receivers rarely contain PHONO preamps.
A traditional turntable requires a preamp inline with it to PRE amplify and frequency-balance the minute signal produced by it's cartridge. Most stereo receivers and preamps have Phono connections and internal preamplification strictly for that purpose. Yours does NOT.
A standard turntable will require you to acquire an external PHONO preamp to place between the TT and an Aux connction on the receiver.
Some of the newer turntables come with selectable internal preamplification to solve the lack of it in modern equipment. If your turntable is that type you can select its internal preamp output and run that to an AUX input.
Jan 15, 2011 | Audio Players & Recorders
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
Hookup
what turntable specifically....
jeff
Feb 22, 2008 | Denon AVR588 Receiver
Denon DP200USB TURNTABLE W USB Turntables Turntable with USB Logo
228 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
