Question about DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale
Elite scale 100 legend - DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale
What is battery model# for a swiss Legend Commander Chronograph watch?
Here is a number to find out:
Swiss Legend Watches
"Express Your Time"
3701 S. Flamingo Road, Suite 100, Miramar, FL 33027
Toll Free
: 1-866-746-7794
Jun 13, 2016 | Swiss Legend Watches
Mouse not working on rise of nation rise of legends
I fixed this going to the main folder of the game and in legends.exe (the client launcher) right click -> properties -> compatibility tab -> check the "Disable display scaling on high DPI settings"
Hope it works! good luck
Oct 18, 2012 | Microsoft Rise of Nations: Rise of Legends...
Operating instructions for Volt -100 pocket scale
If you don't have the measured weights that sometimes come with scales or can be purchased individually, I'd recommend using a United States nickel/5 cent coin. They are supposedly an exact 5 g's each, and a Volt-100 scale requires 100 g's for recalibration. Therefore, you can recalibrate your scale using 20 nickels. I also use a Volt-100 and so far this has worked for me exactly; the most it's ever been off is .02 g, which is basically nothing.
What you do is remove your batteries, (I'd replace them with brand new ones if you have the option) then place the scale on a completely smooth, perfectly level, flat surface. Power the scale on, make sure it is reading 0.00, hold the M (mode) button until CAL comes on the screen, release the button for a quick second, then press it again one more time (quickly, don't hold this time), and then wait until "100.00 g" is flashing on the screen. Then you're going to place your 20 nickels on the scale as smoothly and with as little jostling or movement as possible. After a moment, the screen should read out "PASS". You then power the scale off (don't weigh anything before turning it off as it can possibly adjust the calibration you just set or weigh out heavily or light) and to test out your newly calibrated scale, turn it back on and weigh one nickel. It should be exactly 5 g's, with no more than a .02 digression in either direction if done properly. Good luck!
Jul 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
When I check my scale with 100lb weight it reads 100 kg or 220 lbs??
you need to turn the calibration setting to 100 lbs, then it will be calibrated
Mar 17, 2011 | Detecto Model 6855 Bariatric Scale
No$dsemulator
Here are a few:
02619020 - Obtain Legend Sword, Legend Robe, and Legend Ring
19970628 - Obtain 100% Scan Data for DotAgumon
70307991 - Obtain 100% Scan Data for DotShineGreymon
82607991 - Obtain 100% Scan Data for Numemon
I hope this helps!
Jul 21, 2010 | Nintendo DS Console
I have lost twenty pounds but the body fat never changes. How to fix?
I don't know how your are calculating your body fat, but it may be a case of letting your body catch up - it takes longer for your body to look different than to just lose the weight on the scales. Maybe 2 or 3 months down the road you will see real changes.
The other possibility is a serious one - if the body fat is really not changing, you may have only lost muscle weight - and this could be involuntary muscle tissue - such as regulates breathing, also heart tissue. This happens with unhealthy dieting as with diet pills, crash dieting.
Jul 27, 2009 | Tanita BF681 Scale Plus Body Fat Monitor
My Pentair Legend Pool Cleaner is too slow
Here is a link to the factory website where they have technical support for this kind of problem.
Legend Pool Cleaner
Feb 23, 2009 | Pentair White/Gray Legend Platinum...
How do I set the clock on the Elite Home digital scale
On the display, hit "set" for 3 seconds. The hour setting will blink. Press the up or down arrow to increase or decrease the hour number. Press "set" again. The minute setting will blink. Press the up or down arrow to increase or decrease the minutes. Press "set" when finished.
Nov 30, 2008 | Elite Home Electronic Personal Bathroom...
Canon mp530 issues with printing
Use scaled printing (Mac OS X) Instructions to use scaled printing. You can manually select the scaling ratio you wish to use to print images and documents. scaling_sample.jpg Note: The Scaled Printing function is not available when Borderless Printing is selected (OS X.version 10.2.1 or higher).
  1. Open the Page Setup dialog box.
  2. Specify the Scaled Printing settings.
    Note: For a reduced scale printing, enter a value smaller than 100 %. For an enlarged scale printing, enter a value greater than 100 %.
  3. Click 'OK'.
  4. Open the Print dialog box.
  5. Click 'Print'.
Printing will now begin.
I hope it helps!!!
Nov 27, 2008 | Canon PIXMA MP530 All-In-One InkJet...
DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale Logo
96 people viewed this question
Top DigiWeigh Measuring Tools & Sensors Experts
Tom Chichester
Bill Eager
Are you a DigiWeigh Measuring Tool and Sensor Expert? Answer questions, earn points and help others
