Question about Toshiba Satellite L505-S5966 Notebook
Some keys not working ie, rev and space keys - Toshiba Satellite L505-S5966 Notebook
Bios prolem solution
Posted on Dec 17, 2013
Need help with installation
Did you download the program or is it on a disk? If the license is in an email then use copy and ctrl + v to past it.
Common problems are spaces and 0 read as O ie zero read as letter "o"
hope this helps
Nov 30, 2014 | Roxio Easy VHS to DVD 3.0 Plus
Toyota tercel troubleshooting
honestly i dont know the second one but there is no way its for fuel regulation on high revs ,, maby for inceased idle speed when under loa ,,, ie aircon or all lights and heaters on ,,, to me it sounds as if main jet is blocked in carb ,,,, choke is feeding in fuel in place of main jet ,, ie fuel starvation ,,,,
Dec 01, 2013 | Cars & Trucks
I had to reinstall xp home edition and the product key won't work help
Do you have the proper key ? it should be printed usually on a sticker somewhere on your computer
Make sure all keys are typed in correctly with the space between
IE: Q8VBM-34FWW-7DFFY- .... this is just an example
Hope this helps.
Dec 19, 2012 | Microsoft Windows Xp Home Edition Sp2...
I have IE 8 and 15 updates installed on my PC, but use Google Chrome as my default browser and MSN Premium as my primary e-mail server. I am running out of space of my hard drive. Is it safe to uninstall...
uninstalling updated ie and reinstalling an old version will not give much space on your hard drive because ie progarm files is not to big, you have to delete other files that is unecessary to you to keep for and make sure can give you much bigger hdd space or else you have to replace or add another hdd with much higher capacity.
Aug 01, 2011 | Microsoft Internet Explorer 8
It will run for awhile then it will just stop and want crank back up im thinking fuel pump because today it quit and i sprayed some starting fluid in to the breather and it tried to start then i had it...
This sounds like an electrical issue.
You will need to extract the diagnostic codes from your vehicle's computer.
This can be done in the following manner:
** Firstly, attempt the first part of the procedure with engine running **
- With gear lever in PARK, start engine and rev up to 2,500rpm, then gradually reduce revs down to idle speed (ie take foot off accelerator).
- Cycle gear lever through the gears (ie down to 1st, then back up to PARK)
- Turn Airconditioning to ON, then OFF
- Turn engine OFF
- Within 5 seconds, turn the Ignition Key in this sequence: ON - OFF, ON - OFF, ON (leave key in ON position)
- If done correctly, a series of 4-digit codes will appear in your ODOMETER display
** Remember, you must complete the ignition key sequence, within 5 seconds.
Please advise which codes appear and I will assist you futher.
Cheers,
Scott
Jul 13, 2011 | 1999 Jeep Grand Cherokee
I need to program are fax machine to have are fax # on documents that are being sent to other fax machine's
1. Press <function> then "Down Arrow" on the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" on the <start> button until [OWN NUMBER SET] is displayed.
3. Press "Right Arrow" [ENTER FAX #] will display.
4. Enter your fax number with the number keys (max. 20 digits). To insert space, press <#>, to enter "+" press <*>. To clear a mistake press <speaker> button.
5. Press <start/memory> button.
6. Enter your name by pressing number keys for each letter. Will display the capital letter for each of 3-4 letters to number, then number, then the lower case letters for each press. Use "Right Arrow" to go to next letter, if using the same number key (IE: B to A uses 1, use "right arrow" to go to next space). The #1 will give a space between words. (Max. 24 Characters).
7. Press <start/memory> [DATE&TIME SET] will display.
8. Press <stop> to exit.
Mar 19, 2010 | Sharp UX-B750 Inkjet Fax
I get the wrong symbol when typing on my new dell
Hold-down the ALT GR ("alternate graphic") key, to the right of the space-bar, and press the '2' key, release the ALT GR key, and you should get '@'.
Jan 23, 2010 | Dell 0Y3740 Keyboard
One carb does not want to fuel on low revs ie remove plug lead from good pot on low revs it stops remove plug lead on good pot with revs it wiil run remove bad plug lead on low revs makes no change to...
Sounds like you need to remove the carbs and dismantle them and clean all the parts real good.
Remember if you separate the carbs from each other you will need to resync the carbs.
Oct 16, 2009 | 1997 kawasaki ZX-6R Ninja
I have installed a new lid on my acer aspire 3050. during the install of the wirless antenas I had to remove the keyboard. Unfortunately after re installing the keyboard etc I have now discovered a number...
reseat the keyboard connection. This happens when its only making slight connections. Some laptops can be pretty tricky, especially if the ribbon cable is a bit short on the keyboard. If this helps please rate my solution.
May 10, 2009 | Acer NSK8458AN Keyboard
Toshiba Satellite L505-S5966 Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
