Question about Indesit H361FBK Kitchen Hood
Cooker hood - no lights or fan
Our indesit cooker extraction unit went bang on xmas day when turned on. Now no lights or fan. I assume it may either be the fuse or the transformer. Easy test first, change fuse...unfortunately cannot find it. Any ideas please?
  • Steff Jan 02, 2013
    Resolved! The plug (and fuse) are located by sliding the part of the box shaped casing (above the extractor itself) up. This reveals the duct to outside and the plug socket. Changed the fuse in the plug and voila!, working again...
Timon90
  • 126 Answers
SOURCE: wd10 indesit washer banging
It could be the drum bearings. If you can move the drum up and down, the bearings is worn. It could also be the balanceweight that sits on the top of the outer tub that have gone loose. It's usually made of cement, or cast iron.
Posted on Jan 23, 2008
farfield
  • 462 Answers
SOURCE: wiring a indesit hob and oven
Minimum wire size is at least #8 and maybe #6 depending how far you are from breaker box. If close to 100' (75 or more) Go the #6. But Im not sure what a hob is.
Posted on Apr 23, 2009
dazzle37us
  • 17 Answers
SOURCE: my cooker will not stay alight
check if the oven holes are not blocked by some dust or dirt, then try puting it on again.
Posted on Aug 03, 2009
SOURCE: indesit gas cooker, odd smell
Indesit Cucina cooker
My tenant is complaining of burnt metal or burnt rubber smells when the oven is hot, it is perfectly clean and only two years old
Posted on Mar 16, 2011
ZJLimited
  • 17970 Answers
SOURCE: where can i find the users manual for indesit is50e electric cooker
For Indesit IS50E Single Electric Cooker...
Check this PDF Document: indesit/_pdf/manuals/19504806702_UK
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Nov 08, 2011
Testimonial: "thank you very much "
What is wrong with electrolux cooker hood when ive changed new bulbs, the extract works but lights don't.Did make a bang when old ones blew?
Good Afternoon friend, thanks for your post!
From what you have described your Electrolux hood is working properly but the lights are not coming on. I understand that you heard a bang when the old ones went out it could be possible that your receptacle is bad or wire has shorted. I would suggest having a technician out to properly diagnosis your hood. They have the appropriate tools and knowledge needed to pinpoint the reason your lights are not working properly. Good luck. -Matt
Feb 22, 2015 | Electrolux Kitchen Ranges
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
Fan on cooker hood does not work but light works
It it new? Maybe the fan connection in the connection panel come loose or was not done properly from factory. Turn off the breaker to the hood and inspect the wires and connections, if all is good, then maybe the switch needs replacing. Good Luck!
Jun 25, 2012 | Kuppersbusch Designer Island Canopy Cooker...
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
Cooker hood
Look around on the hood and cooker for a small fuse. If you find one, replace it with one of the same type and rating.
Apr 16, 2009 | General Electric Stove/Oven/Range Chrome...
My Hygena cooker hood fan (model APP2540) stopped working.
this sound like the pcb for all your cooker hood spares visit our site
You-Tube video "8eLuShj-RAg" placeholder (do not delete)
Feb 22, 2009 | Rangemaster Broan 614804 BALLISTA 48IN...
Bulb has blown on one of the lights but the other light will not
Its definetly the control board again.
Its worth $110.00
Read other answers ive given to others about similar problem
gtp_jmp
Jan 22, 2009 | Kitchen Ranges
Indesit cooker hood.
some have fuses, some dont. i know that if you dont have the vent hood hooked up correct the heat can melt the wires on the inside. so make sure the vent is hooked up right.
Mar 16, 2008 | Kitchen Ranges
Cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Feb 18, 2008 | Kitchen Ranges
Indesit cooker hood
indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
Oct 17, 2007 | Kitchen Ranges
Indesit H361FBK Kitchen Hood Logo
Top Indesit Kitchen Ranges Experts
Greg Cann
Greg Cann
paulcarew
Owen Barnes
Are you an Indesit Kitchen Range Expert? Answer questions, earn points and help others
