Question about Electrolux Dishwashers
Esi 68850 antiflood system has been activated
  • Electrolux Master
  • 3,247 Answers
This means a water leak has occured into the base of the dishwasher where the pumps and motors are located. The system shuts off to prevent water damage to components and also prevent an electric safety hazard. The best solution is to find the source of leak and fix it. Ensure dishwasher water is turned off and the power is turned off at mains socket before you work on it.
check door seals and pump hoses for damage or wear and replace. If everything seems ok, then take out dishwasher from under kitchen bench aqnd shake it a few times on its base so that any water in the flood switch can dry out. Reconnect and check.
Posted on Jan 02, 2013
How can activate this cell x free, I.m a low income Senior
This is a Business phone for an ESI phone system and can not be used separately.
Nov 11, 2015 | ESI Ivx 48 Key Local Ipfp Ip Phone...
Lost installer password for esi ivx e-class phone system?
If you own the system you can call ESI at (800) 491-3609 and they can get in through a phone line and reset the password. You will have to give them the serial number on the side of the cabinet and then sign a form giving them authorization to reset the password. they will probably ask you who your re-seller is and want to contact them. If you have one then you should be calling them and asking for the password. if you don't, then tell ESI you don't.
Oct 02, 2013 | ESI Ivx 48 Key Local Ipfp Ip Phone...
Have a zanussi dishwasher ZDF601K trouble shooter says -,antiflood device activated call engineer is there anything I can try ?
antiflooddevice bottom of machine it detects water and shuts machine down or pump keeps runnining ,clear water from bottom of machine and dry check for leaks UN PLUG FROM MAINS WHILE YOU CHECK IT AND DRY AREA
Jan 22, 2011 | Zanussi Dishwashers
I want to know about rate and process of esi deduction
Employee's having gross salary of Rs-10000/- or less are eligible for ESI scheme .It means they are covered under ESI scheme while others not.
The rate is
4.75% for employer&
1.75% for employee
of the gross salary
Jun 10, 2010 | Computers & Internet
Newish Zanussi ZDF 511 dishwasher fills the antiflood device
If you cannot find a leak then check that if you are using the 4 or 5 in one tablets that you are not using rinse aid seperately as this is also in the tablets and salt.Too much rinse aid can cause the dish washer to froth up and this can overflow down the underside of the door causing the problem you have.
Hope this helped.
May 13, 2010 | Zanussi 23 in. ZDT6255 Built-In Dishwasher
Cable Wiring Colour Coding
European color codes are black or brown for hot, blue for neutral, and green-yellow for earth or ground.
Nov 17, 2008 | Electronic Specialties ESI 385A Digital...
2 years old but NEVER used it yet. Put on today and it would not run any cycles. Let in water and emptied it out but would not do a wash cycle. All this from start to finish in about 8 mins. Washer kept...
dishwasher have a antiflood device system in the base of the applince try a tip the machine backwoord or sideway if water comes out the base you have a leak generally associate wit a failure of the seal around the impeller of the motor or the microswitch of the antifllod is stuck. to check remuve lid remuve left side panel two torke screw size 17 or 20 and unclip look inside ther is a red stick that operates a little round polistaring float ( antiflood device)
Nov 13, 2008 | Bosch Dishwashers
Aeg favorite 645
to check the antiflood, remove the bottom front panel and the bottom tray is exposed. if there is water in the tray, this will actuate the antiflood switch. just mop out the water and the machine will run. turn off from mains when you do this.
however, this will not give a hum. the antiflood switch just turns on the drain pump.
if no water found then get back to me
Oct 02, 2008 | Dishwashers
Esys 915 gl motherboard system
Hi, if I understood you right, you main concern is noise from the HSF (heatsink + fan). there are aftermarket HSF available with less noise yet higher fan rpm. you may want to try looking at http://www.tt-itbu.com/ for reference. Good luck. Kind regards.
May 26, 2007 | Gigabyte GA-8VM533 Motherboard
Dishwashers Logo
367 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
